This thread
Still reading through this thread and getting the information I can on his coils.
This is good reading with regard to motor generator units.
Any comments welcome.
wantomake
Why did this thread stop?
I've not read through this entire thread. Watched some of the Muller videos. This seems like a self running machine. Even with all the different variables that is mentioned and needs more testing.Originally posted by blackchisel97 View Post1- At certain speed the shorted coil will self oscillate... check here to get more info Self Assisted Oscillation in a Shorted Coil - Bucking Magnetic Field Oscillation - YouTube
2- A bifillar coil where one of the coils is not equal in lenght to the other one is another thing that you need to start to investigate now
3- A multifillar coil where each one of the coils is not equal in length to another one.
4- I have originally started exploring this in solid state version, with the help of the oscilloscope
5 - Difference of one cm in length can make a big difference - this is one of the reasons it took me very long time to get it right.
6 - The other things about the split core I told you before... make sure you can adjust the 2 split core pieces.
7- Distance between the magnets not less than 1.1% the magnet size but not more that 1.5%, you need to visualize the existence of the virtual pole in between the magnets. I believe it means between 1.1 - 1.5 magnet size, not percent of its size.
8- This info can be used in other experiments, you can also have a look at Dave45 suggestions
9- Start the easy way, simple is better.
10- short at the peak of the wave without any additional component, just the right length of a shorted coil
I hope this info will bring some light to some open mind people.
It sure does
Thank you for a quote chalamadad
Vtech
Why did this thread stop 6 years ago?
I think this thread needs more study on how Muller wound his coils with bifilar or multifilar windings. Split coils.
I'm sure to get some to answer that tried to replicate this. There were many YouTube videos on this subject.
wantomake
Hello
Hello,
I'm new on the forum, I read about free energy since 4-5 years and I test the bedini motor (one coid). But when I see the Romerouk video I know what I want to test
So I read this forum, is very long and my first language are french. So for starting with a good set-up do you advise this parameter:
rotor diameter: 200mm
nb magnet: 8
nb coid: 9x2
magnet size: 1po/0.5po
coid size: 1pox0.5po
rotor material: plexyglass, maybe aluminium
Feel free to correct me, I don't started the construction and thank you for the information on the forum.
When I begin testing I will be happy to give you my tests information. Free energy are very important for the earth and everybody should know that !
I would think the shorted coil and receiving coil would need to be in resonance
(quarter wave resonance)
That seems like a good idea. But why keep pondering around if you could try and find out? Looking forward to seeing your results.Originally posted by jehdds View Post"3- A multifillar coil where each one of the coils is not equal in lenght to another one."
Would this not be perhaps what John Bedini eluded to by having the Kromrey with TRIFILAR wind.....
Two of the wires wound Tesla series type and the third Shorted as noted above? That would in essence bring the lengths to have a differential to be sure. Something to ponder.
Very Best Regards,
Jim
"3- A multifillar coil where each one of the coils is not equal in lenght to another one."Originally posted by Dave45 View PostIm glad to see experimenters on the right track, you need two coils like Romero's muller generator wound cw and ccw wound bifilar one filar shorted on each side.
dave
Very Best Regards,
Jim
dave
Koneheads latest
Backing Magnets
backing magnets on motor coils.m4v - YouTube
Shorted Coils, Ferrite Core
Shorted coil speed up.mp4 - YouTube
Hey everyone,
I've got my motor running very efficiently. Maybe just a little more than 1 watt input. I am using two fast switching Schottky diodes to collect the oscillation output. I connected the diodes like shown in this thread (thanks to ufopolitics). I am feeding the output to a second driving coil which is creating one spike to just overcome the drag. The second coil is also catching some of the oscillations from the first coil.
Happy with the result. I've made a short video.
Chal
1- At certain speed the shorted coil will self oscillate... check here to get more info Self Assisted Oscillation in a Shorted Coil - Bucking Magnetic Field Oscillation - YouTubeOriginally posted by chalamadad View PostRomero released additional info:
It sure does
Vtech
Thank you for the Quote Chalamad, very interesting Informations in it.
Hi marius,
more hints for you to try...
5 - Difference of one cm in lenght can make a big difference - this is one of the reasons it took me very long time to get it right.
7- Distance between the magnets not less than 1.1% the magnet size but not more that 1.5%, you need to visualize the existance of the virtual pole in between the magnets.
10- short at the peak of the wave without any aditional component, just the right lenght of a shorted coil
Best regards,
Romero
I've done the measurements with no coil in place vs coil in place etc ...
I've logged all results here at my 'bench' here (my name is deepcut on other FE forums) :
Acceleration under load experiments ...
My videos are here, as well as my archive of OverUnityGuide's (OUG) work :
deepcut66's Channel - YouTube
I think it's a viable method but i can't afford the amount of copper wire i calculate it would take to be OU.
QV.
That's a great video, thanks for posting about it
Also, well done Mariuscivic !
All we have to know, is what draw there is with no generator coil in place. That seems to be the limiting thought people have, in case it would be 180mA or whatever.
With Romero using multistranded coils (which I was able to show doing funky things some months back) i'm convinced i'm going to be spinning some rotors around tomorrow lol.
Will certainly try to replicate the effect shown in the video, he's stripped out a lot of uncertainty with this clear system !
Speed up under load
Marius discovered the speed up under load effect with a bifilar generator coil. He dead shorted one of the wires and connected the other wire to load, in his case a bunch of LEDs. The rotor speeds up and the amp draw decreases:
speed up with bifilar coil - YouTube
