3 Battery Generating System
  • Turion
    Info
    There is a wire from the + output of the boost module to the motor. That is ONE of the wires on the motor. There is a SECOND wire on the motor, which (on the single battery circuit) goes back to the only battery, and in the 3 Battery circuit goes to the charging battery.
    The output of the boost module, which is 2 volts over the standing voltage of the battery (that will be CHARGED) goes into the motor and OUT OF THE MOTOR down that SECOND wire, and back into the primary battery, hitting it with a higher voltage charging spike ( because the boost module has raised the voltage) over and over and over, just like a battery charger would do. There is NO boost module on the wire that comes OUT of the motor and goes to the charging battery. The boost module is in the circuit BEFORE the battery.
  • Aaron
    Luc Choquette - Gotoluc is a fraudster
    Bi,
    Those replications were NOT representative of our work. I have covered this MANY times with you. But since I have some free time tonight, I will go over it again. The system we showed was NOT designed to run your house but was only designed to PROVE these concepts work and set people on the correct path. It is a BUNCH of little things that add up to a working system. If any ONE of them is incorrect, it won’t give the proper results.
    I will talk about the 3 Battery system first. Problem 1.The batteries used in the “replications” were far too small. Luc was TOLD it wouldn’t work before he even started. His response was that those batteries were all he could afford and if it worked, THEN he would invest in proper batteries. If you go back and look at my comments at the time he started his “testing” you will see my comment as well as his response. Small batteries just have TOO MUCH resistance and we have said that a million times. They WILL NOT WORK.
    Problem 2. A modified Matt motor was NOT used. This means the battery that is being charged was not being pulsed at ALL. Even people who use the boost module fail to understand that it pulses at the WRONG frequency. Without the Matt motor you are NOT hitting the 3rd battery with a PROPER charging pulse. It is a mechanical switch that ALSO does work.
    Problem 3. A boost module was NOT used which means the voltage hitting the charge battery wasn’t at least 2 volts over the standing voltage of that battery. You can’t charge a 12 volt battery EFFICIENTLY with just 12 volts. And as the battery charges and the voltage in the primary batteries drops LOWER, without the boost module in place you are trying to charge the battery with a LOWER voltage than what is in it.
    For ALL these reasons the testing done was NOT a replication of what we have shown. It was CRAP.
    Back in the day I posted DOZENS of You tube videos of results of test runs. I pulled everything down at one point when we decided we had shared enough.
    Luc Choquette is a liar, con and charlatan - what do you expect? He has so many people fooled into thinking he is some humanitarian that wants to help the world, but I have the emails proving how greedy he is for money - and for something that he did not contribute to!!
    When he was approached by two people asking who invented my plasma ignition circuit, he told them he was the inventor then they filed for a patent - and Luc was well aware that I was the sole inventor. He didn't even understand how it could work and I have all the emails and online posts to prove it - I had to teach him how my method worked.
    So, when it comes to real work with any kind of integrity, everyone would be wasting their time thinking that Luc Choquette (gotoluc) is offering anything honest, without an agenda, etc. this is indisputable and I have all the proof in his own words going back 10-11 years!! Luc is a dead end and anyone that keeps pushing the idea that Luc has replicated or shown anything legit probably has a bogus agenda of their own.
  • bistander
    No 3bgs
    Turion,
    I was talking about the Matt modded motor only and the test they did on the motor. I've mentioned a number of times that I don't care about the 3bgs. I replicated your single battery dual boost converter circuit and am interested in that. I was chastised, insulted, and called names because I didn't use a Matt modded motor. I still believe that the boost converter negates any charge pulse from reaching the battery so I want proof that a Matt modded motor can in fact positively affect a single battery through a boost converter per your circuit. The motor tests which tinman and gotoluc ran and posted indicate not, but you and Matt claim it does. So I am asking for evidence. I'd like to see data from you or Matt on that single battery system using two boost converters, or a scope shot of a real Matt modded motor to compare to the one which I posted today.
  • Turion
  • bistander
    Differences
    Bi,
    The data Tinman and Luc provided was not from an actual replication. If you think this makes no difference I invite you to spend the year 2019 driving around your washing machine rather than your car
    Turion,
    What is the difference between what they tested and an actual replication? Why is there no data available for an actual replication? Those of us who know motors and electric circuits believe those tests were representative.
    Please explain in detail what the differences would be of a similar scope shot from an actual replication and this one lifted from a video done by gotoluc.
  • Turion
    Data
    Bi,
  • axxelxavier
    Originally posted by hherby View Post
    Hi axxelxavier,
    You can use a VOM1271T Photovoltaic MOSFET Driver for high or low side switching in a single or bi-directional setup. See the top of page 5 of this data sheet.URL="http://www.vishay.com/docs/83469/vom1271t.pdf"]http://www.vishay.com/docs/83469/vom1271t.pdf[/URL] Worked great for me. A reasonably cheap way to build your own high power SSR's.
    Alex
    Hy, Alex.
    Thank you for your reply. I don't know much about this driver - I have to search the internet to see if it is capable of switching DC/DC voltage, or to isolate readings from dc voltage.
    As far as I know, SSR works only with AC voltage, but right now I am using only DC voltage.
    Best regards,
    Teodor
  • hherby
    Isolated n-Mosfet driver
    Originally posted by axxelxavier View Post
    Unfortunately, because of the common ground issue, I cannot use n-mosfets on lower side, nor p-mosfets for high side, and i don't know other way to switch the batteries with a galvanic isolation.
    Any suggestion? Is there other way to reverse polarity using discrete components?
    Best regards
    Hi axxelxavier,
    Alex
  • bistander
    Why?
    I told you effectively the power returned to the smoothing caps after the diode is not drawn from the top battery. The recovered energy is delivered to the charge portion of the battery after rerunning through the motor. This is a plus in total energy recovered. While keeping the motor running at high RPM's. You had a chance to test n this with minimal amount of work and very little financing similar the tests Gotoluc did but you declined it. Why? If you know how everything works and you know so much why then do you refuse to back it up. Why not take a look... Why not back up your poor excuse for a mouth with real data? Its just copper losses after all why not prove it? Its just whatever bull$hit anyone else chalked it up to being. Why not prove it with no cost to yourself.
    I know why, cause its easier to talk than to research, and your just one of those kind of people.
    None of you can even imagine the possibility in that little circuit.
    Gotoluc and Tinman already ran the tests and presented the data which support my position. And there is just one battery. What do you mean by top battery?
    I built the one battery circuit just like Turion drew it, tested it and presented the data. I am still waiting for you to do that as you said you would.
    Regards and happy holidays,
  • Matthew Jones
    Thank you Matt,
    This is what I've been talking about. The current pulse never reaches the source battery due to the presence of the boost converter. Hence my question: Why did I need to use your modded motor in the 1bgs system which I built and tested?
    Like you told me here.
    Cheers to you,
  • wantomake
    The Box
    Axxel,
    I like the video even though can't see your build. But I think it's a good start to more exploring and growth.
    Had to go back to my bedroom and send this, family wrapping gifts and told me to leave, hahaha.
    Anyway I like the build with the box and good looking voltage meters in front.
    Holidays and family has kept me out of the shop for now.
    Merry Christmas to you, thanks for the video.
    wantomake
  • axxelxavier
    I will try also the single battery circuit when I will have a second motor as generator. Main problem for me is the noise - I live with my family in a 2 room apartment, so I cannot run during the night anything noisy... So I HAVE to use something solid state or very silent...
    This is my beta version, here:
    https://youtu.be/hMYU4_T0DU0
    Everyone, Happy Holidays, health, joy, and successful green energy projects!
  • wantomake
  • axxelxavier
    If I keep this thread alive it's because this project is worth the effort.
    wantomake
    I agree!
    Finally, I have some time for my project, so I will post some updates.
    I decided to give a try to 3BGS automatic switch project, though I am aware it will be a long and difficult process. My previous system was with 2 batteries and a boost converter, but after some tests in 3BGS configuration, the results was very encouraging.
    First step was to create a semiautomatic system for switching the batteries, using for the beginning 4 push-buttons, which will command Arduino to switch 8 relays (12 volt each, actually 3 relays at the time). I am using now just 3 x 5 Amp batteries, and a fourth battery for Arduino and relays.
    Well, this is my first result, as you can see also in the video.
    https://youtu.be/9iEPh9Jon1w
    The system is working, BUT, in one configuration (Battery 2+Battery 3 charging Battery 1) the polarity of the load is changing, so the + pole become „-”.
    The only way I find to solve this is to add another 2, maybe 3 relays, which will increase the current draw to 150 - 180 mA... For bigger setups, up to 60 Amp batteries, I think is worthing this current draw. Later, when the system is set, I can use latching relays, and the current draw will be very low. The total current draw, now, at the arduino + 3 relays ON is between 120 mA (at 12 volts) and 100 mA (at 10 volts).
    Second step is to find a way to isolate the voltage divider resistor readings for sending to Arduino - I cannot use a common ground for those dividers, because of the different configuration of batteries connections.
    I was thinking to use optocouplers... what do you think?
    Best regards
  • wantomake
    Holiday Season and generators
    Good rainy morning to All,
    Coffee, rain and holiday shopping. My daughter asked what I wanted for Christmas. So we finally settled on a spool of mag wire to rewire the larger size my1060 scooter motor as a generator. Good gift I think.
    After the holidays wind down I'll be hopefully redesigning and testing like Turion posted.
    Time to nuke the coffee or head to breakfast with the wife.
    Yes breakfast and good company.
    wantomake
