alrighty i am back in business.....it was the transistor after all that...have upgraded to the mj transistor that bedini uses....and it works at 12 volts!!! the light connected to the receiver works pretty good but the others not so good........i can barely read the amp meter something like 100-200milliamps
Detective Nat
You dont have a ground on the transmitter its the negative of the system. Also I dont think we can transmit energy untill we get up to 7Mhz scalarwave
frequency.
Tesla used spark gaps to do this, signal generates at that frequency are big money! thousands of pounds(aussie dollars).
I think patented 685957 is the one i will work to when i get my spheres its what the wireless energy is base on.
Untill then Im doing the energy attracted to the bulb Experiments.
Take Care All
This is what Detective Nat looks like
I have tried out the Imhotep relay radiant oscillator and can run it down to around 7mA with the help of a magnet on the opposite end of the relay pole piece. The type of diode makes a lot of difference and I found that a UF4007 worked a lot better than an IN4007.
The charging is good for such a low powered 'buzzer' type oscillator and I could see no spark damage to the contacts over a long period of running.
This is a Bedini SG style charging circuit with the relay contact giving fast leading edge pulses resulting in good radiant energy production. I think that this circuit could be paralelled up to produce a more powerful charger.
Another observation is that charging can be improved by increasing supply voltage with virtually no change in supply current and no sign of contact arcing even in a darkened room.
Hoppy
Thankyou Hoppy and Agongon and everyone here for your input. Every reported observation helps others to discover more!
I just want to share my findings. The attached photo has details. I haven't put to use the voltage spikes yet.The nameplate of the fan says that it uses 300 mA[0.30A]of current as per original configuration.
Regarding the sheeting of the capacitor that means a very thin layer of silver above the dieletric plates of the capacitor to limit the vortex losses.
New idea: try to rotate your sphere on the roof. Second idea could be to put a helical part inside the sphere so you have one primary receiver and then the secondary is the helix where the dielectric current really becomes massive(read free energy secrets of cold electricity by Lindemann, really good read AFTER Meyl). As far as I understand counter rotating vortices are the building blocks of the universe. A sphere rotating slowly and the helical inside rotates quickly in the other direction. Compare with the Wimshurst machine, counter rotation is the key and only one direction will work. Maybe you could attach some wings to the sphere and use the wind to get rotation. Just an idea.
" A very effective battery conditioner / charger should be possible at low cost by modulising to increase power. " Hoppy, Thank you for sharing results of your experimentation. I see this relay charger as the most practical/low cost item right now and it can be found anywhere in the world and can be built even by people who even have no idea what an "Ohm's Law" is.
" Agongon--I like your new circuit diagram. I'll have to try it. " Lidmotor, Yes Lid, that's precisely why we are here. We try until we all succeed. The world is our laboratory and humanity is our inspiration. Goodluck to all your experimentations.
" And after reading his[Meyl] book you will not microwave anything that you eat - ever again.... " Gauss, Thanks for this info. I am reminded again and my community.
" ABSOLUTELY AMAZING ~ and only using 8mA...!!!" byjoveoldchap, Wow, considering its size. This relay charger is something that's worth experimenting more, cheap, only 4 parts basically and you have the system running...and parts can be found easily anywhere in the globe.
" I do want to spread a word of warning the back rush of energy is much stronger than that of the fan or the IROL, so please exercise caution. It will give you a good buzz."---Imhotep
Indeed, the imagination(creative power) is the limit. Goodluck everyone
Many THANKS to everyone here...the future is suddenly looking much brighter again.!!!
Nat read your messages
the future is teslas so smile all the time
everything is going to be fine
we are working to a goal and that goal is freedom for all
Thank for all the work you are doing if you where not here i dont now what i would do you a very important person to me
by the way i was born in 1971 too
37 is a good number dont you think
@ALL can someone tell me what a eddy current is?
fly like my bulbs too.
RE: TESLA'S WIRELESS TRANSMISSION of RADIANT ENERGY
The receiver circuit is basically as shown in the patent. An insulated sphere connected to an identical ignition coil with the negative connected to ground. The positive and negative terminals are connected to the light.
The transmiter circuit is basically as shown in the patent. Using the same circuit we have been working on but with no ground and no charging battery...and a insulated sphere. And no CFL's connected.
The insulation on the sphere is the key to it all.
So the parts you will require are:
2 x identical hollow high polish metal spheres insulated with clear arcylic paint - 3 coats. Mine are 8"
2 x ignition coils the same model...any model
1 ground connection. (maybe 2 if you build your own coils or want to experiment further)
The theory that i have read advises that the shape of the sphere is important. The stainless steel ones are the cheapest. I recommend you purchase them rather than trying to put some thing together. The sphere is found everywhere in nature.
