  • quantumuppercut
    Mu metal +1 Steel 0
    Wait, what kind of steel. lol
    Wow, cut out a block of steel... Now I know how lazy I am. lol
  • toranarod
    hello to all.
    That's a good idea. I have tested every thing else.
    I can quickly inset bolt of the same dimension into my coil to replace the laminated core. that will be interesting if what we thought was the worst set up became the best setup. An OU device you can build from your Hardware store.
    that will freak out the energy company's
    Hello
    I am very surprised about what I am about to report.
    I have just spent a few hours cutting up a peace of middle steal into the exact shape as my MU metal laminated core. I have put a soiled block of steel into my 5mH coil replacing the laminated MU metal core. Setting up all the same condition as before without laminations. IT DID NOT WORK .
    The only thing it did was work under full short circuit.
    Remember I said the MU metal did not work under full short circuit but did work under a normal load. So soild steel cores are out unless somebody else can prove other wise.
    I was not able to use any power from the generator coil. Any attempt to drive the largest load was met with standard generator behavior. Lenz law was all over it.
    I will try a solid MU metal core any money on the out come
  • quantumuppercut
    thanks for the Photo
    It all makes complete sense now? So now we know how to do it.
    Who is going to be the first to build an OU motor
    who is working on a full prototype for a full size working generator.
    I did some drafting on the weekend. there are just few unknown dimensions but will have that sorted out soon.
    Already? Guess I'll try to catch up in some way. I'm working on my ghetto version. Ain't working out so well. The little guy is drawing too much juice.
    ImageShack® - Online Photo and Video Hosting
  • Xenomorph
    Just looking back at Romero's setup I would like to say some of his design makes good sense, but there are other parts that don't I guess we will never know?
    If it didn't work he was very close. and if it did its his secret.
    Or he might have a different principle going on.
    He once posted a statement that can be found on page 24 of the "official" pdf:
    Don't even think of using metal or laminations for the cores
    It could have been a disinfo attempt, but i guess only him knows why
    he would not have used metal.
    Regardless, it is very important that you have found the benefit of laminations! Much luck with further development of it !
  • toranarod
    looking back
  • toranarod
    Originally posted by kEhYo77 View Post
    Now when I look at the Neo-Gen/Muller design of coils some things become more obvious. So for this effect to manifest at relatively low RPM there has to be a part of the core sticking out in the front, ha? Hmm...
    What I also see is that the core, made from magnetite dust is encased with a pipe, that looks metallic (Maybe for those eddy currents to help things out).
    The guy from THIS video uses similar design (a pipe around the core) to achieve the acceleration effect. He says that the clue to use metal/aluminium bobbin for generator coils came from Ed Leedscalnin's notes on magnetism.
  • toranarod
    steal bots
    hello to all.
  • mondrasek
    I finally had some free time today. Made a new rotor. (8) .5"x.5"dia n42 (or at least that is what I bought several years ago), all same pole facing out from the edge of the rotor.
    Because of the new aero drag conditons I can only get ~2230 RPM max. I am sure I could increase that if needed by placing air shields close to the rotor.
    So, Rod, what do you need tested? I have variable RPM control, BTW.
    M.
    PS. 6lb of 7x36 Litz arived last Friday. The buck/boost DC/DC convertor is in transit with Speed Mail from HK.
  • Mark
    Hey Guys,
    I have for the first time been able to see rotor speeds increase when shorting a coil out. Was a very simple setup, I have Ricks Classic 3-Pole kit. I was just runinng a simple SSG circuit to get my rotor up to 3,000 rpm's. Then I took the supplied generator coil and mounted it on the frame but instead of bolting it down normally I flipped it upside down so the coils is 1.75 inches away from th erotor instead of .25 inches.
    Then I inserted some 3.5 in. welding rods down thru the coil and about .35 in. from the rotor. This of course lowered the rotor speed to 2823.
    If I short the coil out the rotor speed increases to 2844. Not a big increase but easy to replicate if you have the same kit. It worked with many different starting speeds for me.
    If I attach a load to the coil the rotor does slow down though.
  • kEhYo77
  • quantumuppercut
    I am very happy to hear of your results, this is great news. The more information we can accumulate on this the better.
    YES its a great feeling to see it on your own work bench.
    I would like to see any data you have about the experiment.
    well done
    Oh it's not me. hehe It's a guy over at OU name Overchuss. But this is good, we need independent and more replications of this effect, then we could involve physicists to derive a model for this. The engineer can follow the model and improve the design.
    One thing I notice is both Overchuss and Marius use bolt. That would have more eddy current than laminated core. They both achieve the effect at relatively lower speed. Therefore, I wonder if eddy current is a desire property for this effect along with high mu.
  • toranarod
    Yes Iron is the solution to beat the lenz law at lower RPM, WOW! I think that we can safely say we have made it, only the fine tuning is what remains to be done.
    It was all embedded in the Iron symbol (ferrum): Fe = Free Energy !!! coincidence? I think not! Interestingly, Iron also is the source of biological life. I can't be more excited.
    one other very important point. I think this has been covered before
    but just to recap this.
    The coil needs to be set back from the end of the core. just far enough to stop the lenz field from the copper having to great an effect but to far and you drop to much voltage.
    MU metal works a bit better but not worth the extra fuss at this point.
    Slider HA HA.. iron this out.
  • Slider2732
    Reading along here. I liked the Fe link to Free energy...cool !
    Time to iron this out.
  • elias
  • toranarod
    Originally posted by quantumuppercut View Post
    From Overchuss at OU:
    Hi folks,
    i've just achieved speed-up with shorted coil and also with a 'normal' (light bulb) load, at relativ low RPM (~ 1200, sorry no tacho ). And no Lenz, if no acceleration occurs !
    That's absolutely cooool ! I've never seen this before.
    My setup:
    A rotor (12 cm dia.) with 7 NEOs, 20 mm (dia.) x 5 mm thick (N52), NN Arrangement.
    6 Coils (1 Motor-Coil, 5 Pick-up Coils)
    I've achieved this with a Steel (V2A ?) screw, 45 mm long, 10 mm dia.
    3 mm Distance to the Rotor. The speed-up effect occurs with both low inductance, as well with high inductance.
    The higher the inductance - the better the acceleration, though.
    The Dimensions of my coil bobbins: 36 mm (dia.) x 11 mm (thick), with a 10 mm hole (for audio crossover applications).
    (Test) Coil Inductance, Resistance: from 470 uH, 0.8 Ohm (0.6 mm Gauge) to 2.55 mH, 6.55 Ohm (0.3 mm Gauge).
    The coil to rotor distance is ~ 25 mm to end of the screw (head).
    The solution to achieve OU is (most likely): A Iron Laminat Core !!!
    I think, we are very, very close to OU !
    Gerald
    P.S.
    Sorry for my lousy english, this is not my native language.
    Seems like more successful replications. Yes, I think if we can do it at standard walmart fan speed. We can just make those coils and sell them. lol We just need to pin down how it works. So far we can generate some parameters:
    Inductance - the higher the better
    Resistance - the lower the better
    Core type - high mu?
    current - higher the better (too high Lenz kick in again?)
    position - adjusting needed
    well done
