  • Allcanadian
    Hmm? Imhoteps relay charger looks familiar, this circuit was built 6 months ago at OU.com in "The Tesla Project" thread using a relay as the inductance and switching mechanism. As well this circuit is what is refered to as a DC/DC Buck converter, DC/DC step up converter or switch mode converter----and your computer power supply uses exactly the same circuit minus the second charge battery. As well in the Tesla thread we powered DC motors added to the relay inductance and used the inductive discharge to power neons and flourescent bulbs.
    And the old becomes new again.
    AC
  • Lidmotor
    Neon, cap, battery charging
    Originally posted by Bodkins View Post
    How do charge a battery with the neon lid ? this was not in my setup.
    all i do is discharge the cap!!!!!!!!!!!!!!!!!!
    thank you Gauss
    will look into to it
    nice one nat looks like your follow your your own path to find results.
    Bodkins,
    Remember? I had that same problem awhile back until I used a half dead battery or super caps to let the the cap discharge into. There is evidently little or no amperage here so if you don't create a sort of vacume for the energy, it will not go into the battery. I think that the blinking neon in my cirtcuit holds the voltage at a certain level and as long as it is higher than than the battery voltage by enough volts,and the battery wants to be charged, then charging will take place. It is not just a fluff charge either because it will run those little Christmas LEDs that I showed.
    Lidmotor
  • theremart
    Very clean
    Originally posted by Agongon View Post
    Here's my interpretation. Open for correction. As usual, my gratitude to Imhotep and to everyone here.
    87a terminal of the relay is Normally Close [ N.C.] contact. 87 is Normally Open [ N.O. ]
    But... the wire from inside the case which I think you labled 87a should ONLY goto primary battery neg. you have it connected to another branch. ( I looked again at your schematic it is not connected no dot ) but someone might think it is connected, I would run it with a curve symbol showing the two do not combine.
    I would not use 87a as a label but rather use wire added inside or something like that,
    Nice schematic!
  • Agongon
    Imhotep Relay Charger Schematic Diagram
    Here's my interpretation. Open for correction. As usual, my gratitude to Imhotep and to everyone here. The relay in the diagram is a 5-pin Bosch 12vdc relay.
    Additional info:--> YouTube - Free Energy How-to Single Relay Radiant Charger
    To watch the video clearly, add this in the url--> &fmt=18
    5-pin Bosch 12vdc relay--> Lighting
  • byjoveoldchap
    Hey,
    Thanks Imhotep for the new toy. It really works neat. I modified the relay so it would oscillate a simple CFL circuit at the same time that it was charging. I ran the relay off my small 2 watt solar panel. Really cooooollll. I didn't hookup the ground or antenna to it---yet.
    Here is the video:
    YouTube - Imhotep Relay Charger Replication
    Lidmotor
    Lidmotor your presentation of ~Imhoteps~ Radiany Relay Oscillator is brilliant.
  • Bodkins
    Originally posted by Philosopher View Post
    Has anyone tried to add a voltage tripler on the output of the ignition coil and run a CFL?.Its the ligth brigtheness increased?
    No have you try it?
  • theremart
    How to on the relay charger.
    Hey,
    This is a side track but I just had to try this. Thanks Imhotep for the new toy. It really works neat. I modified the relay so it would oscillate a simple CFL circuit at the same time that it was charging. I ran the relay off my small 2 watt solar panel. Really cooooollll. I didn't hookup the ground or antenna to it---yet.
    Here is the video:
    Lidmotor
    Thanks Lid!
    Finally got mine working...
    1. Purchase a 275-0001 automotive relay from Radio Shack, an neon, a diode ( I used 4007 )
    Steps to build Imhotep relay charger.
    1. Gently pry off the case helps to work one side then the other to get the catches loose.
    2. Scratch the surface as point out in the video then solder the wire to the now scratched surface. Then notch the case this will allow room for the wire to come out. Close up the case.
    3. The wire you just added goes to primary negative of the source battery.
    4. Connect the neon one side to connector 85 the other to 86.
    5. Connect connector 30 of the relay to connector 85
    6. Connect the Diode to Connector 85 this goes to Charge pos
    7. Connect a wire to 86 goes to charge neg
    8. Bridge your batteries with a wire from charge - to Primary +
    PREPARE FOR NOISE
    Wrapping this unit up in a towel does help preserve sanity.
  • Bodkins
    Great!! That is pretty much what I am seeing in my experiments. I got side tracked with Imhotep's Relay but I'm just about ready to box up this neon pulser (Blue Plate Special) circuit. You don't really need the SCR to make it work-- like you discovered. The neon does the pulsing. The faster that the neon pulses, the better the charging.
    Lidmotor
    thank you Gauss
  • DavidE
    Nat
    I was asking the qty of spheres because a few here are doing experimental work with them. I was trying to consider what kind of properties it might need to have. That is where the "electret" information might fit (see above).
    Polarized spheres, one connected to the + charged sky the other - grounded to the earth... sounds like an monster capacitor.
    Tesla was an Alien.
  • nat1971a
    It has occurred to me after running the 60volt input experiment that there is way more power in the circuit than the battery can absorb. It appears to be a quite a slow process (charging batteries) akin to watching grass grow. I would seem more logical to replace the battery with ultracapacitors or to use a combination of the two...where the ultracapacitor is charging the batteries with a higher potential........................... or even better to get an ac motor to run which can then run a vehicle or generator to power the whole house.
    i am no expert but this is where i will be looking into.
  • ren
    Ren,
    I measured the coil and it is 89 ohms and draws 120 milliamps when dead shorted. I have checked the draw using an analog meter and a digital and it is a real reading. The charge battery is being hit with BIG back spike voltage and charges up quickly. I think that the very fast snappy switching by the relay is what causes these result. I was very surprised that something this simple performed this well. Hats off to Imhotep for designing this.
    Lidmotor
    hmm interesting. Thats a fairly low resistance coil there. The pulsed nature of your circuit is definately reducing amp draw then.
  • nat1971a
    @davide
    Tesla was experimenting with 2 brass spheres insulated with 2 inches of wax at some point
    in my system at the moment i have been using two grounds
    His wireless transmitter isnt just a transmitter....it is the radiant energy system as well combined...
  • DavidE
    ANUT
    I have not seen your setup, but I got some similar effects in two different experiments before. Today, my digital multi-meter blew up simply because of this reason.
    12v battery connected ++ and -- to 7v motor.
    Monitored voltage at battery terminal.
    Normally charged batteries just slowly deplete...
    these others danced voltage all over the place.
    The motor seems to draw about 1.2v...
  • Lidmotor
    Neon pulser
    YouTube - Bodkins 13 BEDINI IMHOTEP TESLA
    i think the charging drops! because the big caps charges better but im still playing with it.
    if i take the ground off i can use the big cap as ground!
    Lidmotor
  • Philosopher
    Ignition coil + TV tripler....
