  • Inventor
    Or contact is the inventor of what I have referred to as the Serbian Sonic Boiler.
    I am learning more about this device and it is quite an incredible device. Only an incredible man could have come up with such a simple workable design for such a complex process, (i.e.: not in our understanding).
    • I still can't understand what those arrows with 300Hz and 400Hz mean. How they are obtained ?
      • 300 hz & 400 hz (How are they obtained?)
        Boguslaw,
        Well, I don't understand the physics behind it but I'll explain it the way the inventor explained it to me. He said that you have to tune the can carefully to the exact right frequency. The cans in US must be tuned to 60 hz and the cans in Europe to 50 hz. Once the cans are properly tuned and the ring gap is exactly correct, the mains voltage through the negative ring will cause the can to sing 300 hz in USA and 400 hz in Europe.
        As I understand it, this is not explained by modern physics but by older physics.
        If you like, I'll ask for more information regarding this issue.
        Best Regards,
        Slovenia
        Богуслав,
        Па, ја не разумем физику иза ње, али ћу то објаснити начин проналазач је објаснио мене. Он је рекао да морате да подесите може пажљиво да Тачан праву фреквенцију.Конзерви у САД мора да буде подешен на 60 Хз и лименке у Европи 50 Хз. Када су правилно подешени конзерве и прстен јаз је управо тачна, напон кроз негативне прстен ће проузроковати може да пева 300 Хз у САД и 400 Хз у Европи.
        Како ја то разумем, то није објашњено од стране модерне физике већ старији физике.
        Ако желите, ја ћу питати за више информација у вези са овим питањем.
        Срдачан поздрав,
        Словенија
        • Comment
          • I just wanted to add this paragraph from the patent
            did you guys already read this patent by Tesla
            MEANS FOR INCREASING THE INTENSITY OF ELECTRICAL OSCILLATIONS.
            Tesla Patent 685,012 - Means for Increasing the Intensity of Electrical Oscillations
            Now in his aptent, Tesla talks about using a cooling liquid, but at the right resonance you boil the liquid as in Peter Daveys/ Serbian Mr C Set up:
            From the foregoing the operation of the apparatus will now be readily understood. Assume, first, as the simplest case that upon the coil A of the transmitter impulses or oscillations of an arbitrary frequency and irrespective of its own free vibrations are impressed. Corresponding oscillations will then be induced in the circuit B, which, being constructed and adjusted, as before indicated, so as to vibrate at the same rate, will greatly magnify them, the increase being directly proportionate to the product of the frequency of the oscillations and the inductance of circuit B and inversely to the resistance of the latter. Other conditions remaining the same, the intensity of the oscillations in the resonating-circuit B will be increased in the same proportion as its resistance is reduced. Very often, however, the conditions may be such that the gain sought is not realized directly by diminishing the resistance of the circuit. In such cases the skilled expert who applies the invention will turn to advantage the reduction of resistance by using a correspondingly longer conductor, thus securing a much greater self-induction, and under all circumstances he will determine the dimensions of the circuit, so as to get the greatest value of the ratio of its inductance to its resistance, which determines the intensity of the free oscillations. The vibrations of coil B, greatly strengthened, spread to a distance and on reaching the tuned receiving-conductor B' excite corresponding oscillations in the same, which for similar reasons are intensified, with the result of inducing correspondingly stronger currents or oscillations in circuit A', including the receiving device. When, as may be the case in the transmission of intelligible signals, the circuit A is periodically closed and opened, the effect upon the receiver is heightened in the manner above described not only because the impulses in the coils B and B' are strengthened, but also on account of their persistence through a longer interval of time. The advantages offered by the invention are still more fully realized when the circuit A of the transmitter instead of having impulses of an arbitrary frequency impressed upon it is itself permitted to vibrate at its own rate, and more particularly so if it be energized by the freely-oscillating high-frequency discharges of a condenser. In such a case the cooling of the conductor A, which may be effected in any suitable manner, results in an extraordinary magnification of the oscillation in the resonating-circuit B, which I attribute to the increased intensity as well as greater number of the high-frequency oscillations obtained in the circuit A. The receiving-coil B' is energized stronger in proportion and induces currents of greater intensity in the circuit A'. It is evident from the above that the greater the number of the freely-vibrating circuits which alternately receive and transmit energy from one to another the greater, relatively, will be the gain secured by applying my invention.
            Signs and symbols -Confucius.
            • Thats easy for him to say
              S
              What is he saying??
              Chet
              BE that change !!
              • Originally posted by RAMSET View Post
                S
                What is he saying??
                Chet
                Resonance
                I do not of course intend to limit myself to the specific manner and means described of artificial cooling, nor to the particular forms and arrangements of the circuits shown. By taking advantage of the facts above pointed out and of the means described I have found it possible to secure a rise of electrical pressure in an excited circuit very many times greater than has heretofore been obtainable, and this result makes it practicable, among other things, to greatly extend the distance of transmission of signals and to exclude much more effectively interference with the same than has been possible heretofore.
                • Thanks Gordon
                  Imagine... this Man did things that still cannot be done till this Day!!
                  Chet
                  BE that change !!
                  • What is he saying??
                    What is he saying??
                    You need to study both translations below to get the feel of what he is saying. This is from Google Translator which isn't ideal but the only online translator I've seen that translates Serbian.
                    Serbian Translation:Croatian Translation:
                    S
                    What is he saying??
                    Chet
                    • Tesla did things
                      We're going to do some of them soon.
                      Chet
                      • Yes
                        Yes, Tesla style.
                        Resonance
                        • Interpretation Requested
                          I just sent Dragan a copy of the Inventor's message so he could give us a good clean English interpretation of it. He lives in Belgrade and speaks the Serbian language fluently and can give us a good accurate English translation.
                          • Thats great
                            I was ready to put out an APB for an interpreter !!
                            This is Wild stuff "S"!!
                            Have you asked him the Can size for USA ?
                            If the can is to short at 2'5 wide I can get a longer can in a bigger diameter?
                            I want to get busy with this I'm heading home tomorrow?
                            Also I really would like to work In 110 volts if possible ,just for using the power in meter ??
                            I am not to good at long math............ [if all experiments are in 110 it will be easier for me]
                            Chet
                            BE that change !!
                            • Translation
                              This is the best translation of the Inventor's message I could get so far. I haven't heard back from Dragans yet.
                              (Message from Inventor in Serbian translated to English.)
                              • Can Size
                                Hi Chet,
                                I forgot to ask him about the can size for USA. I'll send him a message before I go to bed. The can diameter has to stay the same, but the length does change from 50 hz to 60 hz. I'll get that for you as soon as I can. I think the 220 volts is the way to go instead of the 110 volts. COP 12 sounds great!!
                                Best Regards,
                                Slovenia
                                Chet
