  • nat1971a
    i will be making a major video announcement this weekend.....stay tuned
  • Guest
    Guest replied
    Remember Tesla was a bachelor for a reason...
    Just to remind you of an interesting thing: Scalar wave technology by Meyl.
    And here is the EXPERIMENT KIT: XT-Commerce - Demonstrations-Sets
    For you who have some money left over and are afraid of shortening your expected lifespan with the HV/HF/Spark gaps you can turn to the signal generator instead, it works in the MHz range with a sinusoid wave and still gives an OU of up to 10 according to Meyl. There are 6 experiments described in the lab book:
    1) Energy transfer
    2) Feedback(receiver to transmitter)
    3) Proof of free energy
    4) Superluminal velocity
    5) Ineffective Fraday cage
    6) Refutation of near field interpretation
    I am not sure if this kind of kit will ever give the kw range effects but it will improve understanding of scalar waves I believe.
    Nat, how is it going? I just reread a book yesterday, did you try to add 2 permanent magnets(N and S on each side) over the spark gap? Put a conical/helical/metallic object next to the magneticaly quenched spark gap and see what happens..... Watch out.... Should get an electrostatic charge of the metallic object.
  • CaptainScat
    Guest replied
    hi all, i was playing around with the circuit shown here, http://www.energeticforum.com/renewa...html#post27204, minus the condenser across the ignition coil. for the bulbs i was using one standard flouro tube 2 feet long and a different kind of flouro out of a scanner, a small little thing an eight of an inch in diameter and maybe 9 inches long. anways, long story short, it lights the 2 foot but its dim. the scanner flouro runs as brightly as if it was driven by its original 12V inverter. i can't get this brightness with 2 normal flouro tubes.
  • braden
    re safety
    Nat,
    It may be prudent to start putting small amp fuses before the coils,Martdale posted a youtube video, where he nearly burnt his house down when he had a voltage runaway causing the coils to melt down
  • nat1971a
    yeah i am rearranging my setup for safety.........before i continue on......
    placing my batteries outside etc...behind brick wall....
  • Guest
    Guest replied
    Ok I see. What if you do like this:
    Multi-Spark Gap Experiments
    Add a capacitor before the spark gap, put the cold pulse through a primary and then over (to a cap) and possibly a battery - voila should work. Add an extra spark gap for safety, Meyl also says in his book the surges can be extremely dangerous and if a thunderstorm approaches...
    Cap - spark gap(s) - primary coil - cap - (battery) - no bad idea it seems.
  • nat1971a
    from my last circuit i posted... disconnected the cable from the positive of the primary battery to the spark gap and the negative from the primary battery to the negative of the cap ...increased to 36v...then it started sparking
    if you then connect the spark gap to ground...it stops....if you connect the spark gap to the negative of the cap it stops also....but if you connect it to nothing it works........as i said i have no experience with spark gaps....so am quite puzzled....
    maybe grays circuit works at 36 volts??? i didnt try that....the volt meter went off scale at 12 volts...but no sparking.....maybe have to take it to 36 volts......scary stuff.....
  • Guest
    Guest replied
  • Guest
    Guest replied
    Ok, but you left the battery out and went straight from spark gap to ground?
    Now you have sparks and before you had not, which parameter did you change? Maybe you could try a transformer soon?
    Well, I am ONE user and I have no idea about those user names... But I am not a builder, merely an interested observer here..
  • Joit
    Lol.
    thats the Different between blowing hot Air theoretically and sproad Links and practical doing it.
    Right /Gauss/darkwizard?
    Its anyway 2 Accounts from 1 Person.
  • nat1971a
    i replaced my antenna wire with coaxil cable.....and it seemed worse...so i can only conclude that the cyclinder b/w the bridge rectifier and the sphere...is acting like a magnifying transmitter of some sort.....
    might build grays conversion tube and see what happens....
    @gauss....tried connecting direct to ground and the sparks stopped...
  • Guest
    Guest replied
    Another idea is to put some simple Savonius wings on an inner sphere on your roof, that one should rotate more quickly than your outer sphere. Get the inner sphere to rotate, that would attract some more energy I believe.
    If not possible to solve try to rotate your sphere just as it is, maybe something will happen.
  • Guest
    Guest replied
    Nat,
    please try to wire the cold current from the spark gap through a primary coil and then to ground, attach many bulbs(normal should be fine) to the secondary coil(step down transformer) and see what happens. If you get no spark try to minimize the gap or step up the voltage.
    The cold current always looks for ground and you should pick up the power on its road to ground. Good luck!
  • byjoveoldchap
    errr... whats going on Nat ?
    You started on the Xmas spirit already Nat, drinking it I mean?
  • braden
    tesla plates and helpful insights
    there is some very interesting info here
    Nikola Tesla Page, Tesla's power receiver
