  • Inquorate
    ''the earth in all it s appalling immensity is nothing more than a small steel ball'' - I know what you mean re waiting, but I'd also like to vary actual individual pulse times as well: I think energy aback is instant. But might take time to impressively accumulate. Days even, according to the earth arial article someone posted on stubblefield thread. The caps are sometimes in the microwaves, they are screwed onto housing next to transformer. I can spot them now by screws on the outside. I also have 55farad 2.5v caps.. Etc. Lots of toys to play with.
  • nat1971a
    Interesting experiments you guys got going there....quite odd with the large cap.....
    I thought i better clarify what i meant by radio interference just in case people want to replicate it...it completely knocks out radio reception....all that you can hear is noise.....nothing from the radio.....then when you turn the system off...it goes back to normal......
  • Bodkins
    Great Stuff Inquorate
    I once took my scope to work
    Will be pulsing my EarthCoil soon,I think we are coming to the end of the first chapter
    Inquorate,
    Try pulsing to Earth for a set time then switch it off and wait for the energy to bounce back.
    What Im saying is read the potenical difference of the earth before you start then pulse for a time,Stop,read the potenical difference again and monitor it for a bit.
    Once you get postive reading pulse the energy back again.BUT be careful if you Pulse it back too must you may get a shock or two!!
    Remember Tesla fryed a power station?
  • Inquorate
    pulsing dirt and using feedback..
    Ah, sweet sweet progress. I'm even taking this stuff to work now. Anyhoo, pulsing earth: preliminary findings very positive.
    YouTube - Inquorate 3
    YouTube - Inquorate 5
    YouTube - Inquorate 6
    YouTube - Inquorate 7
    YouTube - Inquorate 8
  • nat1971a
    My setup is creating interference on the radio and stopping the cd player now....so i can see what happened to gray...he got shut down pretty quick because of it.....
  • nat1971a
    Gray was using 2uf 4000vdc caps
  • nat1971a
    i havent tested this but i think this is the next step based on this info. We just need to be in the zone!! So i am guessing he means the capacitors.
    http://radiant.100free.com/zpe_gray.html
  • nat1971a
    8" TESLA COIL VAN DE GRAF SPHERE DISCHARGE GAZING BALL - eBay (item 220308890876 end time Nov-18-08 13:40:57 PST)
    spheres from here or bodkins posted a link several pages back
    Gazing Balls at Online Discount Mart
  • Inquorate
    Where did you get your spheres?!!! I've been wanting to oscillate a metal sphere for ages but can't find any. The sphere shape restricts electron movement so should help only release pure voltage..
  • Inquorate
    Ps I was measuring voltage difference with respect to ground.. It was higher than voltage diff from primary neg and secondary pos, which was a mere couple of volts. Also, when it was off, ie negative to battery disconnected - I touched positive and meter showed 3v.. Thought that was odd, as ignition coil not oscillating so should show zero?
  • Inquorate
    Last night I was working with a double contact relay and ignition coil. One contact when in default on position would trigger the coil in relay to open the switch, turning it off - where it would then return via the force of the little internal spring to 'on' position. I had intended to have the other contact going off-on being setup in same manner but instead driving ignition coil primary, not relay coil. I accidentally wired the negative from relay coil thru (backward facing 1n4004 diode) to pos of ignition coil, and pos of relay coil to 90v neon to neg ignition coil. and I had a 1000v diode from ignition coil secondary to ignition coil primary negative. the system produced only 60v when measured from primary negative or secondary positive, and barely lit neon to ground. But it barely registered current draw on amp meter. My relay is made of clear plastic; lots of sparking on contacts. When I realised low voltage was because I had wired it 'incorrectly', I disconnected negative wire to relay and got up to walk away. Then I noticed the meter still connected was showing negative 1 volt. When it got to negative 10v, I got my camera ready. But when I returned, volts were back to 0. Don't know if I disturbed anything? I'll try it again tonight and try get it on video...
  • Bodkins
    YouTube - Bodkins 22 energy tennis
  • Bodkins
    I dont now where to got with the spark/ground stuff do we keep it here? but this is imhotep light stuff if anyones new to it they will be lost??
    Forget that next video uploading to here!!!!
  • nat1971a
    i have been tinkering with my new discovered spark gap....quite odd....i put in place a proper solid brass sphere spark gap....and it doesnt work...however if it connect only one up...everything on the bench starts to hiss
    then i went back to my magnet wire spark arrangement and place them close to each other with two connecting....now they glow purple in colour....like a plasma colour....
    am starting to wonder if this is what tesla refers to as the weak dielectric he mentions in the radiant energy patent and others
    now its making the cd player stop when on
  • Inquorate
    Hi guys. I've been conversing with bodkins on page 2 and 3 of earth battery thread, gotten off topic. There's details there relevant to radiant oscillator thread and water spark plug thread. :-)
