  • John_Bedini
    Big Bedini Machine
    John Smith,
    I guess the meaning is not understood by you.
    I said if you live in the northern hemisphere the rods going through the coil core would extend 3 inches past the south pole or the base of my coil. Why did I say this because of where the energy intersects in the coil. If you live in the southern hemisphere then your rods would extend towards the north pole magnets or the top of the coil.
    The shield is then adjusted to the Bloch wall. You must learn what it is that your looking for before you build anything or failure is in your path. I have told everybody to watch the movie at www.144.com for a reason.
    I also said that you must drop through the Delta Zero to gain the energy, or what termed mass-less charge, mass-less charge is what your collecting. If you watch that movie and understand what is being conveyed to you, you will understand why the 16 poles around the wheel and the axial motor has ten poles, Ring Twice. you will only find magnetic streams and when the imbalance comes you get current to charge the batteries. (in another post here )
    ( Aaity is a saint. She is my good friend.Time spent studying her work could not be better spent.)
    We will ask you to work with energies that are invisible to you. Even as they are invisible you can see their shadow effects. Be patient with us and with yourself and all will be clear to you over time. Read as much as you can, then rest. Let the concepts be taken into your center.
    ALCHEMICAL MANUAL
    FOR THIS MILLENNIUM
    "She is right all energy comes from the Bloch wall", look at her drawings.
    As I said before this machine is to advanced. look at the three coils what do they make up? So why do I need any switch on the output?
    It's possible you are on the wrong planet .
    And I'm not screaming just running out of time.
    John B
    Originally posted by John Smith View Post
    Hello all
    Just had a thought...dangerous I know but....Here goes....
    John Bedini stated at the CDA conference that the North magnetic pole is the dominant pole...I accept that.
    Well it occurred to me that in the Northern Hemisphere I can see the reason for this being the case as the North pole of any magnet is closer to "The North pole" in the northern Hemisphere so the dominance is easy to see.
    Does it not stand to reason then that in the Southern Hemisphere that the South Pole of any magnet would be the dominant pole?
    If so....would it be fair to assume that those of us at the bottom of the globe would either have less efficient machines or could we have the same efficiency by building our machines with the south pole facing outward.....??
    Hope I am not on the wrong planet here...
    Just my 2 cents worth
    Thank you
    John Smith
  • xpskid
    Coils
    While I experiment and probe around these shaped fields with the single coil challenge, I'd like to slowly work on the three coil set.
    Does anyone know of general guidelines for coil to core ratio ?
    IE: Coil length / Core Length of approximately 1: 1.66 ???
    Timm
  • Rl2003
    Thanks Sniky, I will try one, I've got three to get it to work otherwise I will have to wait till I order some.
    Originally posted by sniky View Post
    the 4 pins halls are
    +side output 1 output 2 GND
    you can use only one of them and will work
    when output1 is on , output 2 is of and viceversa
    (this is for alternate Poles)
    Visse, Thanks for the heads up on that. i will spend the time I have right now on the timing wheel. No one said if a infrared switching device would work or not??
    Mark P
    Mark. You should not use that circuit as I could not get it to work yet.!!
    Rather try the solid state relay circuit for now as Matt got it working real well.
    Vissie
    Today 03:53 AM
  • John Smith
    Dominant North
    Hello all
    Thank you
    John Smith
  • sniky
  • nvisser
    The halls I know has got 3 legs and look the same as that small transistors that came with the 3 pole kit we got at the conference.
    Rather buy one. I use A1203.
  • Rl2003
    I found some Hall switches. They are tiny and have four legs. I think the fourth one is for programing and 123 are Voltage in, Ground and output. Thats from left to right.
    Can anyone confirm this. The only thing on them is an "E". I didn't find any schematic for them.
    Mark P
  • John_K
    Mark,
    Great looking setup. I'm just in-between snow plowing right now but I'm here watching.
    Great looking work!!!!!!!!!!
    John B
    John, mind your fingers!
    I will also remove the superpoles from my rotor. I've also ordered the neos for the back of the ceramics and the disc ceramics for the timing wheel.
    I attempted to draw out the lines of flux when you have the metal sheild on the bottom of the coil and the small neo on the back of the rotor magnet.
    It kind of looks like a flux gate!
    John K.
  • Rl2003
    Thanks Guys for the nice comments. I have a few things to adjust and change
    when I attach the timming wheel, but otherwise moving along.
    Visse, Thanks for the circuit. I will put together what I can tomorrow, the only thing that
    I may need is to find is a hall. Not sure I have one. Lots of reeds switchs and IR's from encoders. Would an IR work??
    It sure would be easy to mount and adjust the on time. Down side is that it needs 3-5 volts and don't know if the pulses will affect it.
    Mark P
  • John_Bedini
    Big Bedini Machine
    Turion,
    The machine does not use any super poles on the wheel, trick add a little neo to the top sides of wheel magnets so south is a little stronger.
    In other words use the top side between the rim on the wheel. but it looks like it will work just fine.
    JB
    If I understand correctly, the machine used super north magnets, that is two magnets with their north faces forced together and glued. Then these magnets would be placed on the wheel so that the sides of the magnets faced the coil and the two south faces point to the sides, or toward other magnets on the wheel.
    S [][] S
    [] Coil
  • John_Bedini
    Big Bedini Wheel
    Mark,
    John B
    Very nice looking set up Mark
    Mark
  • Bill H
    Originally posted by nvisser View Post
    This is the mosfet cap pulsar circuit I want to try . I did borrow some information from Johns patent 6677730_Device_and_method_for_pulse_char
    It is very basic and only for use on a 12v system. For higher voltage systems the gate voltage will have to be regulated to not exeed 18V.
    Looks good! I ordered up some IRF260's today, look forward to some good cap pulsing.
    I am still waiting on the parts to build my BiPolar circuit but I did run my wheel on a hall trigger today, played around with a timing light on the output pulse, it was a great experience.
    On a side note, I also have a large version of nvissers series/parrellel pulser waiting for some action, it is 4 7600uf 50 volt caps all tied together with 1n5408 diodes, i have pulsed ti manually....it is a beast.
    BillH.
  • Turion
    S [][] S
    [] Coil
  • nvisser
    I cannot get this mosfet pulse circuit to work. Once it switch on it stays on like the problem I always had with this.
    I have to remove the circuit and go back to the bench this time to get it working.
  • nvisser
    Very impressive mark!!
