Electric Motor Secrets
  • vzon17
    Soleniod piston engine
    Originally posted by Tishatang View Post
    Hi All,
    I am so glad I found a link to this forum. I call this thread the Zen of R & D.
    I am in China and not able to get the Attraction Motor DVD, but I have some of Peter's books in my library at home.
    For those of you who are interested in a solenoid piston type motor, go to this link:
    Green Steam Engine Home Page
    I refer to it as the "Lean, Mean, Green Machine". Perhaps Aaron can start a new thread for discussion. I feel this is the one to build.
    Tishatang
    So are you suggesting to make an engine like that with electric solenoids on it instead of steam? that might be intersting. When I look at that setup I have a hard time figuring out how it makes rotation or how much torque it would have.
  • Aaron
    new thread
    Hi Tishatang,
    Yes, that is a very neat way to make a steam engine. It has been posted a few times on this forum in different threads.
    Anyone call feel free to start a thread at any time on any topic.
    When you're in the main renewable-energy forum:
    Towards the left side, you'll see a button to start a new thread. Simply click that and start one on that steam engine or anything else.
  • Tishatang
    Solenoid piston engine
    Hi All,
    Tishatang
  • lighty
    It really depends on the ampermeter and on the ammount of transients getting to it that it's capable of registering. As for those shunts- yes they would do fine if your oscilloscope is capable of measuring signals with resolution of at least 3.75mV or better (75mV/20A = 3.75mV/A).
    I'm not saying that ampermeter is making erroneous readings but rather that you should eliminate that possibility in order not to start making adjustments on the motor that are possibly not needed. Consider it a precaution.
  • Jetijs
    Hi lighty
    I am using those cheap multimeters that can measure up to 10A of current. I tried to get a shunt out from a cheap meter, but there was just a thick copper wire used as a shunt with no specs on it, so I can't use that. I also searched for some shunts in local electronics shops, but they do not have anything around, I can just order some from them, but they are charging about 50$ a piece for a 5A, 60mV shunt, like this:
    So I really have not pursued the shunt measuring idea
    What about these shunts:
    20A 75mV DC Current Shunt Good4 Digital Analog meter - eBay (item 350072790126 end time Jun-29-08 09:16:37 PDT)
    do you think they would be suitable? If yes, I will buy them now!
    Of course, I am not an expert, but do you really think, that all those spikes would make an error this big on my cheap amp meters? The power supply current reading is about 30% less than the amp meter reading, but that, of course, is because of the recovery. I mean, to get at least 60% efficiency in my calculations, it would require a current draw of about 1A (instead of 2.45) for the same other readings. Could those spikes make an error this big on the meter?
    Maybe the problem is somewhere else
    Thank you!
  • lighty
    @Jetijs
    What ampermeter do you use for measurement? I mean for anything in kHz range with any kind of distortions you should really forget about DMMs because even capacitor won't filter out all the spikes and distortions. If you don't already do it you should measure RMS current with oscilloscope but I guess you're already doing it that way so I'm just reminding you of that fact.
    P.S.
    I just checked your schematic and you really ought to place your ampermeter directly on battery + and measure total current going into the system.
  • Jetijs
    Peter,
    this is the circuit I used with the amp meter in it. It shows the current that the motor is actually using. If I connected the ampmeter between the insulating diode and power supply negative terminal, it would show less current (only the part that is taken from power supply). When I made these tests, I used the same commutator wheel as before, it has one 65 degree gap on each side (180 degree apart). There was no LED pulsing, so the energy recoverey was at about 30-35%
    I also made changes in my calculations so that only the difference in both scale readings is used to calculate the torque, this gave even worse results with efficiencies around 20%. Test results where there was a deflection only in one of the scales, remained the same. I used a rather narrow leather strap, about 4mm wide (did not have anything better). Using this strap I could load the motor with up to 25 grams till the other scale also started to deflect.
    Anyway, the calculated efficiencies are so low, that either I did a mistake in measurements/calculations, or there is something wrong with the motor.
    Thank you!
  • Peter Lindemann
    Clarifications, please....
    Ok, I finally got the spring scales, they seem axactly like Peter used in his dvd. A friend helped me with the measurements. While he loaded the wheel, I monitored the RPM's, volts and amps. Amp meter was put before the insulating diode, so that it showed only what the motor actually consumed and not what the power supply was showing. Also the voltmeter was attached across the capacitor. It always showed about 1V less voltage than the power supply voltage. I did numerous tests with two different input voltages. All the tests showed that the more I load the wheel, the better efficiency I get, but the efficiency is still too low. For example, here is one set of the test measurements:
    Input voltage - 11.42V
    Input current - 2.45A
    RPM's - 2655
    Scale1 deflection - 100 grams
    Scale2 deflection - 10 grams
    So the input power is 27.979 watts or 0.0375 HP.
    The wheel circumference is 0.5 feet, so at 2655 RPM's there are 22.125 feet per second.
    If I sum up both scale readings, I get 110 grams. If 1 gram is 0.00220462262 pounds, then 110 grams will be 0.242508 Lbs
    To get the foot pounds per second, I must multiply the pounds with the feets per second. That would be 0.242508x22.125=5.3655 foot pounds per second.
    Now, if we divide the foot pounds per second by 550, we get the output HP.
    So 5.3655/550=0.009755HP
    This means that the efficiency is HP(out)/HP(in)x100 or 0.009755/0.0375x100=26.01%
    I got similar results with all the measured values. So what could be wrong? Are there a mistake in my calculations or measurements? Or could the problem be somewhere else? How could I find the problem?
    Jetijs,
    Congratulations on finally getting all of the parts together to make your own dynamometer! You are now in an excellent position to start testing you experimental motor.
    From what you said in this post, there are still a few things you don't understand about the process, so I'd like to help you through it.
    The first thing is, I am unclear exactly WHERE you have placed your input ammeter. Could you please post a complete schematic of your circuit and show me where the ammeter is placed?
    Second thing is the method of reading the scales. The proper reading of the scales is the DIFFERENCE between the scales, not the sum. Also, to get the best results, the pressure applied by lifting the scales should be backed off until the low reading scale reads ZERO. That way, the high reading scale is the full deflection. This is the method I demonstrate on my DVD.
    Third thing is that you and Lighty have already determined the best conditions for running your motor, where the recovered energy is the highest. This is the speed we want to run the motor UNDER LOAD on the dynamometer.
    Fourth thing is under these conditions, we only want to monitor the power (current and voltage) actually coming from the supply to keep the system going. We don't care how much the motor actually uses, which we KNOW is COP<1. All we care about is how much WE have to put in to keep the process going. THIS is what can be COP>1!!!!!
    If your motor can produce 60% mechanical efficiency AND recover 60% of its electricity and return it to the capacitor in the front, then we should be able to measure the motor's efficiency at COP=1.33 because the motor will be able to produce 60 units of mechanical energy for every 40 units of REPLACEMENT electricity we need to supply!
    Let's just take this one step at a time, and see how far we get.
    Great work!!!
    Peter
  • Jetijs
    RPM's - 2655
  • muttdogg
    Component size
    H1341;
    If you can standard-size any of the components on your device please let all of us know. One of the things I have learned on this thread, is that there is no standard. Each motor, unless it is produced by a company, will be subject to the parameters given by the creator, if not there will be sacrifices in the design. I wish you well in your experiments, but you gotta remember, they are your experiments. There is a wealth of information on this thread, but you need to use that information to your own advantage. When I first started learning about alternative energy, specifically a motor to drive a bicycle, I thought I would find a design that I could put together and then just drive! After a year of research, I found this thread, and found I knew nothing about motors. Jetjis, Peter,, Lighty, Elias , were light years ahead of me. Dang-it. At least the motor I was trying to design. Watch out for designs delegated to the dust-bins of history.
    Dan
  • kokerich
    Alternative method for power measurement.
    Power measuring is essential when estimating the COP, and I'm thinking how to do it easier. Well the basic idea goes like this.
    Maybe I'm simplifing too much, ha?!
  • hh1341
  • lighty
    @hh1341
    No, of course I'm not suggesting that it shouldn't be attempted. I'm just pointing out the obvious obstacles that would have to be solved before design would work even remotely efficient on the bigger scale. Some obstacles like the lack of keeper could be solved with the outer coil having a full keeper and the inner one with having at least partially closed keeper. The friction obstacle could be (at least theoretically) solved with extremely precise and thin layer of teflon inside solenoid or better yet with thin layer of teflon inside solenoid and teflonised (I don't know the correct English term) yoke. Of course that would add to the gap between solenoid and yoke but with the proper selection of yoke material and keepers on solenoids that could be reduced somewhat (theoretically).
    So, I'm not saying that it's not doable but I personally don't see the advantage of adding several problems to be solved in addition to the ones introduced in Peter's design. Also, Jetijs is hardly a home hobbyist no matter what he says- his experience and accessibility to machining tools are beyond scope of most of the people on this forum (not all though).
    Anyway- I will contribute with advice if I have something relevant to say. Good luck.
  • hh1341
    Originally posted by lighty View Post
    I'm with Peter on this one because I anticipate few obstacles that would have to be solved.
    1. One shouldn't use two solenoids per yoke because one would really want to use keeper in order to minimize stray flux and thus significantly reduce losses.
    2. Airgap between yoke and solenoid should be as tight as possible to reduce magnetic losses through air. With rotary design it's a question of precise machining. With solenoid design it's a question of choosing the appropriate durable friction reduction material while at the same time reducing gap as much as possible. Those are two opposing requirements.
    3. Again you would have to convert linear motion into rotary and introduce more parts, more friction and thus more losses.
    To be honest I found solenoid design to be too demanding for average home hobbyist. On the other hand Peter's design if done properly is also too demanding for home hobbyists.
    Always check the pretty picture
  • lighty
