  • DavidE
    "toilet coils"
  • nat1971a
    @gauss
    that last capacitor in grays circuit going back to the charging battery could be a smoke screen.....
    could be that the conversion tube is connected to a spark gap going back to the battery..
  • nat1971a
    am starting to wonder whether the metal case of the ac fan is also acting like a cylinder which is being radiated and sparking back to the battery
  • nat1971a
    the toilet rolls are similar....i wouldnt say identical.....as i slapped them together pretty fast and messy....
    inner layer is aluminum foil
    next outer layer is toilet roll
    next outer layer is aluminum foil
    then outer layer is electrical tape
    on the receiver circuit.....there was only 3 or 4 turns of the wire (leading from the ignition coil) wrapped around the conversion tube which then leads to the sphere....
    the thing that makes the difference is the sparking back to the battery bank that was outside....
  • nat1971a
    Thanks all....amazing what you stumble into having a messy bench........
    anyway heres the circuit....
  • Bodkins
    thought i would mention that it works best at night...so you probably want to start testing at night first....to see the results...then experiment from there......obviously needs a lot more testing etc......and was at 36volts
    @lidmotor ...thanks for the info.
    @bodkins.....cant wait for your replication
    did you notice the difference in the sound of the circuit?
    Sound like the frequency has gone really high which is a good thing!!!!
    I only have one ignition coil so Braden sending me two of his. my spheres are smaller but should fine. How many turns on the toilet roll coils and are they the same.
    Well Done Nat
  • nat1971a
    i will draw it up exactly the way it is now.....ac fan and unrelated battery bank and all......bizarre.....
  • Guest
    Guest replied
    Good job!
    So can you post the final wiring diagram ow will you need a few more days to experiment?
    About the battery it is really interesting what you say since I read that Gray and his engineers were arguing about the last capacitor to the charging battery, whether it was needed or not. And what is a battery really, anyone has something to share about what a battery really is? Dielectric constant, magnetic field etc? Something makes it attractive to the cold current, we need to figure out exactly what it is.
    damn....it pays to have a messy work bench.......
    i tidied up today thinking i was on the home trail....and what do you know....the effect was very diminished...
    i carefully reassembled the bench exactly the way it was after rewatching my videos i took.....and what do you know.......it was somehow sparking back via an ac fan that wasnt connected to anything to some wires leading back to a battery bank that wasnt connected to anything via the receiver circuit.....
    so in summary the spark back to a battery is necessary for the aether gas effect to fully realise....grays circuit must be followed folks.
  • Guest
    Guest replied
    Yeah and how about the imminent ice age: Terracycles
    I found this video showing someone else doing similar research. We are not alone. Makes me wonder about how many other people in high places know about this stuff and are keeping the technology surpressed.
    YouTube - solar powered tesla coil
    Lidmotor
  • nat1971a
  • nat1971a
  • nat1971a
    grays circuit is starting to make sense he had 3 cylinders operating at different phases to run an ac motor!!!
  • Lidmotor
    Wireless energy transmission
    Lidmotor
  • Bodkins
    Well done nat i need another week to be up to speed
  • nat1971a
    YouTube - TESLA'S RADIANT ENERGY WIRELESS TRANSMISSION - UPDATE 13
    how to produce aether gas!!!
