  • Ufopolitics
    C&B et Al
    Originally posted by crash&burn View Post
    I have one friend who has a water jet cutter. He can cut anything you could imagine. What if I used a composite fiber from areospace industry? Just get a big block and cut out one piece with the fins? It is heavy but incredible strong. Actually, that may have carbon in it.
    The air gap could be as tight as you want with the water cutter.
    Also, due any number of armatures work, how did you get your winding patterns?
    The closest thing I could find is universal motor with a 2-pole field stator.
    But you have changed it completley.
    We were kind of "surprised" by an asymetrical winding.
    Sorry, lots of questions.
    Thank you
    CB et al
    Hello C&B et Al,
    Waterjet is great, having the CAD exactly to cut is excellent, I am going to render the Pattern to follow that approach also. I have used WJ before in many Motors I have built from scratch...Armatures and Stators.
    Ah...the only thing that you could NOT use as Material for the Stator Core, is Carbon Fiber Mesh, Fabric...it has the rare property to instantly kill Radiant Field Induction to exactly ZERO...I have several cylinders of CF...made with fabric...I have tested them all...it dies right away...and this is due that CF is like a Superconductor for Radiant-Cold Electricity...it will short out instantly...and it is faster than Hot...
    You could use KEVLAR, but it is very hard to cut...unless you get the right tooling/blades...
    Winding Patterns comes from Ancient Sacred Geo...to new configured based on certain rules of Asymmetry...like no parallel axis of Pairs of Coils at In/Out...so we have to look for specific designs where this does not occur...
    Asymmetry...is beautiful...you will see it working.
    UFO
  • crash&burn
    Thank you
    CB et al
  • Ufopolitics
    Hello and Welcome Dear,
    hello everyone,
    I have also been trying to catch up. I do not have much computer skills but i do have hands on experience in " different shops", and lot's of friends with very nice shops, machining and electrical.
    Is This correct (roughly, for layman like me)?
    The field magnet got improved to permanent magnets, and now we improve that by using a field magnet(energized coil), with the permanent magnets, plus use "isolated armature windings", not one big single coil thus eliminating the bemf. That was alot to say and probably not right, but this is very different, and looks really nice, to build.
    I am getting a friend to help me build the circuit to pulse the coil as I write this. He owns an electronics shop, and is into homemade radio, he is also interested now, i showed him your videos, on YT.
    In your other thread, you mentioned running a vehicle, and that would be really "sweeeeeet".
    I have the rs motors to try an "asymetrical wind", looks fun!
    I am waiting for info/prices on imperial motors now, p56sd704?, to start.
    Your last video was beyond cool, I even have a body shop friend, i am sure he will help me with the mold if i ask nice.
    Can I ask one personal question ufo?
    Are you a professer, you seem like a professer to me, what do you do?
    CB
    Hello and Welcome Dear Crash&Burn,
    I wish I would be a Professor...but they would have trow me out by now...
    I am just a "Random Guy"...out there
    Permanent Magnets are Ok, but they add constant magnetic drag with steel...and worst than that...Models are not scalable to huge sizes...so it limits their size...
    Coils like you saw on my Video are very scalable...and besides with two diodes you obtain Radiant Energy reversed flow...that could be used to light up or re-charge system through the proper Electronics Filtering and BMS (Battery Management System)
    That is great you have so many friends in the same fields!!...and willing and interested to help you!!...but those are awesome news!!
    The Oscillators I use are just based on Cheap 555 timers in Astable Mode...no big deal, you will find here My Diagrams...also look at the "Updated" Voltage Regulator Schematics...where there is also a slight resistor deal, one is 220 Ohms and the other one is 2200 Ohms or 2.2K...I wrote both at 220 ohms...my bad. but is rectified in a lower post.
    Yes you will be able to run vehicles...so get ready...start first at smaller scale...then upgrade.
    Now the Fiberglass Stator could be done off original Volumes...a Cylinder, sand it down, but make sure you have found your perfect Armature first...with enough shaft length to host a second Commutator...and some Fiber sheets...cut them glue them with same small fibers and polyester resin...Marine Supplies have all, fabric..and resin plus hardeners.
    Many Regards and Welcome again!!
    UFO
  • crash&burn
    hello everyone,
    CB
  • Ufopolitics
    Welcome!
    Originally posted by yipyipdog View Post
    I don't recall if I have ever posted anything on this forum before, I mostly just read. But this is one Thread I will definitely be participating in. Wanted to say hello to everyone. I am trying to catch up on things before I ask questions/make comments. I currently am on page 10 of the thread.
    A little background on myself - 48yrs old, been working in the electrical field for almost 30 years starting with generator repair (small to large - size of a truck), electrical contractor for 20 years with an electronics engineering degree from the University of Akron, Ohio.
    p.s. what is a trackback?
    Hello and welcome friend,
    Please. feel free to read first as much as you could...not all the crappy arguments though...but the "essence"...
    A track back is an automatic "text robot" that sends you messages when someone posts here...so you could come and look at them...
    After you done here most of Us are at My Asymmetric Machines, fighting... ...We need people with your experience there also.
    UFO
  • yipyipdog
    Hello Everyone
  • codeboundfuture
    Originally posted by HagenT25 View Post
    Hi Matt,
    I got them from Digikey. There were a little expensive, but I wanted a mosfet that had a high voltage rating. I hate it when I blow them up.
    Hagen
    I don't blame you, and thank you for causing me to look them up, I forgot I had a 15% rebate from Newark.com that is only good for things that you don't buy enough of to get a discount on them, which I couldn't afford 10 of those mosfets to have to worry about that, it was a good opportunity to use it.
    Having said that though the coupon will work for anyone and those big FETS are probably one of the best opportunities to use the discount.
    From http://www.newark.com sent to my email. Hopefully this can help some people out. I saved about $3 each on the CMF10120D mosfets.
    "The Voucher code is NEW2P and it can be used as many times as you would like through August 31,2012, feel free to share with whomever you would like."
    peace,
    matt
  • HagenT25
    Originally posted by codeboundfuture View Post
    Hello Hagen,
    I was taking a look at those FETs and in the application notes that the 20V turn on should be something closer to 22, the starting turn on voltage is around 2.5V, but is not fully on until 16V. I'm not an electronics expert by any means, JohnStone mentioned similar information about the gate swing speed needing to be fast and hard(enough current), it looks like you will just have to be sure to take good care in the design of your oscillator to mitigate these factors but in my opinion they are good, the fast rise/fall time is important and the voltage/amperage availability are nice.
    Just be sure you can drive them well, to me they look like they will be a tad more difficult but I know little of the tribulations of circuitry design.
    best wishes,
    matt
    P.S. Did you find a good price on those mosfets? I was looking at them when I purchased SiC zero recovery diodes from Infineon and Cree but they were hella pricey, I think $6 for the 600V mosfets.
    Hi Matt,
    Hagen
  • codeboundfuture
    CREE Fets
    Hello Hagen,
    best wishes,
    matt
  • HagenT25
    Cree CMF10120D MOSFET
    http://www.cree.com/~/media/Files/Cr.../CMF10120D.pdf
    I just got of couple of these the other day.
    Any feed back this MOSFET would be appreciated.
    I read in the specs that it likes to see +20 volts GS for turn on.
    Thanks!
  • HagenT25
    Hello Hagen,
    The voltage regulator is the correct way to NOT discharge ONE single Battery out of the WHOLE BANK, a very simple LM317 and a couple of resistors and Caps, will feed steadily the necessary and EXACT, Voltage-Currents,required from Oscillator IC, in a MUCH BETTER FILTERED WAY, that just getting it directly (IN ELECTRONIC RUSH AVALANCHE) from just one Battery, As this will create an UNEVEN decrease in the Main Bank Supply...
    Other words, getting the "juices" from just one Battery is, besides a Lazy Choice, not a well Laid Out, electronic design of manipulation and management from Battery Source...
    Understand?
    UFO
    Thanks UFO,
    I know that you would not want to take any sort of real power from any one battery, but I was thinking just how much power can a 555 use up? Of course it may not be as stable as the voltage regulator, and that may cause some issues, and you may have to deal with some ripple. I guess it's the poor man's choice, or the I'm waiting for Fed Ex choice .
    Hagen
  • Ufopolitics
    Hello Hagen
    Just out of curiosity.
    Why do you need a voltage regulator when you can grab DC from the first battery out of the three batteries?
    Hello Hagen,
    Understand?
    UFO
  • HagenT25
    G'Day Dana
    My wife wont like this But I Just have to give you a big
    My problem all along has been the resistor connecting the Oscillator to the mosfet circuit it should have been 10k but I only had 100R
    Like I said before I think it is just the nut on the end of the soldering Iron
    I am really pleased with the people on this list every one is patient and wants to help even the NumSkulls
    Tomorrow I will connect the coil and the CLF bulb then I can start to
    I think this is this the way to hook it up at least this is the way I see it
    Please If you would just check it over for me to see If I am correct
    Thanks a million to all those who have helped me
  • Bob Smith
    For what it's worth, I cut my motor housing with a fine grit cutting wheel on a dremel - pretty quick. I pincilled the line for my cut the whole way around, cut it a little larger than needed (outside the line), then levelled out the cut on a sanding board (quarter sheet of plywood with 80 grit sandpaper surface).
    Bob
  • wonza
    For those continuing to build this using the Radio Shack motor, was able to use a Rigid pipe cutter, vise to hold the pipe cutter and a drill to turn the housing. Once set up, took less than a minute to cleanly and evenly cut each section of the housing. Thought this technique would help those that do not have a lathe to do this with.
    IndianaBoys
    It might be worth posting this in the main thread: http://www.energeticforum.com/renewa...-machines.html
    It's funny you mention this though, I was using my hacksaw yesterday to cut it, I did a decent job at getting it straight, but no where near perfect; but I had the same idea of using a pipe cutter instead.. just need to get one
