  • RAMSET
    You have a water capacitor
    Daemonbart
    This is storing energy in the water [normal]
    Short out your water before touching even if the power is off! [google water capacitor]
    Very cool you see the resonant wave in the water [some said this would not happen]
    Thanks for sharing.......
    Chet
    PS
    If you could get some Distilled water for a quick test that would be interesting??
  • MonsieurM
    are you familiar with the work of Victor Schauberger
    read this post (i would recommend you read the whole thread when you get the chance to )
  • daemonbart
    Stored energy?
    Hi,
    must only point that I am using ac mains, no dc for the moment!
    After cutting of power there are some voltage and amperage stored in water (still ac mode ). If connecting amperemeter to device, like shortcutting, it gives current for quite some time.. I will measure energy later!
    Maybe that is normal? Does anyone know anything about this, only use clean tap water.
    After shorting out all current water seem to have charging phase again at startup, I think the spirals are more intense during this phase
    Please explain if you know anything about this!
  • Duncan
    That difference is very important I think. When i tested my 12V->230V AC-DC inverter with neon screwdriver tool it lights neone in both terminals, while when testing power grid socket only one can do it. So inverter is not grounded, right ? Do you remember Tesla patents , when all transmitters and receivers are grounded from one side and has a capacitance at second side ?[/QUOTE]
    of course I recall .. and I guess there must be a bias... but its arbitary .. as is good and bad (for instance)
  • boguslaw
    Originally posted by Duncan View Post
    QUOTE=boguslaw;164954]Still many questions remain unanswered and I also propose to test device with inverter but where is hot and neutral connection in inverter output ?
    [/QUOTE]
  • MonsieurM
    like all the little piggies we must huff and puff
    If those are the piggies of Tex Avery, I'm in
    Three Little Pigs - American WWII Propaganda - YouTube
    here is a little info about the many uses of water:
    Use of Supercritical Water Could Cut Costs for Ethanol - Technology Review
    Instead of using enzymes or acids, Renmatix employs . Under these conditions, cellulose will dissolve and very quickly break down into sugar molecules. The reactions take seconds, compared to days for some other processes. Because of the high speed of the reaction, a relatively small amount of equipment can produce a large amount of sugar, keeping capital costs down. Smaller equipment could also make it possible to distribute the production of biofuels, thereby decreasing the cost of transporting biomass.
  • Duncan
    I'm all ears and eyes
  • Slovenia
    Daemonbart Thank-You!!
    Demonbart,
    Thank you for your contributions to our thread.
    Best Regards,
    Slovenia
    Originally posted by daemonbart View Post
    Having hard to keep up with reading all the good inputs from you guys while working and testing more setups of the device
    Slovenia will recieve e-mail later tonight with information about some nice progress from todays work with the device
    He will post this info here!
    There are so many things to talk about and it takes a little time for me to write in english.
    One observation i have made is that in "resonance mode" there are four symetrical spirals in the water, i think the spiral is called "the golden spiral" I think it is a good sign
    More will come..
    Kind rgds D
  • MonsieurM
    More will come..
    Kind rgds D
  • daemonbart
    Many good inputs!
    More will come..
    Kind rgds D
  • Duncan
    QUOTE=boguslaw;164954]Still many questions remain unanswered and I also propose to test device with inverter but where is hot and neutral connection in inverter output ?[/QUOTE]
  • FOI
    Some information on inductive heating using circuits
    High Frequency Induction Heating
    This link describes circuits used to induce inductive heating. Might be some information which could be usefull.
  • daemonbart
    Sweden
    Only a little water apart
    Daemonbart,
    Are you in Europe ? I'm from Poland.
  • MonsieurM
    Have you guys thought about just keeping the same ratio....height/width , thickness/to height etc....and you have fixed ratio from which you can work with no matter what the size of the can....if harmony there is, it will exist also when you do ratios....
    by the way 72 hz if you read the previous post on harmonic math is 14.4/2
    7 1/4" == 75hz.
    7" === 74hz.
    6 7/8"== 72hz.
    6 3/4"== 71hz.
    6 9/16"==72hz.
    6 1/2" ==72hz.
    6 3/8" ==73hz.
    6 1/4" ==75hz.
    6 1/8" ==75hz.
    6" == 75hz.
    COHERENCE AT ANY LEVEL IS COHERENCE AT ALL LEVELS.
    An orderly arrangement between wave lengths establishes a connection between frequencies and fields. But for this connection to last, it must resonate to all frequencies and fields. This can only be accomplished through the resonate structure of golden mean pathways
    . a harmonic cascade effect
  • boguslaw
