  • Ufopolitics
    Hello Iankoglin
    [QUOTE=iankoglin;201316]
    G'Day Dana
    Both my Regulator and my Mosfet circuits work Fine
    My Regulator works fine outputs what ever I set the pot at
    The Mosfets switch on and off 3 x 12v bulbs in series so it works fine
    I have tested it by bypassing the Oscillator IT IS OK
    The questions I am asking are
    Question One
    When the 555 circuit is Oscillating and the input is 12v is not the output to the Gate bus expected to be 12v the same as the input 12v but switching at the pulse rate of the duty cycle?
    Also
    Question two
    Should the frequency remain reasonably the same throughout the changing of the duty cycle?
    Question Three
    IN UFO's Circuit /Diagram My Motors got me to Tap into Radiant Energy
    the Wiper to the 250k pot comes from pin7 by passing the diodes before D4 (in kapierenundkopieren's it is D2) where as the wiper in kapierenundkopieren's Post here
    comes from pin 6 before Diode His D1(which is D5 in UFO's)
    I have mine set up as per UFO's
    Please
    Which is the correct setup?
    Please what could stop/reduce the output volts?
    Still
    Ian,
    My circuit works fine...now you wrote:
    Question One
    May I ask you one question, a silly one, sorry, you are mentioning Gate V but you wrote "BUS"...Now, I hope you are not trying to turn on your Coil with 12V?...right?
    It seems you have a Supply fault there...when you hook up coil it drops down...Your Coil will require -at least- 24 to 36 Volts...
    Your Gates DO NOT need the whole 12 Volts to trigger...2 to 3 V is more than enough (like Dana said)...so there is a problem there...your oscillator is not sending right signal to FET's Gate...
    Now you mention you turn the pot to regulate Input?...from voltage regulator ?...my circuit regulator (LM317) do not have a "pot"?...You are using an external one I guess..so, is that regulator output also hook to
    Negative Source and Positive to Coil?
    Could you please draw (hand draw is ok)..your whole set, including V Regulator, Coil, and the "part" of my circuit you are doing...pictures do not work...so, go over the whole thing...write it down...let's give it another try...
  • iankoglin
    [QUOTE=prochiro;201293]
    Kogs
    This may be as stupid question but I have been watching you struggle for some time. First, if you have 2.5 volts to the gate, that part should work. Just in case, you could take a fet and do a test rig with a variable power supple to check when yours will fire. All could be low voltage and a LED/resistor setup.
    You should also have 12 volts or so at the source pins. This is not enough to lite the cfl but good for testing. If you have 2.5v at gate and 12v at source and 0v at drain, then fets are blown. Otherwise, there is no reason for them not to work. If you are using the cfl to tell if the fet is fireing, not a good method as with all working at 12 volts only it would be hard to get cfl to go the first time without exact timing. If you think that there is no fet on time, check the gate to gound voltage and see, if you have not done so already. Just trying to help. I think that you getting the PWM will solve everything fast.
    Dana
    G'Day Dana
    Question One
    Also
    Question two
    Question Three
    Please
    Still
  • Ufopolitics
    Sorry Ian...not that..
    G'Day Les K
    I that the reason of 2 motors is using the coils from one motor to drive the other like he explained here http://www.energeticforum.com/renewa...tml#post183683
    Hello Ian,
    I am very sorry you are still struggling with your circuit!!
    And I am really sorry...but I am having some "pressure" to upload the little Radio Shack Motor spinning... ...and have no time to go over with you...
    Ok, You got to read my post above...go to that thread and read post number seven (7)...then you will have an idea of what I am gonna do...
  • Ufopolitics
    Hello to all
    Ok, for all of you guys to know...I have opened an specific Thread on My Asymmetric Motors-Generators here:
    http://www.energeticforum.com/renewa...-machines.html
    Now, go to my post number seven (7) and read what we are going to do to those two little motors... and I also have uploaded some nice pic's of the "making"...I will post a small video later on tonight..
    Thanks and regards
  • iankoglin
    Originally posted by Les_K View Post
    I am not sure I can see how to implement this in the radio shack motors. At first I thought maybe We were going to remove the brushes etc. from one and add to the back side of the other. but that is not easily done with these motors.
    Anyway If I understand this right This is splitting the streams which I understand to be the "Secret"..... Is that fundamentally why two coils?
    One other thing that it looks like it can do is be either a generator or motor?
    This is going to require a lot of thinking but it is starting to clear some of the fog... But I can't wait to see my little motors here spinning just like what is shown. Replication is everything....
    Les
    G'Day Les K
  • prochiro
    [QUOTE=iankoglin;201290]
    Hello
    G'Day UFO, kapierenundkopieren,EtAl
    I am still having trouble I am sure it is the 555 Timer circuit I have ordered an Oscillator from China This one here
    eBay Australia: Buy new & used fashion, electronics & home d�r
    While I am waiting for it to come I still need to understand why this one I have tried to replicate does not work
    First of all It does seem to Oscillate, as when I Connect to the DMM set in duty cycle mode as I turn the pot from lowest about 1.4%? gradually increases to highest 99%? But when connected to the Mosfet circuit it does not turn the mosfets on.
    The volts at the output to the Gate bus on the Mosfet circuit is only about 2,5V? and this showed to be about right when I measured with the Scope
    Question
    Also
    IN UFO's Circuit /Diagram http://www.energeticforum.com/renewa...tml#post179481
    http://www.energeticforum.com/180140-post156.html
    Please
    What would stop/reduce the output volts?
    Still
    Kogs
    Dana
  • Ufopolitics
    You will see them...
    Ok, I have been looking at this incredible work. I understand this at the basic level. The collapse of the magnetic field is creating the high voltage spike and that is being sent to be used/captured just like the Bedini SSG or window motor etc. That all makes sense to me.
    The interesting thing that I see in the video is your point about the flow and more than one coil. These streams are not running against each other(Thank you! ) But are in a flow interlaced. If I were to guess, I would say we are looking at something like a DNA strand as it winds around the center while spinning.
    Les
    Hello Les, Thanks and yes...you will see them...
  • iankoglin
    Re Kogs 555 Oscillator
    [QUOTE=Ufopolitics;180157]Hello
    Originally posted by kapierenundkopieren View Post
    Yesssss!!!!! Now, That work looks AWESOME!!!
    Yes, that is perfect, I knew at least ONE of You guys will give the final touches at great detail.!!!
    That is wonderful!!
    Question
    Also
    Please
    Still
  • Les_K
    Understandings...
    Les
  • Ufopolitics
    Hello Larry
    Originally posted by larryross View Post
    UFO
    How can I email you? I would rather not discuss my comments about your video on the forum.
    Larry
    Hello Larry,
    Is there something wrong?...did you like it?...
    [email protected]
    regards
  • IndianaBoys
    Originally posted by anthonynoahan View Post
    I had gone through the post. The motors which I am using was good as I was using them from many years and doesn't came across any problem with them. Could you please produce some attachment links regarding the book that you have described. I am having the motor from the manufacturers amperis.
    partial discharge detector
    winding resistance meter
    Anthonynoahan,
    That is great you posted this. The price for the Switchgear ULD 40 in US Dollars is around $3,350.
    Switchgear ULD 40 | Amperis - Tests & measurement electrical instruments
    Found a similar one made by Amprobe at Allied Electric for $350 USD:
    Amprobe ULD-300
    Amprobe - ULD-300 - Testers - Ultrasonic - Allied Electronics
    While locating corona arcs with a camera that cost over $100,000 and rent for $18,000 for 3 months (price keeps it out of reach for most), the above test devices put detecting the corona arcs at a level more can afford.
    These devices will also help break "The Spell" as UFOPolitics puts it.
    Below is a visual of corona discharge. While they are looking at ways to eliminate it, we are looking at ways to set up the environment to direct it, manage it, and put it into positive beneficial uses.
    Eliminating Corona: Using Epsilon Midsun RTV HVIC for eliminating Corona Discharge
    Eliminating Corona: Using Epsilon Midsun RTV HVIC for eliminating Corona Discharge - YouTube
    IndianaBoys
  • prochiro
    Posts
    Larry
    Click on his title name at the top of the post and select private email.
    Dana
    By the way, Thankyou for the help given in your posts.
  • larryross
    UFO
    Larry
  • anthonynoahan
  • john_g
    UFOpolitics
    Fantastic video - thank you. I can see why it took so long to make.
    Look forward to trying to replicate.
    John
