  • Dave45
    We'v done it bro we figured out how the galaxy works,
    Now we just have to make it work for us the people.
  • Dave45
    When watching one of the vids it showed the magnetic field of a torioid and I realized the A vector potential field runs inside the toroid thats why a toroid has qualities that are different than a solenoid.
    I will have to think on this awhile
    If we use say ferrite cores,
    In a solenoid the magnetic field runs in the ferrite core, and the A vector field surrounds the core
    In a toroid the A vector field runs in the ferrite core and the magnetic field surrounds the core
    The A vector field runs inside the core
  • Dave45
    Let me show you what i see and you let me know what you think
    In the picture you posted Dave, you see (in a simplified manner )
    3 Elements: 2 vortex and a donut (Rodin coil most likely )
    You'll find these three element all over Mother Nature's work...as if they can only exist as a "triptych "....you follow me so far
    so i would venture to say if you create two solid version and join two of these three elements; for instance, one Rodin coil and a vortex coil ; the third element will come into existence ie: the third vortex....your 3 6 9
    bonus:
    you control the third vortex thanks to the second coil:
    John W. Keely
    ps: no one ever thought of placing a dc pulsed Smith (Caduceus Coil ) in the center of a dc pulsed Rodin Coil....would make an amazing antenna
    It would be interesting to see a rodin coil in ice, but the A vector field runs inside the core of the rodin coil,inside the doughnut, now to make a superconducting ring for antigravity
    But for free energy we must us a vortex coil wound like Tesla's bifilar pancake coil. Im building one now and it easier said than done, one failed attempt so far, but I'll get it.
  • MonsieurM
    bonus:
    John W. Keely
    ...When these harmonics form unisons or direct harmonic relations the two vibrating aggregates and their chords of vibration are said to be sympathetic to each other. This unison of frequency dictates that what happens to one vibratorily happens to the other simultaneously.
  • Dave45
    The A vector field moves into the core, like water down a drain
    and we can manipulate this field.
  • Dave45
    Sorry for the spelling tried to correct it but these darn computer's
  • boguslaw
    Originally posted by Hope View Post
    I can answer this one. How we can tap into this field is by disturbing the natural flow of the field (say with HV spike (arcs for instance) that disturb a large area of this balance field) then placing an antenna (connected to a load) to collect from what nature sends (you see we just make a less resistant path than air is) to re-balance this disturbed field. This has taken me a few years to see clearly and I just last week understood it. We are floating in a vast sea of energy. I at first thought we had to anchor to a place that was not moving so we could sense and use this "sea power" but we do not have to do that (all the metal in the world may not be able to take that much current anyways) all we need do is disturb the cohesiveness of the atom to atom bonds and "nature" will on it's own seek to re-balance itself. If we provide a path of least resistance with a working load on it then we can reroute that balancing energy into doing another job.
    This example of high voltage disturbance causes the cohesive bond of atom to atom to be shifted (like when a pebble is dropped into the water, the waters surface tension is broken) and then the sea of energy makes it re-balance or cohesive again. I believe this is what all these device we been trying to figure out really are doing since Tesla and even others before him.
    I agree. The only possible explanation why Earth is rotating and why its magnetic field can resist so powerful solar wind is because there is inflow of energy which makes it such. The resonant stage when resistance is null makes a kind of "magnet like " structure which allow this energy to accumulate maybe like a vortex, but we need a kind of trigger which force that energy to lag for a moment and change direction into our resonant circuit. Resonant circuit is a must but I still do not understand how we direct cosmic energy into it. It must be like a bell which is singing from a wind - our work is to hand bell where wind is blowing or redirect wind.
    The other problem is to load resonant circuit without damping oscillations.
  • Hope
    the planets and stars of a galaxy run in the electric field. the center of the galaxy is a magnetic core, what they call a black hole is the magnetic core of our galaxy.
    Its starting to make since now
  • Dave45
    Realizing that there is an A vector potential field and how it relates to the magnetic field has opened a lot of doors.
    Its the big picture
  • MonsieurM
    MM thanx Im watching the vids now, very interesting
  • MonsieurM
    There is a test you could run...it may seem weird...but you'll have spin...
    just hear me out...a dc pulsed Rodin coil with a spinning neo ball in the middle on top of your water to freeze.....
    Antigravity Part 5 - The Vortex Coil (How to built) - YouTube
  • Dave45
  • Dave45
    interesting short videos
    sciencetosage's Channel - YouTube
  • MonsieurM
  • Dave45
    It will be a superconducting electron pump.
