  • nat1971a
    wow just been testing charging caps up ....and the insulated sphere "kicks but" over the insulated plates.....looks like i will have to buy another sphere.....
  • nat1971a
    I tried putting a spark gap together on the weekend...but having no experience with them....i probably did it wrong..as i was getting no sparks.....will look at it again this weekend....as well as some different grounding solutions that tesla mentions....
  • Guest
    Guest replied
    That is well done and interesting, did you test to use a permanent magnet across the spark gap? Result?
  • DavidE
    Spark Gap set ups
    Spark Gap Experiments
    Multi-Spark Gap Experiments
  • Guest
    Guest replied
    Yes it seems connected to the Tesla rotating coherers for sure and also related to the neutrino powerred boats by Meyl. Rotation tis a sure trigger to me, nobody speaks about the Tesla rotating coherers, why did he use that and why is it so unknown?
    Rotation generally is underestimated I belive, since all aether(including condense matter) consists of counter rotating vortices we should really study the rotating coherer carefully. In a year or two we should be more conclusive about the best design.
    Also, Meyl says the OU is not a problem but the regulation of the energy bursts are. The receiver must work with strict On/off functions as the avalanche effect can destroy any device. Maybe if we rotate a device the stability of the effect will be better.
    Another interesting feature from radio technology: Spark-gap transmitter - Wikipedia, the free encyclopedia
    Notice the spark gap and the components, make some adjustments to the circuit and we have a pretty clean dielectric longitudinal wave.
  • nat1971a
    @gauss,
    number 1 sounds like Tesla's sensitive device he talks about in one of his patents...i never did understand what he was using that for...but maybe now i do
  • Guest
    Guest replied
    A quick summary of some late night studies:
    1) Electrostatic transfer between anode and cathode with thousands of small spherical beads(dielectric/conducting layers) as the "neutrino receivers" and a dielectric "receiver" at one electrode triggers lots and lots of neutrinos into making electrons and cold electricity, hence splitting water inside the cavity. Even normal DC works out. Is called the Patterson cell, mysteriously disappeared from everywhere on the web(almost) but not the Meyl Scalar waves book - it is a top notch invention based on geometry and materials choices. Claimed OU of 4000.
    2) Use the above concept but add a pulsed DC(>10 kHz) signal, take away the electrolyte and use a unipolar high tension voltage with a protective diode against back pulses(>1 kV) like Meyer. Add a spark gap with a strong permanent magnet to blow away all electrons and a spherical cavity for all small beads to rest in. Add acoustic resonance like Puharich suggested.
    Now I believe something really will happen in this cell so anyone has the kWhs to put in? He will rise like a saucer to the skies.....
  • Bodkins
    earth battery thread carl
    My setups on the last page.Nat
  • hh1341
    Originally posted by Bodkins View Post
    Thank Ash
    Looks like what i found was only me redicovering the same effect. Only exciting the system improve the volt pickup.
    Tomorrow Im off to by a full set of tuning Forks
    YouTube - Bodkins 16 Stubblefield earth battery
    HI Bodkins,
    Here is a site with a lot of NS stuff on it.
    Nathan Stubblefield Earth battery/Self Generating Induction Coil Replications
    Carl
    PS....can you give us the source of those patents?
  • nat1971a
    @bodkins
    Can you draw a sketch of how your rod and light and that insulation is connected together.
  • Bodkins
    Thank Ash
  • ashtweth
    This one is for bodkins, just to last minute distract him form Nathans work .
    It has radiant energy and Tesla's stuff in there thought might be of interest.
    (scroll down)
    Ash
  • Bodkins
    I need to to get the earth battery sorted out before I can move on to greener pastures.
    See you soon all
  • Bodkins
    @bodkins
    i beleive thats the 1hr 48 minutes that Tesla refers to. The great discharge from reflected waves of energy!!!
    YouTube - Bodkins 8 strange effect BEDINI IMHOTEP TESLA
    Maybe Not
    The Cathode Ray Tube site, Crookes tubes.
    I can get the stratification effect (bottom right hand corner)will post video.
    William Crookes (interested in spiritualism) did many experiments with the medium Daniel Douglas Home next to al his other Physics work.
    Crookes was so fascinated that he, as a scientist, wanted to measure this "new force". He believed that every human must have this
    kind of Physic force. Crookes developed a sensitive "indicator" in order to work without the (strong) force of D.D. Home, in fact this was the
    beginning of the radiometer. He had some information from James Emerson Reynolds professor of the Royal Dublin Society who had
    constructed a little instrument which would turn to the hand, fire, or another source of heat. [It consisted of a thin slip of deal suspended by a
    filament of spiders web and enclosed in a thin glass flask.....] all of this in 1871. After this experiment Crookes was so obsessed by this new
    discovered phenomena that he soon constructed many types of radiometers, otheoscopes and did great research of the behavior in vacuum
    to eliminate the resistance of air molecules.
    In 1876 produced Crookes assistant Charles Henry Gimingham, a skilled glassblower, for the Physicist William Grove the first electrical
    radiometer with metal vanes which Crookes developed further into the yet well known form. Geissler however, made better evacuated tubes
    due to his own developed vacuum pump which irritated Crookes, his produced electrical radiometers glowed faint due to residual gas.
    This was the start of a new race to produce the perfect vacuum sealed in glass. Crookes patented his radiometer on 5 Nov 1875 under patent
    number GB 3860. On 13th of may 1876 the Queen opened the Special Loan Exhibition in London, where both Crookes and Geissler showed there
    radiometers to the public. William Crookes presented here also his flask with "nothing" (vacuum tube) in which the Queen was not interested....
  • Agongon
    Lidmotor hits the bull's eye again
    Lidmotor,
    Wow! Very nice, very, very nice. Thanks. Also big thanks to Slayer007, and of course to our usual Bodkins, Nats and others who are really working hard for all of the success we are all experiencing now. It seems the pace is getting faster. The inputs of Braden, DavidE, Gauss,byjoveoldchap and others are just amazing. And most of all to our very own Imhotep who started this thread. You are all outstanding human beings!!!
