What John said made some sense to me. If you use two wires that are the same dimensions in diameter and length and then they are the same "matter" either both copper or both iron, you have two like potentials sitting at the same inflow/outflow. (these inflow/outflows exist in ratio in all matter and are the unseen/unsensed flows that maintain this creation we live in, as it is)
The model is a point sphere model... however in a wire its extrapolated out a bit differently. The wire itself is a series of points connected to form a line which has an axis and which has a mid point halfway between either end. When this conductor is wound into an inductor, the mid-point shifts and becomes a plane of division at the middle of the coil, usually halfway between the top and bottom of the coil.
Copper has some ratio of inflow to outflow... This is what sets up the ambient balanced fields that sustain the copper in the form that its been refined into... that of a wire.
Iron also has some ratio of inflow to outflow... Which is different, necessarily, from the copper wire (or it would be percieved as the same element.)
One is more densely magnetic... the iron wire is ferromagnetic given its ability to sync more flux than it has at ambient while the copper wire which is more paramagnetic (less magneticly affected) has less ability to sync additional flux.
All Magnetic fields are PURE CURRENT fields. The matter emitting the magnetic field is where the voltage potential lies locked in the lattice and sustaining the divided flows of polar current.
I say all that to get to the point of noting that this would be why two copper wires of the same length but of a different diameter *might* be able to work like the lasersaber setup. The deltas are far more noticeable and probably usable between copper and iron however.
One other clarification, the less humid it is, the better charge is able to accumulate. Humidity allows the charge to bleed off while the more dry it is allows the charge to be pegged in place. (at least thats my understanding.) Thats based on reading the plauson and other "electricity from air" type patents. Seemed they always got best charge in the winter versus the humid summer.
Good stuff.
Take care,
Gene
Originally posted by Les_K
