  • RAMSET
    Found the Davey PDF From "DOC"
    Also I still like these guys and there Little movie
    HEATRESONATOR..HEATSTEAM RESONATOR TEST FOR HOME HEATING BOILER ..STAN MEYER STYL ... - YouTube
    Chet
  • RAMSET
    Core was the most recent
    RE: Davey
    Member "Core"
    Posted a vid here with some impressive boiling Action recently!
    We had another member from Overunity who did a very extensive replication with a very good PDF
    He spent Thousands of dollars and hundreds of hours!
    I think he has the link "Doc" something's Place" at the bottom of his posts??
    {i'll remember it ] any how He had all the aggressive instant Boiling but in the end no OU!
    I Must say this was also tried I believe By Mr.C ,who later came along with His Sonic "Tesla" version .
    Chet
  • PhysicsProf
  • MonsieurM
    Originally posted by PhysicsProf View Post
    2012 will be AWESOME... in more ways than one!
    Happy New Year Professor and All ...let's make this year; a year to remember
    Don't Worry | Playing For Change | Song Around the World - YouTube
  • PhysicsProf
    Thanks for the reply, Cherryman, very encouraging:
    Actually I tried that more or less. Putting it in a glass top open container and inside the filled bath. As suspected it boiled much sooner, giving the top layer of the bath water a very quick temperature rise. I tried out different debts, did some basic readings, but not long enough for power consumption, more a quick test to see major differences.
    The amp draw very's a lot with temp, so does the effectivity. I guess in the long run it will deliver a sweet spot for the flow-rate of new "cold" water into the system, related to that the design, (Funnel, pipe, beker etc ) or maybe a working fluid separate from the "stuff" you want to heat.
    During my bath test I got some peak wattage of over 3000...
    A cop of about 2 is very impressive for the bath; would be interested in what you get for the "glass top open container".
    Is the 3000 W for the heating in the water (output), or the input to your heater?
    Can you remind us (me) -- which DESIGN are you using here, for your heater? 220V? Any kind of FREQUENCY tuning?
    Cool video!
    Thanks!
  • PhysicsProf
    Just now, for this thread:
    Currently Active Users Viewing This Thread: 12 (1 members and 11 guests)
    The 1 member would be me, and I'm feeling outnumbered!
    Welcome, Guests! now how about contributing? just a suggestion.
  • MonsieurM
    Originally posted by provelless View Post
    Ok, now I understand what you meant by wound in opposite directions on the caduceus. I think I'll pick up some smaller wire today and start over, the wire I'm using is just to hard to work with, thanks Ken
    Excellent news Thanks again...also one more advise...you may want to make a few replicas of the set up to test out....
  • provelless
  • MonsieurM
    I thought this might interest you...
    interesting coincidence from http://www.energeticforum.com/psychi...tml#post173573 ...look at the pattern design on the snake's body
    Caduceus on a snake
    the interesting fact is that when you make a Mobius wire one side looks like the head of a snake (two oval endings, you can see it in the right side of the last pic )) ....and the other end is a an oval ending with 2 wires coming out
  • MonsieurM
    The mobius and caduceus look correctly wound...one remark ...I see the orange coil and the red coil wound in the same direction
    otherwise everything else is correct...when you get the set up running...you may switch the end that is in the tube and the end in the glass...to test which end gives you results
    If the wires are too thick...you may want to start with transformer copper wires just be careful not to scratch the insulation...
    as you can see in the image ..with the copper wires i got them to coil around a pen several times
  • provelless
    Gordon, here's a pic of my coil wound the way you said. Red wire is going into tube, orange wire going into glass (not pictured) the other ends of the wire are hooked to 220, (110 running into each wire) I'm still not getting any reaction.
    I'm not using any acid and both tube and cup are plastic. I also notice my coils are not wrapped as tight as yours, suggestions?
  • Cherryman
    PS
    Cherryman
    Ever hear of a water capacitor?? [careful which parts you dip in the Tub]
    OUCH!!
    It is and stays scary stuff.
    My protocol at the end of a test:
    - Cut power switch
    - Take socket out of wall
    - Take connections out of socket and let them touch
    - Touch the water
    And still...
  • RAMSET
    Cherryman
    OUCH!!
  • Cherryman
    LOL -- good idea to jump into the warm water!
    But you're right that over 1hour 5minutes, there will be a large heat loss from the large bath!
    Can you put your "heater" into a plastic bucket or something, and insulate the container? (E.g., bubble-wrap).
    If you imply outside the bath? Or inside the bath but partly isolated? Actually I tried that more or less. Putting it in a glass top open container and inside the filled bath. As suspected it boiled much sooner, giving the top layer of the bath water a very quick temperature rise. I tried out different debts, did some basic readings, but not long enough for power consumption, more a quick test to see major differences.
    In the past few days I did some boiling observations:
    - After the heating up and reaching boiling temp; So far I have seen three "different" boiling stages:
    1- Normal boiling, medium sized air-bubbles coming up, taking water along and causing a little stir ( Just as you see in a cooking pan)
    2- "Tiny" boiling, lots of small air bubbles coming up, creating a kind of "foam" like bubble layer, quickly dis-appearing. Top layer almost flat
    3- No visible air bubbles, but large upward water movement. Almost "aggressive" the water is coming up like large "water bubbles".
    I have to admit I have never studied boiling water before so it might be all normal. Just reporting things I see.
  • boguslaw
    Here is a crude analyse of my beer can.
    Can is not adjusted yet but here is interesting effect. Peak frequency computed by program is 52.73Hz while I see almost flat thick peak from 46 up to 53 Hz. More interesting is that peaks at 200Hz and 400Hz (well, slightly near thos values) are very sharp.
    Question for Mr "C" : how should peak at 50Hz looks like ? Thick and flat or very sharp rather ?
