Originally posted by ibpointless2
Captret - Perpetual Light with Dead Batteries
Captret - Where is it going?
Hey Jbig, ibpointless and all,
This is a pdf for real usable power Capacitor that the Energy fairy dropped off @ my inbox.
Seriously, what is the potential of the captret?,
What we need is COMBINED efforts in developing real usable FREE ENERGY devise that will be self sustained and fulfill all of our energy needs.
We need an organized drive, open source platform where everyone can contribute and we can all move forward and make a difference in the world.
From what that I have learned with the captret, it's just another toy. But isn't that what you all have been playing with for the past 20+ years in the Free Energy community. What have the Leaders provided other than toys to generate only enough output to drive LEDs.
I say, let's organize. Lets develop an Open Universal Platform where all of our energies can be effectively directed at solving all of our energy needs. Each of us have so many unique talents. UNITED we stand tall, divided we will be suppressed.
Let's agree on One devise, allocate our resources to each component, build, test, improve and combine our learned knowledge in building a devise that will be Self Sustained and produce copious amount of Free Energy!
For the love of Humanity, let's take back what Tesla had intended for Mankind. Freedom and Free Energy.
Unlike a normal capacitor where it has a limit of how much it can charge up to the captret doesn't. Where a normal capacitor will only fill up to the voltage of the battery a captret will exceed that.
I hooked up a battery negative to the case of a capacitor, then the positive to the positive of the capacitor. Then i measure positive to the negative of capacitor and the voltage is higher than whats in the battery. How can that be, where is this extra energy coming from? And the voltage just keeps going up, don't know when it will stop but i'll let it run.
I'll post a video of what i mean on youtube in a few minutes.
I'' have to check yours out...
I need about a day to check yours out. We are very busy atm. My mom is coming up from Florida on Sunday. She is up for the Holiday and family is very high on my priority list right now.Originally posted by Joit View PostLeft one is what i did, right one should be yours.
Btw At your Picture what are this waves where your arrow point to before the pot,
another resistor or the waveform?
Right now i can run a LED and keep the Voltage pretty stable with the pot at ~6-7k
Is'nt a LED actually a thin Wire inside what make the Light at a p-n junction?
I did read somewhere something like this.
But oh well, i did not do a long run test for it now.
The squiggles is actually a resistor that is set. Like a 1k to limit the maximum current to simulate a leakage that would be present in the Electrolytic cap while using the Captret method. The pot is to adjust the minimum current allowed to leak. I made this to explore the adjustment of resistance and how that affects the signal I am seeing.
Also I am thinking that paralleling more ceramic caps would strengthen the oscillation that is happening because of the leakage. It might be that we could also put the same setup on the right of the circuit as well to simulate the leakage from the other plate as well. I am not sure about that yet. It just might pull more real current from the battery and I think all we want the right ceramic cap is to use as a rebounding container.
Leds are a funny thing. Actually the highest current they will pass is on startup or conduction. After this happens they will stay open just from the flow of voltage across the junction. Thats why we will see the current ping high then drop off with the added caps filling up to operating level. Like I said earlier I think this signal is auto tuned to the battery or source and to the load as well. The whole circuit becomes balanced and will charge the battery from the mere presents of the low level flow and amplitude that this method provides.
We conduct or allows a small amount of flow and that flow has inertia. This sets the battery in a slow leak mode draining a small potential and then sloshing it around on the ceramic caps. This feeds back via the negative plate and across the positive plate causing a vacuum to form and flow increases exponentially. Once the flow is started the caps piggyback a signal into the battery at it's resonance frequency that is formed by the caps and battery.
Right now I am trying to figurew out the relationship with the resistors that are now operating as a flow valve for the leakage we are providing. I need to get some more parts from the store before I can go further. A grab bag of ceramic caps and some good ranged variable resistors (pots) plus some resistors..
If I'm gonna do this I might as well start with known good parts.
Like I said I'll look at your circuit in a day or so and let you know if the signal is present with your circuit.
By the way the new setup or design is working flawlessly... I haven't gotten a loss in voltage but I have not gained any either. It was mentioned that old parts and sloppy connections could be the case for the bad results on the charging effect as of yet. Of course I'm not running the led hard either it is only dimly lit because of the high resistor I had to use at 322k ohms. I'm gonna go with the set resistor and the variable add on to have a base limit on the leakage. This could also make it easier to use on multiple voltages or raise the range of higher voltages. I'll have to see when I get to that point.Last edited by Jbignes5; 11-19-2010, 03:33 PM.
Captrets without batteries...
I checked out CosmicGnarler's captret vid. I posted a comment similar to the following I thought you all might want to know:
Great results! Do this experiment for a few days. I did one which showed voltage increasing, decreasing, etc. until it stabilized. Like water sloshing back and forth in a tub. One you can try is connecting captrets together (without a battery) in series (both legs of one cap touching the head of the next cap, and so on). Enough of them will power an LED which drains power. Remove the LED and power goes up. Caps are pos or neg biased. Test them and use one or the other, not both.
You test them by placing a test lead on the head of the cap and the other lead on the legs of the cap (which are twisted together). The voltage is either positive or negative.
I had trouble doing this because I couldn't find an easy way to connect the caps together. When I managed to do so the voltage would increase for every cap I added. I was thinking I could bend the legs of the cap in such a fashion that I could drop them in a tube or straw so the legs are touching the head of the next cap... To really check this out I was going to get a bag of caps from a surplus electronics store and just make a really large array of caps.
On the downside... when I put a load on the array the voltage would drain... but after a while it goes back up again. I know that caps tend to collect residual voltage when they sit for a while... Perhaps this is just a way to harvest that voltage...
Best,
Anonymussle.
Left one is what i did, right one should be yours.Originally posted by Jbignes5 View PostI need to see your mods of this to better understand what you are talking about.
Dear hemancro,
Please protect yourself and your family with some EMF sheilding. There are thousands of reports of families and animals going insane and getting sick from such power lines. Trouble going to sleep, trouble healing from diseases, trouble thinking... Please...
A web site like this one can help you. EMF Safety Superstore- "Electromagnetic Field Detection & Protection". I have 2 of their sheilded caps. I wear them when I go under high tension lines. (Yes a tin foil hat that actually works.) Research "Faraday cage" and either get some of the sheilded fabric or make your own cage. (Then you can take power from it!)
Anyway. I would advise that your "Antenna" look natural. Like a shed or a wind vane or something... Because the power company could sue you for theft which is insane. You should sue them for health problems.
I would be careful...
Yes it would make an interesting test but in most cases they can go after you for "Stealing" the product they are selling. It doesn't make sense but they think they own the air as well apparently. Like I said it would make an interesting test but don't plan on making that part of the circuit.Originally posted by hemancro View Posthi guys. is it posible to charge supercapacitor instead of battery with captret?
also, im liveing near electric pole. im not sure how high voltage is but im sure its more than 15000V. if i connect 1 wire to earth and 1 10x10cm metal plate 2 metre of the ground i get AC voltage. highest is 50 VAC. i was thinking to convert that to DC and drive captret without battery.
what you guys think?
Can you post the diagram?
I need to see your mods of this to better understand what you are talking about.Originally posted by Joit View PostIt seems for me it even works with one 103 Cap and the Led
directly connected to Plus to keep the Voltage at the Batterie.
My 10k pot is anywhere at 6k ohm adjusted.
+..9V..'-' >pot - ...unpoled Cap
+ Led - ............ unpoled Cap
Excellent...
Do not worry about not having the right parts for now. We need to test all different setups. Mine ran all night without loosing a bit of voltage so I think this is a success.Originally posted by automan View Post@Jbig
I don't have the correct value parts ATM but I will try to get it sorted correctly this weekend. I am trying a 470uf 200v as was used in my first captret video, along with 2 small ceramic bead caps (too small markings to read) a 100k pot and a junk ups battery. Starting volts is .48 @ 8:06pm est and is steady for a few minutes now. We shall see. Keep up the good work and testing.
The one thing I am thinking about is that this system has the diode built in via the Electrolytic cap. The two caps on the top are ac capable caps and this is where the magic is. When the Electrolytic fills up it acts like a drum. The caps on the top are the drum sticks. It seems to me that this is an open resonant system that matches whatever load or battery is connected to it. It is capable of multiple resonant frequencies and that corresponds to Tesla's theories as well about being able to setup multiple oscillations from a starting pulse. It takes a bit to gently coax these oscillations to be powerfull enough to, from the reports about Tesla's experiment, to shake down a building just by attaching this system to a part of that buildings conductive structure.
I believe from trying to understand the flow that this system tunes itself depending on what you have connected as the source and load.
We need to start focusing on what is happening in the flow structure of these potentials in this system. Once we fully understand the mechanism behind this system then we can apply it to being capable of moving mountains if we wished.
It seems for me it even works with one 103 Cap and the LedOriginally posted by Jbignes5 View PostI think I have duplicated the effect not using the "Captret" but I need someone else to help me with it to test it out.
The 2 dead 9 volt batteries that i took off the captret charger where at 17.31 yesterday and now they're up to 17.32 today. So the charging still lives on without being hooked up to the circuit.
IB,
thanks for removing the battery and letting it sit... Great news that it didnt drop while sitting..and is in fact continuing to climb
