Hello Dave,
Meanwhile I tried another BiTT with my Royer generator. This Bitt has 2 ferrite toroidals with permeability 10000 & 2000. The toroidals are overlaped, not connected side by side as in the previous BiTT. I apply the drawing. The result is the same one - there is no OU...
Sadly. Theoretically it must work, do not understand where my mistake is.
Alex
Hello Dave,
Thanks for the scheme you sent. I do not understand exactly how it works and where the output of energy is. Does it use the energy of the magnet?
The magnet should stop the bemf by resisting change in the magnetic field, carrying energy on into the capacitors, I havent built this yet still studying, but it should work, Im not asking anyone to build it, just putting some idea's out there.
Hello Dave,
Hey Alex
My circuit probably will not work, Im throwing an idea around in my head I have been playing around with for awhile.
I have been playing with the zvs and your circuit is a version I found interesting.
MrClean in the Don Smith thread played with the bitoroid, if you go back a few pages you will find his work on the subject, I would encourage you to look at his work.
Try everything you can think of, you may find the answer
Hope you dont mind I played with your circuit a little, your primary's should be on the center leg
I have no idea if this will work or not, not sure if two batteries can even be used this way,
Hallo Dave45,
Thanks for your response, so as I do not have anybody to discuss of the subject. I could try to experiment your proposal, but have questions. Do you mean that transistors (and coils L1 & L2) are working simultaneously or like in a traditional Royer generator ? Why 2 separate batteries are using, what is the target?
By the way, in the Mr. Thane Heins's patent I did not find any mentioning on any special coil wiring...
Alex
Thanks a lot for the references. I shall follow them.
One question I ' d like to ask you. I use a square - wave voltage, applied to the Primary (Royer generator). As I understand BITT is functioning with a sine shape voltage. What is your mind concerning square - wave voltage which was used? Is it possible or a sine - wave voltage only?
Alex
Without reading your PDF, i would say your mistake is in not following the exact method of the inventor who made the device you admire.
If you want to replicate something, you should follow the design as closely as possible.
All the best,
Hello Qvision,
Thanks a lot for your fast response. Probably you are quite right that I "not following the exact method of the inventor ". The problem is that I have read some articles devoted the invention, they did not include any special data, practical recommendations...
Could you please, point out or send the practical information which helps for replication?
Very best regards,
Alex
