  • Dave45
    Ok if you have two resonate coils connected using low voltage it should build a structured field between the coils then when used at high voltage the transfer should be increased this needs a lot more investigation I hope people with more knowledge and experience would take a look.
  • Dave45
    This is what I did I ran 6volts ac through the coil to a bulb, then connected the aluminum plate to a grounding rod and let it freeze about 24 hours
  • Dave45
    This means the column we'v been observing is structured water molecules that are conducting and the clear ice around the column isnt structured so it doesnt conduct.
    I wonder what this would do for the Don Smith device?
  • MonsieurM
    Ok Iv got news
    This is what I did I put a aluminum plate in the bottom of the container
    When I hit the coil with high voltage I get high voltage from the aluminum plate -- which is not unusual with high voltage but here's the kicker I get voltage nowwhere else usually the coil induces high voltage in everything around it but the ice isolates the voltage.
    Im so excited I can hardly type or even think this means the ice creates
    I'll get back to ya
    keep those great news coming...
  • Dave45
    Ok Iv got news
    I'll get back to ya
  • MonsieurM
    The Hydroplate Theory
    Red Ice radio - 31.5.2011 - The Hydroplate Theory, Cataclysmic Global Flood & - YouTube
  • shawnnweed
    Originally posted by shawnnweed View Post
    You have got to be kidding me...these dummies have no idea, let me help you get a visual of what is really there. In the days of noah there was a flood that covered the entire earth. The water was said to have come from too places above and below. Yet as we know the atmosphere can only contain so much moisture. The majority came from below. The earth flooded above the Ararat mountain which is above 17,000 feet(which is well more than 3 miles) and took more than 3 moths to descend just to the mountain top. But let us just say 3 miles as a minimum. Now multiply 3 miles of water by the circumferance of the earth in 3D then ask yourself in camparison to our oceans would not this much water make our current deposits, which cover 3 quarters of the earth, look like a mud puddle. WHere do you think all that water went? Back where it came from, in the earth. and they think it is only equal with our one ocean. You have got to be kidding me.
    And to top it all off they really beleive that this water is 'in' the mantle. The majority if not all the mantle rests / floats on top of highly presurized superheated water. Read any account of the record attempts at earth core drilling and you will see that mud mixed with high levels of oxygen and hydrogen always came speweing from the depths. If the core of the earth is made of metal i.e. nickel and iron and is superhot, even hotter than the surface of the sun then without that water to regulate the temperaure before it actually got to the earths crust this planet would be a desolate volcanic wastland if not a ball of bubbling gruel of matter. Any guesses to the volume of water needed to cool 13,000 degrees F before it gets to the mantle. let me put it this way the suface temp of the sun is said to be 10,000 degres F and the earths core is only 4,000 miles away; what if the sun was only 4,000 miles away with nothing inbetween us and it? Get the picture now?
  • shawnnweed
    as above so below
    Dave remember the info on quartz creating rifts and mountains
    USU geophysicist links quartz deposits to mountains and faults
    USU geophysicist links quartz deposits to mountains and faults | The Salt Lake Tribune
    try quartz dust with ice under emf , water has memory and expands when it freezes.....
  • MonsieurM
    MonsieurM,
    Here is a reproduction.
    The colloidal gold was a couple years old.
    Could not locate the same glass container.
    This has more of the radiating spikes from the center than is shown in the picture.
    This is a 1 ounce shot glass.
    Pure water - 0 TDS (total dissolved water) did not produce the radiating spikes
    IndianaBoys
    Team produces weird optical phenomena - and rewrites the rules of refraction | TG Daily
    The conventional laws governing the way light moves from one medium to another - from air to glass, say - predict the angles of reflection and refraction based only on the incident (incoming) angle and the properties of the two media.
    But while studying the behavior of light impinging on surfaces patterned with metallic nanostructures, the researchers realized that the usual equations didn't cover the bizarre phenomena observed in the lab.
    Essentially, the group's discovered that the boundary between two media, if specially patterned, can itself behave like a third medium.
    "Ordinarily, a surface like the surface of a pond is simply a geometric boundary between two media, air and water," explains Nanfang Yu, a research associate in Capasso's lab.
    "But now, in this special case, the boundary becomes an active interface that can bend the light by itself."
    What makes the difference is an array of tiny gold antennas etched into the surface of the silicon used in Capasso's lab and structured on a scale much thinner than the wavelength of the light hitting it.
    This means that, unlike in a conventional optical system, the engineered boundary between the air and the silicon imparts an abrupt phase shift - a phase discontinuity - to the crests of the light wave crossing it.
    Each antenna in the array is a tiny resonator that can trap the light for a given amount of time before releasing it. A gradient of different types of nanoscale resonators across the surface of the silicon can effectively bend the light before it even begins to propagate through the new medium.
    The resulting phenomenon breaks the old rules, creating beams of light that reflect and refract in arbitrary ways, depending on the surface pattern.
    read properties of water , it is in a previous post
    hint: water vibrates and memory
    see also: http://www.energeticforum.com/154661-post362.html
  • MonsieurM
    as above so below
    Geophysical measurements collected in the western United States USU geophysicist Tony Lowry says quartz is key to rock cycles resulting in large-scale deformation of continents. Image courtesy Tony Lowry, Utah State University.
  • Dave45
    Antimatter Spacecraft Propulsion The Future Is Now - YouTube
  • MonsieurM
    Signature of Antimatter Detected in Lightning | Wired Science | Wired.com
    During two recent lightning storms, Fermi recorded gamma-ray emissions of a particular energy that could only have been produced by the decay of energetic positrons, the antimatter equivalent of electrons. The observations are the first of their kind for lightning storms. Michael Briggs of the University of Alabama in Huntsville announced the puzzling findings Nov. 5 at the 2009 Fermi Symposium.
    water cycle
    The Golden Tractate of Hermes Trismegistus
    O Son, is but one in our egg; but this, in the hen's egg, is much less to be found. But lest so much of the Divine Wisdom as is in a hen's egg should not be distinguished, our composition is, as that is, from the four elements Adapted and composed. Know, therefore, that in the hen's egg is the greatest help with respect to the proximity and relationship of the matter in nature, for in it there is a spirituality and conjunction of elements, and an earth which is golden in its tincture. But the Son, enquiring or Hermes, saith, The sulphurs which are fit for our work, whether are they celestial or terrestrial ? To whom the Father answers, Certain of them are heavenly, and some are of the earth.
  • shawnnweed
    reverse the image 180 degrees
    This would make an interesting coil.
  • MonsieurM
    As the thunderstorm forms, it produces ice in the upper cloud. The formation of ice in a cloud is an important element in the development of lightning. Those storms that fail to produce large numbers of ice crystals may also fail to produce lightning.
    compare it to an image you are more used to seeing
    In a world made only of waves, there would be just two geometric forms, the torus, or vortex, and the golden mean spiral. the donut, torus, form is the only structure in a world of waves that can become coherent, that is, retain a regular shape like a smoke ring. As more of these smoke rings are created and they want to relate to the first smoke ring, they must "nest" in the right pattern so that they can remember their form and still share structure. the best pathway for doing this is the ratio we call the golden mean.
  • Dave45
