Greg, you should be getting carbon credits for that Bro. When we did the hydroxy we showed 67% less hydrocarbons, which in fact attack the liver and cause cancer. That modification alone is a great success Greg. Absolutely beautiful to watch man.
Sincerely
Ash
Water Sparkplug
condensation
Hi Ash,Originally posted by ashtweth View PostNICE Greg!!
I bet that engine will last longer and it will run cooler obviously with the steam injection and get almost the same benefits as the hydroxy. If Bugs came off the production line like that ill take 5 of them
Even when you rev the engine, if you hold a piece of steel or aluminum in the exhaust stream water condenses and dribbles off!
I know my thermal efficiency is up because I still have the same compression ratio ... of course ... so my (p1 - p2) / p1 is the same, my exhaust temp is just way down. I bet I'm producing very low NOx's.
It sounds throatier than normal ... some things are definitely different ... very peppy though.
Greg
thanks
Thanks Aaron, I appreciate your words.Originally posted by Aaron View PostWow Great!
You're work is very inspiring to me!
I have a Datsun 240Z with a 2.8liter in it with a 240 head for higher compression...it is pretty souped up but I wrecked the car racing.
Anyway, I think this coming spring I might pull the engine out and junk the car and just put the engine on a test stand and do these mods.
I would hope to see more duplication attempts on gas generators since there are a lot fewer variables to account for. The lawnmower Peter and I was using had the rip cord attachment break so we couldn't do much with it. I'm just itching to get back to the experiments.
Greg
NICE Greg!!
engine
Wow Great!
water spark plug + steam test begins
Hi everyone,
I built and installed a water system today. It is very simple and introduces hot steam into the inlet air. This keeps the inlet air warm- guaranteeing good mixing between the air, gas vapor and steam water vapor.
I did some highway driving and more back road and around-town driving before topping off the fuel tank and taking the odometer reading. Of course I checked the plasma system to make sure all was fine with that too.
The water addition rate is about 2 drips every 3 seconds. For the record my odometer reading is 35987. I have no idea how many times it has actually flipped.
Kinda' looks like my Bug is on an I V Drip ... hope it survives !
I have linked six (6) pictures of the installation.
Peace,
Greg
-overall picture
-shows holding tank
-shows sight glass (vinyl really) & needle valve above
-shows water line entering hot carburetor air inlet tube
-shows water line on inside wall of hot air inlet tube
-shows the hot exhaust pipe that the water drips onto
Hi Ansis, I know the guy well, he has already shared his stuff with us allOriginally posted by Ansis Freimanis View PostI have one question. Is your setup with limited quantum of gasoline or you put in your "bubbler" more gasoline after some time? Is it system with pump?
In You Tube user "jopinoypower" are making very advanced car.
YouTube - jopinoypower's Channel
I think he can share with us his knowledge. I send a letter to him- about our forum.
Thank, You!
Down load this document
Now, look at the bottom for PDF -water mist and fuel vaporization research (its at the bottom , your looking for a PDF). Now Jo's stuff is called genesis
HC cracking system + Plasma Ignition
Thanks Luc,Originally posted by gotoluc View PostHi revizal,
If you can test with Diesel it would be better.
Luc
I believe with appropriate process we can crack a long chain HC to get better combustion. Or we can increase the octant number of gasoline (because gasoline easier to vaporize and pass the catalyst by engine's vacuum) before entering plasma ignition zone. But yes, cracking diesel is better than gasoline.
I'm still thinking the best way to vaporize diesel and the setup will be:
Diesel vapour ==> thermal catalyst ==> leaner AFR ==> plasma ignition
or even:
water vapour ==> thermal catalyst ==> leaner AFR ==> plasma ignition
I think the closest point that we will catch is getting better MPG.
Rev.
Hi Luc and all,. i just noticed what an ass i made out of my self with the out of focus snaps, will take some more snaps today and get the values sorry guys :P
Hi Ash,Originally posted by ashtweth View PostThanks for the report Revizal. Here is the plug wear report on your circuit running with Wouter's WFA booster. We dropped the dump cap down
from 50 to 30uF.
Seems like not allot of wear, this were the same plugs, so if you compare this to the last photo in the PDf, there does not appear to be significant wear, but we noticed not as much power, so its
still a trade off.
We have some new plugs to try also.
ImageShack - Image Hosting :: 0001139fg9.jpg
ImageShack - Image Hosting :: 0001138ox8.jpg
ImageShack - Image Hosting :: 0001140mc1.jpg
Ps, we got some strange carbon or some thing on the top of the plugs.
ImageShack - Image Hosting :: 0001141ay7.jpg
Ash
thanks for posting the new picks
I can't see the difference from the previous so I'll have to take it from your description.
The last one looks like a carbon build up from a loose contact
Could you post your previous charge voltage and cap size with this new test charge voltage and cap size so we have a record of it.
Thanks for sharing
Luc
Hi revizal,Originally posted by revizal View PostHi All,
Similar as what Greg done (very nice experiment
), I made an experiment on my SUV with 'semi geet setup'. I used 100% gasoline in the bubbler and it's 300 km running now with this setup. Just look like air bleed to the engine, I introduce the fuel vapour at two lines (the top of air filter and inlet vacuum after the carburetor). At this time I used stainless steel wire as the catalyst (need trial and error change the catalyst to see the different effect on cracking Hydrocarbon chain by thermal catalyst).
So far, the engine runs very well. I could increase the speed easily. I donot know the MPG yet (may be after the fuel tank empty).
Right now, I'm still using standard CDI from the car. Later I will introduce our plasma booster ignition on this setup. We'll see the effect on power and MPG...
I like your setup idea
If you can test with Diesel it would be better. The Oil Mafia
oops, I mean Companies have been adding chemicals in Gasoline to prevent fuel cracking. I believe Diesel is not altered yet. They change the chemical additives in Gasoline up to 4 times a year, so if you had a GEET vehicle you would need to re-tune the reactor rod every time the additives change. Also, if you traveled from State to State you would also possibly have fuel additive changes, even changing from one garage Company to another can get a different blend. This is the number one reason the GEET system has never taken off in America as Diesel is not the Fuel of choice for cars! ... Gasoline is. I think they are trying to keep it this way also since for the last 2 years Diesel is higher priced than Gasoline and is now up to a $1 more per U.S. Gallon. Before this, for as long as I can remember Diesel use to be less than Gasoline.
The GEET has really taken off in France and the main reason for that is Diesel is the number one choice for vehicle fuel. They are years ahead on GEET Diesel development. I know about this because I researched it a year ago and French is my mother tung.
One way or the other Diesel has more energy content. Not much difference than Jet fuel.
Great work revizal and thanks for sharing.
LucLast edited by gotoluc; 11-25-2008, 03:03 AM.
The Basic principal is a fuel vaporizer
Hi Ansis..
Yes. The basic principal is the same as air bleed on that fuel saver. I put some gasoline that will sucked by the engine vacuum. With additional catalyst (thermal cracking) and a plasma booster ignition may be we could reach leaner fuel combustion. I do not know the number (1 : 30 as above disscussion ???) But so far just on standard ignition system I feel the power boost.
Rev.Last edited by revizal; 11-24-2008, 08:49 AM.
from 50 to 30uF.
still a trade off.
Ash
Hi Ash,
OK. It seems better. With smaller capacitor instead of 47 uF (I choose 10-22 uF), I will use it on this SUV. I made a testing setup to test a plasma booster out of the engine that make me able to test each plasma component for some period of time. I used simple DPDT relay to own pulsed it self, car coil, and 9.9 uF (3x parallel 3.3 uF 400 V capacitor). The plasma effect looks good and I could use only 25 watt bulb as restriction with enough Amp injector to the circuit to charge the capacitor.
Some of link on the internet say about catalyst which can crack the long chain Hydrocarbon to shorter HC. So I can use different catalyst to pretread gasoline from the bubbler before entering ignition chamber.
Nice long experiment Ash. I'm sure your result is very usefull to make important progress on this research. Thank you.
Revizal.
to Ash
I am sorry, but picture quality is very "poor".
If it is possible, maybe we can hope to see better pictures?
I am very sorry....
Thank, You!
Hi, Revizal!
Thank, You!
