I made this cell with pvc, if you heat pvc with a heat gun it gets very flexible, but it could also be done using boiling water Im sure.
The A vector field is purely electrical, the reason I know this is because it cut through the ice.
The lines in the ice were cracks, the electrical field couldnt flow through the pure ice so it cut lines, cracks.
So Im going to use an electrolyte to get it to conduct, I'll be using KOH.
Here's the setup I used before
Originally posted by Dave45 View PostYes the cone coil should be made to the specs of the golden ratio, I used a funnel that I had, it should work for experimentation but in the final version it needs to be made in the golden ratio.
Do not overlook the size of your water container either, if you want an optimized ice vortex...
besides you want it to work both ways like a Tesla Coil as an emitter and a receiver...you need the vortex coil to be in perfect resonance with the ice columnLast edited by MonsieurM; 09-12-2011, 10:39 AM.
This hit me as soon as I woke this morning, if the A vector field runs through the core of the toroid We should be able to tap it with the ice cored toroid.Originally posted by Dave45 View PostIt would be interesting to see a rodin coil in ice, but the A vector field runs inside the core of the rodin coil,inside the doughnut, now to make a superconducting ring for antigravity
But for free energy we must us a vortex coil wound like Tesla's bifilar pancake coil. Im building one now and it easier said than done, one failed attempt so far, but I'll get it.
Now I tried this back when I was using dc to form the ice, I will try it using ac.
Yes the cone coil should be made to the specs of the golden ratio, I used a funnel that I had, it should work for experimentation but in the final version it needs to be made in the golden ratio.Originally posted by MonsieurM View Postnote there is a direct relationship between the volume of water and the vortex coil...(search cones and cylinders golden ratio )
This is a work in progress, I hope that once the energy is flowing through the ice the freezer will not be needed, it should cool itself by magnetic evaporation, time will tell and Im not in control.
Iv always thought I dont have to know how it works I just need to know how to build it, but we may get both
Originally posted by MonsieurM View PostOMG, Dave you know what you are doing....you are recreating the Tesla Coil....with the vortex coil as your primary and your result is the secondary.....I only thought of it when i saw your picture with the copper screen..
forget about the ball
Lets just hope we can bring it down to a useable form of energy. Once I get it working I have a transformer that steps down from 800 volts to 120 volts will give it a go.
The A vector field moves into the coil, it feeds the magnetic field
When you pull energy from a permanent magnet this field replaces it, this is where the magnet is tapped into the either.
If you notice in this pic the A vector field is shielded by the copper screen it wont form where the screen is, it moved above it.
If we can move it above the cone shaped coil it should collapse into the core instead of the windings=no bemf
old experiment with mobius caduceus coil, look at the fractures (if you can see them )
the black part is were it shorted
you can shape it and concentrate it
