Thanks Gordon
Imagine... this Man did things that still cannot be done till this Day!!
Chet
Originally posted by RAMSET View PostS
What is he saying??
Chet
Resonance
I do not of course intend to limit myself to the specific manner and means described of artificial cooling, nor to the particular forms and arrangements of the circuits shown. By taking advantage of the facts above pointed out and of the means described I have found it possible to secure a rise of electrical pressure in an excited circuit very many times greater than has heretofore been obtainable, and this result makes it practicable, among other things, to greatly extend the distance of transmission of signals and to exclude much more effectively interference with the same than has been possible heretofore.Last edited by MonsieurM; 10-16-2011, 10:51 PM.
I just wanted to add this paragraph from the patent
Now in his aptent, Tesla talks about using a cooling liquid, but at the right resonance you boil the liquid as in Peter Daveys/ Serbian Mr C Set up:Originally posted by MonsieurM View Postdid you guys already read this patent by Tesla
MEANS FOR INCREASING THE INTENSITY OF ELECTRICAL OSCILLATIONS.
Tesla Patent 685,012 - Means for Increasing the Intensity of Electrical Oscillations
From the foregoing the operation of the apparatus will now be readily understood. Assume, first, as the simplest case that upon the coil A of the transmitter impulses or oscillations of an arbitrary frequency and irrespective of its own free vibrations are impressed. Corresponding oscillations will then be induced in the circuit B, which, being constructed and adjusted, as before indicated, so as to vibrate at the same rate, will greatly magnify them, the increase being directly proportionate to the product of the frequency of the oscillations and the inductance of circuit B and inversely to the resistance of the latter. Other conditions remaining the same, the intensity of the oscillations in the resonating-circuit B will be increased in the same proportion as its resistance is reduced. Very often, however, the conditions may be such that the gain sought is not realized directly by diminishing the resistance of the circuit. In such cases the skilled expert who applies the invention will turn to advantage the reduction of resistance by using a correspondingly longer conductor, thus securing a much greater self-induction, and under all circumstances he will determine the dimensions of the circuit, so as to get the greatest value of the ratio of its inductance to its resistance, which determines the intensity of the free oscillations. The vibrations of coil B, greatly strengthened, spread to a distance and on reaching the tuned receiving-conductor B' excite corresponding oscillations in the same, which for similar reasons are intensified, with the result of inducing correspondingly stronger currents or oscillations in circuit A', including the receiving device. When, as may be the case in the transmission of intelligible signals, the circuit A is periodically closed and opened, the effect upon the receiver is heightened in the manner above described not only because the impulses in the coils B and B' are strengthened, but also on account of their persistence through a longer interval of time. The advantages offered by the invention are still more fully realized when the circuit A of the transmitter instead of having impulses of an arbitrary frequency impressed upon it is itself permitted to vibrate at its own rate, and more particularly so if it be energized by the freely-oscillating high-frequency discharges of a condenser. In such a case the cooling of the conductor A, which may be effected in any suitable manner, results in an extraordinary magnification of the oscillation in the resonating-circuit B, which I attribute to the increased intensity as well as greater number of the high-frequency oscillations obtained in the circuit A. The receiving-coil B' is energized stronger in proportion and induces currents of greater intensity in the circuit A'. It is evident from the above that the greater the number of the freely-vibrating circuits which alternately receive and transmit energy from one to another the greater, relatively, will be the gain secured by applying my invention.
300 hz & 400 hz (How are they obtained?)
Boguslaw,
Well, I don't understand the physics behind it but I'll explain it the way the inventor explained it to me. He said that you have to tune the can carefully to the exact right frequency. The cans in US must be tuned to 60 hz and the cans in Europe to 50 hz. Once the cans are properly tuned and the ring gap is exactly correct, the mains voltage through the negative ring will cause the can to sing 300 hz in USA and 400 hz in Europe.
As I understand it, this is not explained by modern physics but by older physics.
If you like, I'll ask for more information regarding this issue.
Best Regards,
Slovenia
Богуслав,
Па, ја не разумем физику иза ње, али ћу то објаснити начин проналазач је објаснио мене. Он је рекао да морате да подесите може пажљиво да Тачан праву фреквенцију.Конзерви у САД мора да буде подешен на 60 Хз и лименке у Европи 50 Хз. Када су правилно подешени конзерве и прстен јаз је управо тачна, напон кроз негативне прстен ће проузроковати може да пева 300 Хз у САД и 400 Хз у Европи.
Како ја то разумем, то није објашњено од стране модерне физике већ старији физике.
Ако желите, ја ћу питати за више информација у вези са овим питањем.
Срдачан поздрав,
Словенија
Originally posted by boguslaw View PostI still can't understand what those arrows with 300Hz and 400Hz mean. How they are obtained ?
Inventor
Or contact is the inventor of what I have referred to as the Serbian Sonic Boiler.
I am learning more about this device and it is quite an incredible device. Only an incredible man could have come up with such a simple workable design for such a complex process, (i.e.: not in our understanding).
Can Size for USA 220 Volts
Hi Chet,
I'll have to check on that for you. Good question. My computer has had my full undivided attention and I wasn't paying that much attention to the project at hand.
Yes, this contact is a very sharp cool guy indeed!!
Best Regards,
Slovenia
Originally posted by RAMSET View PostSlovenia
This is Wonderful!!
Which Can Do we use for USA device??
Thank you
Chet
Prof. Savic'
Slovenia
This is Wonderful!!
Thank you
Chet
Mr. "C" has a Name
Mr. "C" has a name now.
He autographed his diagrams.
Mr. C's New Diagrams
Sonic Boiler Diagram for USA
Sonic Boiler Diagram for USA & Europe
Sounds like fun
I hope we have the Can for the new one??
Chet
Suppression
Hi Boguslaw,
Good to hear from you. No, I've been having serious computer problems. My computer crashed really bad during an upgrade and I've been working on that feverishly for several days trying to get it up and running. I finally got it going but I'm not happy with the upgrade.
Anyway, there is no suppression. I was just otherwise engaged. The contact knows how the device works and is now saying he will explain it to me. He has also sent me two more diagrams of his device to post with some new information. He found a better design for the US version. It needs to run on 220 volts too. Anyway, I will be posting the new diagrams soon, hopefully today. I need to ask my contact a lot of questions about his device, so that we can all understand how it works. Right now it's like a magic lantern. It looks like something that shouldn't work; according to modern science won't work; but works well.
Thanks for checking in.
Best Regards,
Slovenia
Originally posted by boguslaw View PostWhat is happening to Slovenia ? Is this kind of suppression ?
Also,I would like to know if Slovenia contact knows how this device works and if he is willing to share that knowledge ?
Nice Gordon!!
I've never seen that before. Thanks for sharing it!!
