  • BrentA929
    Bedini GT3
    Brent,
    This is what I'm measuring with my analog meter. I asked Rick and he said the same thing as I got charged for 4 buckets of wire. My LCR meter will be done tomorrow as it is way off for some reason. Please when you do this add a little extra wire just incase I have mad an error also. I want to see your machine running and everything will change after that for the better.
    Excellent work with the drawings this is the way it looks on mine. I will make all the measurements over again just to be on the safe side. make the side coils adjustable so you can move them if need be as that is what I had to do, you will see that the magnetic fields are big. try not to exceed when it is running over 20 RMP's
    Now back for now to my other work on Stubblefield.
    John B
    John B,
    Thank you SO much for your patience with me through all of this!!!
    I can't take any credit for the drawings...Scott (txaggie00) has done all of our drawings and CAD work. He has done an amazing job!
    Looking forward to the next phase!
    Thanks again, Brent
  • John_Bedini
    Bedini GT3
    Brent,
    John B
  • BrentA929
    ____________Center__________Slave
    10.2 ohms_______4.0 ohms________10.2 ohms___=______________Power__________Control_________Control
    12 ohms_________12 ohms________24 ohms_________24 ohms___=___
  • BrentA929
    Bedini GT3
    Brent,
    It looks as in talking to Chuck here as you face the machine in your drawing That my left coil is off to the left by one inch as this machine was tuned as we rotated it. Can you keep your core at 3" my core length is exactly 11 X 10 inches top flange. Side core is 5 inches in length Top Flange 10 inches.
    It looks as if you have the correct space to mount the coils. Gary says the weight is 205 pounds center coil with core. The coil is filled within 1/2 inch to the outer flange. Four wires wound together but not twisted. Can you match my coil impedance in DCR and also on the side coils or get as close as you can?
    John B
    John B,
    The drawing does not show any offset yet...
    Yes, we can make our core 3" in diameter and we can also make the center spool longer to match your 11". The side spools will remain at the 5" and we will update our drawings to reflect this. Give us an hour or so and we will post them.
    My question is does the iron flaps look ok from a geometry standpoint?
    Also, I will check and see how close we can get with the wire we got. We purchased (2) 84 lb. spools of #15 and (1) 48 lb. spool of #18.
    Thanks, Brent
  • John_Bedini
    Bedini GT3
    Brent,
    John B
  • BrentA929
    Bedini GT3
    John B,
    I am assuming this was for me...
    Yes, that is where I got it. You mentioned 12.2 ohms and then Jeremy calculated the 3 coils from that figure. There was another post that you mentioned 12.6 which was then updated by Jeremy to reflect this new value. Obviously, these are incorrect based on your previous measurements.
    Brent
    Right now, my figures show...
    61ohms for the Main Base Coil and
    30.5ohms for the conjugate asymmetrical side coils.
    This will equal the 12.2 ohm total in parallel.
    The side coils are opposed pulsing a weaker south pole to create attraction, while the Main center coil is creating a huge repulsed north field when switch goes on. Very interesting non-linear arrangement to say the least. I do know there is more to learn here.
    POST #20
    At this point I see the half bipolar bedini/cole circuit as the switch across conjugate coils in parallel. The switch sees this as a resistive load and non-inductive when on, but yet you are able to collect the collapsing magnet reactive impulse after disengaged.
    I was looking at your Adams motor arrangement. Using the concept of your half bipolar bedini/cole circuit, I made some slight adjustments. Again, I am only learning here, but I see this as a method for switching the non-linear fields. Schematic parts will of course change accordingly.
    We are all very inspired to test and learn here. Thank you so much!
    Jeremy Burnum
    Yes I see that, Thank you is this where you got the information?
  • John_Bedini
    Bedini GT3
    POST #20
    Jeremy Burnum
  • John_Bedini
    Bedini GT3
    LaserSaber and All,
    The coil I made for test.
    I took a welding rod core as I have always done 6 Inches long. I took zinc coated iron wire Red Brand #17 Gauge. I very carefully wound by hand the same way you did. I spaced the wire by hand to make sure that one Iron wire did not touch the other taped them in place then put a layer gauze over the top and repeated the process to the end. I did not wet anything. It was 1500 turns I could see the effect and that was all I was looking for at this time.
    I have seen something else now and I will test it soon. I have seen things in the past done by other people but you can not always replicate them. It's now not important to me to try and replicate as the energy is a brush effect which is in everything. Logic says that just two different things will do this effect no matter what they may be. Reich call it Orgone Energy it's the charge around things and each thing has it's own charge. The difference is, can you build a device to collect it, as it is a very strange form of energy more like a fluid that is in a gas.
    Your battery is already done in living things, but your not going to plant electrodes into yourself.
    Now most materials are very costly to do this work but You have my attention, sorry for that. I say that you can take your energy from anything to drive that motor you have made, let's just say you drive two metals in a tree Iron and Magnesium the motor would run with any coil of high impedance. I live near old telegraph stations as I'm basically a jump from the forest where old mining towns are hidden but I need permission to go into them which I have. I have seen the telegraph equipment with dead batteries still working and nobody at the other end but the power is still there, so this energy to work needs very High Impedance to manifest itself into a working system.
    The motor your showing with cylinder turning at the ends of a coil is what is termed as a Zero Force Motor if you would turn the rotor the other direction and ride the magnetic streams you would get a much better effect and the motor would be much faster as you then would have canceled Lenz's law and it can't generate anything. You must be very careful in using Neo magnets as Copper is very magnetic under that condition, The neo magnet and the spacing is very critical because it will saturate the core, that has happened to you with the soft iron.
    The reed switch is also important as it will eventually get magnetized and quit working.
    I would almost bet that two pieces of Iron Pyrite will make the best battery for this motor. Don't look for allot of voltage it's just the magnetic current and the effect your looking for.
    The real trick here is the energy that is developed from the pumping action of the coil and then can you tap it to charge batteries or something like that, then you can do useful work.
    I say it can be done.
    The Electromagnetic coil, What is it? this is the way I look at it, this device is an energy pump the same way the air compressor works. The electromagnetic coil works this way because it can very the Bloch wall to full open or full closed so the energy is sucked in at 90 degrees and compressed. This energy surrounds everything in a scattered form, vectors pointing in every direction call it dark energy or the Aether, or negative energy total potential. I presented this paper to two universities in Quantum mechanics and they said they could not teach this as they would loose their funding. Back EMF what is it, it's not what everybody thinks as it really only applies to DC motors and if understood you would find that it is always lower then the applied input voltage.
    The spike is the Aether it's the differential between the back EMF and the negative energy. It will burn out anything in semiconductors if let loose. So what charges the battery is the spike as it causes a high potential on the Ions and they move, the battery develops it's own currents inside to charge. Imagine a coil as a pump that we can catch things with then you must transform it to use it. The Mono Pole Motor is one way to do this with a diode and if not that a bridge with a capacitor. If you look at the Mono Pole Motor you see the windings all the same so it is an one to one transformer all the same number of turns, no high voltage winding.( The negative Energy is what gives the high voltage with the pumping)
    The Magnetic Tap ( again using the Bloch Wall), you could do the same thing with a barium magnet insulating a piece of steel on both sides and it will produce magnetic current, Zinc is the Key here as it deflects the magnetic current. Two rods in the ground or two metal plates in your creak with the water passing through them will also do the same thing.
    The Stubblefield coil, Your hook up if the coil was in the ground with a carbon button microphone would allow you to transmit all over your property with your wife and the kids as a telephone system never needing any power ( Free energy at it's best with ground currents supplied by the earth ) I have spent years with Peter L doing Stubblefield experiments so there is not much I have not seen or done with this system, if it's free you can't charge for it.
    But the term is wrong as it does not fit with the science community, as they charge for everything even when their wrong.
    LaserSaber you have done excellent work with your experiments, you have let loose a Wild Dragon and everybody should thank you as I do for proving things I have been saying for years.
    John B
  • BrentA929
    Trying to understand
    Originally posted by Ron Chase View Post
    Hi Brent,
    Great job designing and assembling your wheel! Here are some thoughts concerning the power and control wires.
    If you consider only the #15 power wires in the three coils the math appears to work out OK for parallel impedance (resistors) if we have 31.5 ohm slave coils and a 63 ohm master coil (two #15 wires in series) with the total impedance of all coils in parallel being 12.6 ohms.
    Using the basic calculation for two parallel impedances we find:
    R1 = 63 ohms (center coil)
    R2 = 15.75 ohms (two 31.5 ohm slave coils in parallel reduce to 15.75 ohms)
    ----------R1 x R2-----63 x 15.75----992.25
    R total = ________ = __________ = _______ = 12.6 ohms
    ----------R1 + R2-----63 + 15.75----78.75
    Calculating for the weight of the power wires with the information JB has given us also works out as long as you don't include the control wires.
    JB said the three coils are hooked up in parallel but does that include the two #18 control wires? If so then it becomes quite difficult as you know to reconcile the numbers using the impedances we have been given. So what do we do with the two #18 "control"wires?
    Review of the magamp articles found in this thread indicate three ways to saturate the core of our center coil to initiate an amplifying effect:
    1. Close proximity of a magnetic field to the core. Outer wheel magnets.
    2. Short the ends of the #15 control wires together.
    3. Apply a DC voltage to to the control wires.
    To create the amplifying effect of the above functions one could wind the two #18 control wires around the center coil core (in parallel or series) and short the ends together. The two #15 power wires in series would then be wound on top of the control wires.
    This configuration may or may not be how JB constructed his coils but it does seem one way of reconciling the numbers.
    Best Regards, Ron
    Ron,
    Thanks for your input...
    I think what your saying makes sense! Just trying to wrap my head around all the numbers so we can wind all of our coils. (the right way)
    Thanks, Brent
  • BrentA929
    Measurements
    John B,
    Thanks for the measurements...
    Let me be with these for a while to let them sink in!
    Brent
    Brent,
    Hope this Helps this is as close as I could get. The coils are so big that everything interferes with them even a set of keys in your pocket changes them. Just the AC magnetic fields also change the measurements with the LCR Meter.
    And by no means I'm a master at anything as I put my pants on the same way you do.
    I was bitten by this bug a long time ago and have never rested in my relentless search for this energy. Your all bitten by this bug too.
    But here are the numbers
    Big Coil
    DCR= 4 Ohms
    L@ 1K= 861.5
    L@120Hz = 1.126
    R@ 1Khz= 27.23
    R@120Hz= 4.752
    Henrys 1.126
    All with Iron core in place 3 inches in diameter
    Side Coils
    Best measurement I can do because of interference with LCR meter
    DCR=10.2 Ohms
    Total all inductors together
    DCR 2.2 Ohms.
    I must take the machine apart to do this much better and I'm not going to do that as this is a working machine.
    I'm going to send this meter for test as I don't know if I can believe it and I will do this again.
    I would believe my analog meter before I believe any of this digital stuff at this point. and DCR should give the answer. The Bedini/Cole Switch works best at 2 to 30 Ohms.
    So I will be back with more measurements after the meter is tested.
    John B
  • BrentA929
    Bedini GT3 "Junior"
    John B,
    Thank you for your willingness to help!!!
    Brent,
    I can see what your trying to figure but I do not think I used that much wire That would be one big coil and I could not lift that. where did Jeremy post that? .
    Jeremy took the figures you gave us in Post #20 and ran the numbers and displayed them in post #30 (His drawing in this post shows 30.5, 61, and 30.5 ohms for the three coils, but later updates it to 31.5, 63, and 31.5 based on your post #42)
    Our wheel diameter is 6 feet and weighs 87 pounds (see attached Wheel Dimensions.pdf). We have laid out a possible spool arrangement in AutoCAD and attached it as Coil Closeup.pdf. We have not nailed down our spool sizes yet. We were waiting till we were confident in the setup of the windings. The diagram shows 10.5" (flange diameter) spools with 3.5" barrels. We have the ability to specify the lengths of the barrels, but have randomly chosen 10" for the center and 5" for the slaves. Those can change and can even be the smaller 6.5" (flange diameter) spools with a 2.5" barrel. I think the geometry matters and we can definitely make the necessary adjustments.
    Your machine is going to be much different as you have scaled it down. what is the actual size of the machine? Mine is sixteen feet high. The wheel is almost 12 feet . The next question I have for you is, from the baseboard to the magnets how many inches do you have as I can see I must figure out your coil and the side coils.
    I see that you have the copper so that is not the problem. The core I think is 3 inches across on all the coils but your machine is scaled down. So give me some figures here as your coils will not match mine at all. Also the bottom of my coils the core is at least 3 inches into the base on all of them and are you going to put the Iron shield in? so give me some measurements here so it will come out right. I will do all this but I do not think you have the space.
    John B
    You should be able to see all the measurements in the attachments. We were thinking about 2" cores, but would love your input...
    Thanks, Brent
  • genessc
    Hi Les,
    Yeah thats one way to look at it I suppose.
    Those ideas of poynting and heaviside had to do with whats in the wire and whats outside the wire when an applied potential is applied to the wire from some "source".
    Not so much the pre-existent fields that sustain matter that is perceivable to our senses. These fields are there on/in the wire without any other "source" attached. They ARE the wire. The visible sensed part of the wire is the part cohered to be sensed by our senses. It has a constant instreaming and outstreaming of current to maintain its state.
    Its this "natural state" of the wire that is different between an Iron and a Copper conductor of the same length and diameter. Its this current field delta between the two wires being put in local relation via the shorting as shown by lasersaber that is acting on the compass in the lasersaber video.
    Matter is, because of a potential aka voltage which sustains the current inflow/outflow at the right rate to sustain the *thing* in its current state, which then changes at a rate commiserate with the evolution of time on the relative planet. Growing a crystal takes time... wood breaking down takes time. Most of natures processes are not instant.
    Our devices aren't able to measure the ambient truths tho there is a book by Manly p. Hall on "The dual theories of conductivity in metals" that sorta talks about Peltier effect and other similar effects of putting dissimilar metals in direct local relation to each other. It might be helpful if you've not browsed it before although its got a good bit of math in it. I'm not much of a mathie.
    This is what makes sense to me at my current place in learning. It seems the stubblefield methods took advantage of these pre-existent fields which Are simply by the fact that the Wire is.
    What seems to be lacking is what angular phase relationship has to be produced to generate the largest effect? The precision wound coil in lasersabers video gives a good starting point. I wonder if its the layers of alternation that let the effect become more significant?
    Anyways thats how I see it. (hopefully its helpful)
    John B,
    You say a trifilar stator with 1 wire iron could potentially be made self running yeah? Which wire is the Iron wire? The trigger, the Power? Or is that the feedback winding which would then be the 3rd winding? (rather than the typical collector winding as the 3rd winding?)
    I know the hardware store has plastic covered iron wire or steel wire... wonder if that would work for this purpose. Or if bailing wire is the best way to go.
    I'm also still planning to make a Solid State SG (not via the resistance from collector to base) but rather using your suggestion to replace the rotor with a coil and a sine. I'm curious to see how that lets the SG circuit work. Hopefully I'll get to that before to much longer.
    Take care guys,
    Gene
    Originally posted by Les_K View Post
    genessc,
    Thanks, I think you just explained poynting and heavyside. Well, back to the shop....
    Les
  • Les_K
    genessc,
    Les
  • John_Bedini
    BediniGT3
    Brent,
    Big Coil
    DCR= 4 Ohms
    L@ 1K= 861.5
    L@120Hz = 1.126
    R@ 1Khz= 27.23
    R@120Hz= 4.752
    Henrys 1.126
    Side Coils
    DCR=10.2 Ohms
    DCR 2.2 Ohms.
    John B
  • Ron Chase
    Center and Slave Coils
    Hi Brent,
    Best Regards, Ron
