Water Sparkplug
  • rosco1
    Update
    Originally posted by gmeast View Post
    What ever happened to the RPG 4700 thing?
    Apologies for the lengthy delay in posting up info on the RPG 4700.
    This link shows a 17 second video of what it yields thus far.
    YouTube - Aquapulser RPG 4700 with Crane Cams HI6 and PS91 coil, using thick strap Firestorm plug replication.
    Next step will see this plasma tested with a modified Kiker Wire, as well as resistorless Brisk LGS plugs which have been kindly made available by Brisk for these tests.
    Steps have also been taken to fabricate a special spark plug which will hopefully take full advantage of this plasma.
  • gmeast
    Rpg 4700
    Originally posted by cowboyrx View Post
    Are you selling a complete kit or assembled unit?
    If I buy thr PCB, will it include a parts list and soldering instructions?
  • cowboyrx
    Originally posted by Shane Jackson View Post
    As promised here is a short video with crappy audio.
    YouTube - Vexus Plasma Spark.
    If you are wondering.... Lysol. I think part of the problem is I did not have the plug grounded very well. All my vice grips are in my spray foam truck.... I may do another video when my new plugs arrive.
  • Aaron
    Mixing High Voltage and Low Current
    Little explanation on diagram
  • Aaron
    How to Mix High Voltage and High Current
  • ashtweth
    Great part about the ECOPRA micro bubbler is that it can make A LOT of mist from the engines exhaust just a matter of regulating it and getting it into the FINE mist.
  • rosco1
    Update
    I've managed to source a set of resistorless Brisk Premium LGS plugs for my testing too.
    This will give me an opportunity to compare different plugs, namely FireStorm and Brisk Premium LGS, with the Crane Cams HI6 and PS91 coil, as well as the Aquapulser RPG 4700 plasma gen.
    My Aquapulser unit should be arriving from the USA sometime in the next fortnight. Hopefully the LGS plugs arrive at the same time.
    Ash is right, I'd like to attempt to use parts of the ECOPRA system to deliver a fine water mist, as my current water/methanol injection isn't adequate.
  • ashtweth
    AND
    Thanks to our LUC for creating a monster
  • gotoluc
    Great mate
    Thanks to you and Rosco's for continuing the research
    Luc
  • ashtweth
    Hi Luc
    Okay Rosco and i are looking getting a vaporizer from Ecopra for the aqua pulsa circuit now, another aqua pulsar is on the way to Panacea and Robins NEW plugs will be used with them./ New video is coming re loaded with results and exhaust gas anlysis MPG.The Water spark plug is coming back with a vengeance .
  • gotoluc
    Hi Luc, they have done one or two tests on a petrol engine and got 20% but used too much water and are optimizing it ATM, i thought maybe the VAPORIZER they use might work for the spark plug?, seems like a neat unit.
    Ash
    Thanks for the reply Ash
    You're right to think that and goes to prove the results that Greg was getting.
    Thanks for sharing
    Luc
  • ashtweth
    Hi Ash,
    thanks for the links
    Concerning the Ecopra vaporizer. I thought this was for Diesel Engines and there are no spark plugs in a Diesel Engine. Do you have this working in a Gasoline Engine?
    Thanks for sharing
    Luc
    Ash
  • sigzidfit
    one more time
    Originally posted by AhuraMazda View Post
    @Spokane1
    You may be interested in these notes:
    "Electrically induced explosion in water"
    Go to page 71 of
    Meyer WFC Extra Info
    It highlitghts frequencies at which water explodes.
    @AhuraMazda
    I looked at the document you referenced. I saw no reference to frequencies on the page referenced. The only thing I saw concerning frequency (aka speed? interval?) was the range of the scope used (50 mhz).
    Actually, I've seen little to no explicit information any where concerning the frequency (at least none with any independent reference or support).
    However, if you are interested, see totally ignored post #1988 in this thread:
    The resonant frequency of a hydrogen atom is....
    Perhaps this will help.
    "In the case of water, a preferred resonant frequency is 1420 MHz which corresponds to the nuclear magnetic resonant frequency of hydrogen. At 1420 MHz hydrogen atoms become excited via nuclear magnetic resonance and will break their valances and separate from the one oxygen atom." Excerpted from United States Patent 6581581 - Ignition by electromagnetic radiation
    Information contained in these patents may also be relevant to your pursuits:
    United States Patent 3587775 - HYDROGEN-OXYGEN SOUND SOURCE
    United States Patent 6705425 - Regenerative combustion device
    United States Patent 1226500 - WATER EXPLOSION-ENGINE
    PEACE
    PJ
    Again.
    Peace
    PJ
  • gotoluc
    Hi Ash,
    Thanks for sharing
    Luc
  • ashtweth
    Finally i can get off my PHAT Butt and contribute some R and D. BTW Robins new plugs look IMMORTAL (can take a punishing)
    R and D
    YouTube - Plasma Water Ignition
    New aqua pulsar video
    Comments/Idea
    WELL DONE, Try an Ecopra kit using water mist injection (using the endothermic reaction ALREADY from the exhaust) to inject THROUGH THE PLUG. Guys Check out Panacea's ecopra install.
    YouTube - Panacea Ecopra Installation (1 of 2)
    WATER MIST INJECTION IS THERE. Try Water mist through a reservoir -> into Ecopra vaporizer -> through the RPG 4700 through the plug it self for ENHANCED ignition. We may be able to test for you drop me a mail guys.
    I think water mist from the exhaust put through Robins plugs is underrated, but what do i know
