Bedini Earth Light
  • plengo
    Originally posted by Allwest View Post
    Fausto,
    Reading with resistor, start 5.38 Ma, 5 minute run 1.97 Ma semi holding
    Reading without resistor, immediately disconnect resistor jumped back up to 2.86 Ma, 5 minute run time 1.98 semi holding
    Your thoughts?
    Thank you for the measurements. Yes now it makes sense to me. I think your cell is giving about 0.05volts with 2ma which is pretty much what I would expect from a dry cell. Unfortunately the internal resistance is so high that to run something makes it very difficult.
    Putting many in series will not work well, BUT, putting many in parallel with many parallel LEDS will work like a charm.
    Fausto.
  • Allwest
    Originally posted by plengo View Post
    This is great. Missing two numbers only. The amp reading with and without the resistor in series just like you did with the voltage reading, please.
    Fausto.
    Fausto,
    Your thoughts?
  • plengo
    Fausto,
    Happy Thanks Giving
    So I tried the 100 ohm resistor set for volts, it started at .59 volts and then started going up to 1.08 volts, it was still going up but very slowly after 10 min
    Then I took the resistor off and it read 1.08 and stayed for 5 min
    I then read amps without resistor an it read 14.21Ma
    So what does this tell us?
    Best of luck
    On second test (I forgot that I was shorting the cell for a couple of days) Volts beginning without resistor 1.27 volts after attaching resistor 1.27, volts removing resistor 1.27, the only thing I see different is when I test the amps after the resistor was attached and they have gone up from 5Ma to 15Ma
    Maybe I am doing something wrong? I am using a 110 ohm 1/2 watt Carbon-film resistors (RadioShack) attached to the mag screw and test the other leg of resistor with the copper
    Your thoughts?
    Best of luck
    Fausto.
  • Allwest
    Very simple. You will only need the one meter you have. Any 100 ohm resistor will be fine I think. I don't think your cell will burn a 1watts resistor in 3 seconds.
    Measure the cell just like you are doing BUT put the resistor around the screw on the top of that cell, and the other end connect to the meter just like you did.
    Measure that voltage on the meter down.
    Now, make the same measurement AGAIN but this time connect to the cell only (bypassing the resistor all together). Measure that voltage down again and post both numbers here.
    Fausto.
    Fausto,
    Happy Thanks Giving
    Best of luck
    Your thoughts?
    Best of luck
  • plengo
    Fausto,
    Maybe you can show me how to do this and type of 100 ohm load resistor I need?
    Fausto.
  • Allwest
    Hey guys,
    testing my latest cells towards dry I noticed something interesting. I can even with copper to copper produce some voltage and current using MnO2 + Alum + Epson salts.
    On Magnesium off course is a super cell but corrodes, now, if you let it dry pretty good and add ONE drop of water, enough ONLY to wet the chemical but not the Mg, it works too.
    So, controlling the amount of water on the Magnesium surface is key. I wonder if what is happening at IB's cell is indeed locked water that can not move, but only conduct.
    In my cell, I have a electrolyte (testing still) that sucks the water but does not let the Mg get wet and the power is 2 ma or more at under load 100 ohms, about .1 or .2 volts, not much but in series/parallel can light an LED pretty good.
    @Allwest,
    can you measure your cell with voltage AND current under 100 ohm load resistor? Just current could be that you have 1/2 amp but almost 0 volts, or vice-versa. So it is important to have both measured at the same time.
    In the case of Bedini's alum/Mg cell that he cells, it is clear to me that the water makes the Alum crystal grow for the little time the water is available. And that little time is very little too to corrode Mg substantially and AS the crystal grows the effect is more towards crystal grow and less towards corrosion, So, his cell will run literally forever.
    I am not trying to start a debate about water or not cell. What I CARE is that I have power for a long time. Water is essential for current, crystals are essential for voltage so lets figure this out together.
    I am working on dry cells but to get there I have to make them wet first.
    Fausto.
    Fausto,
  • vintasalo
    Double posted on accident
  • vintasalo
    Testing out an old idea with a new scope.. (SCHOOL GLUE)
    I took an old AA battery and took it apart to see how they construct their batteries. To my surprise the Cathode (-) was a nail surrounded by some sort of electrolyte buffer. I dont know what either of these two are comprised of. and the electrolyte between that and the anode was Maganese Dioxide from what it looked like.
    I took a mix I've been testing, mainly to test with the Cathode components I pulled from the battery. Made a anode casing from some copper i had lying around and the amps are pretty high so far. Its going to take some time for this cell to settle.
    Mix was: Calcium Hydroxide (Kalwasser), Barium Titanate, Potassium Chloride, Rochelle salt. (SCHOOL GLUE)
    Barium Titanate has an extremely high charge/discharge rate and you can get this as old sonar pieces off of ebay. I just ground this down using a dremel. The new eestor batteries are comprised of this component.
    Has anyone actually taken these commercial AA batteries apart? Very interesting, why dont we just use their Cathode's and Anodes and put our electrolyte mix in the battery? They spend millions to research and make these; just a thought.
    Last edited by vintasalo; 11-20-2012, 07:20 PM. Reason: Had to add component School glue
  • plengo
    Hey guys,
    @Allwest,
    Fausto.
  • Allwest
    Originally posted by ibpointless2 View Post
    Yes I'm still around and still working on my cells.
    "It was brought to my attention that the Crystal glue cell could be making magnesium chloride. Magnesium chloride absorbs water from the air like crazy. So if its making magnesium chloride that its nothing more than a water battery. So I ran some test that can not confirm that its pulling water from the air and thus is the reason why it works. I've made a table salt and Epsom salt glue cell and it has the same opportunities to make magnesium chloride but it does not and it dies off. Also physical appearance of the crystal glue cell to the magnesium chloride cell shows that the crystal glue cell rock hard while the magnesium chloride cell is wet and gooey. If the crystal glue cell was pulling water from the air than the glue would never dry and it would remain wet looking like the magnesium chloride and glue cell. It can not be confirmed that the crystal glue cell is a water battery."
    Video.... Is The Magnesium Chloride the Reason why the Crystal Glue Cell works - YouTube
    Here is the data...... https://docs.google.com/spreadsheet/...TN2Q2pfWjVKZVE
    IB,
    I don't know if you have seen my last video, but this is the oldest cell I have continued to work with
    It is a dry cell and still has power and the volts just keep going up
    It is sitting around 1.5 Ma, no matter what I do to it, it also gains Ma when I short the cell, but when I did my test it almost hit a 1/2 amp
    I have several theories and I was wondering if you could help prove a piece of the theory
    You have a cell that is a copper pipe wrapped in mag ribbon
    If you could do a test as a base line volts and amps
    Take the tape off the end of the pipe and put ice down the tube, then blow the outside with a hair dryer, if my theory is right then you will have massive gain in power, we are making a form of a thermal electric generator
    But there is a twist to this, which leads to the next test after this if this proves right
    PS, make sure you do not get the mag wet or this will not work, the cell needs to be dry
    Another PS, If this does not work, you may want to try hot water in copper pipe and cold on the Mag
    Best of luck
  • ibpointless2
    Originally posted by CrystalDipoleMatrix View Post
    I have a question for you IB: I've made your crystal glue cell and yes the voltage is steady but as soon as I load it, the current jump back up but then it runs down to almost nothing (it takes a long time to do it). Maybe it's the wrong kind of glue? The glue becomes transparent when it dries and is non-toxic. It's all purpose white glue but not the elmers brand. I have some elmers wood glue too but I think it contains some nasty chemicals to make it bonds to the wood more easily. I just made a simple test: I cut between the copper and aluminium strips to separate them and I placed the copper over the aluminium to see if I have a ''skin effect'' like in your videos and....Nothing...Strange! Why??
    The glue itself has nothing to do with why the cell works. Its the water in the glue that is key. The water in the glue allows the salt sub and Epsom salt to mix into something else. When the glue dries the water is being evaporated from it so the glue becomes hard. When the water evaporates the "something else" that is created is what allows the cells to keep working without having to add water to it. The skin effect is why my 5 foot tall, 6 inch, and 2 foot crystal copper tube cells work. Same ingredients (salt sub and Epsom salt) but glue is not used. The Glue is merely a support and has no real purpose other than to act as a support. The key point is that water is needed to mix the two salts into one salt, and when the water evaporates the cell still works. When other cells dry out they stop working but my cells keep going.
    I'm still searching for the "Why" it works and I thought it could have been Magnesium chloride was the reason but testing showed that it can't be confirmed. So far its still unknown why my cells work.
  • CrystalDipoleMatrix
    I will make another cell with the elmers wood glue to see if it's the chemicals in the elmers brand that changes everything.
    Crystal glue cell under load
  • ibpointless2
    Yeah IB, your the best! Your crystal glue cell rocks! Just don't know why they keep on working for so long. I quit on working on bedini's cells because they need water and corode away but yours with aluminium and copper, wow! We need to know why this is working but we all know, in the micro-amp range..
