3 Battery Generating System
This topic is closed.
Incredible accuracy.
The Kibble balance avoids the problems of measuring B and L with a second calibration step. The same wire (in practice, a coil of wire) is moved through the same magnetic field at a known speed v. By Faraday's law of induction, a potential difference U is generated across the ends of the wire, which equals BLv. Thus
U=BLv.
Single battery circuit
To all,
Will setup the 3BGS today while looking at the SBC single battery circuit Dave posted.
Will try something Dave said per email. Want to try something with 3BGS first before trying the SBC on my work bench.
Only have one boost module left over from this summer's testing. Smoked my other one during that time.
Not wanting to keep this thread alive or create any new interest here. Just thought to drop some lines and say I'm still having coffee mornings and thinking about this system.
wantomake
Wrong battery again
Update.
Did try the 3BGS setup as per Dave's email today. Tried my old lithium battery packs I built, but the packs sit too long and lost too much amperage. Therefore will move three marine batteries over to try.
Nothing new to post but still trying to get back to testing and such.
wantomake
hi all. just wanted to add something. just an opinion, but i think it's important to remember that a load and a charge battery in series is always a voltage splitting combination. motors with load/no load are pushing back on the current flow,proper bemf, with varying force and batteries have varying levels of resistance depending on degree of sulfation,state of charge etc. i've often wondered if this is why 3bgs and derivative systems are hard to keep in balance, because the voltage across the motor or battery will fluctuate due to each other.
hopefully i'm not being captain obvious and a goose, but it seems like a critical aspect to me.
cheers.
Voltan,Originally posted by voltan View Posthi all. just wanted to add something. just an opinion, but i think it's important to remember that a load and a charge battery in series is always a voltage splitting combination. motors with load/no load are pushing back on the current flow,proper bemf, with varying force and batteries have varying levels of resistance depending on degree of sulfation,state of charge etc. i've often wondered if this is why 3bgs and derivative systems are hard to keep in balance, because the voltage across the motor or battery will fluctuate due to each other.
cheers.
You are very correct. Dave has said the same thing many times and my own experience backs that up. You can't just throw something together and expect to get the same results Dave and several of the rest of us have gotten. You have to take the time to study and learn the system and that will lead you to learning how to keep everything in balance. If you don't do that you will get poor results. And it doesn't hurt to be reminded of that from time to time. Thanks for your thoughts.
CarrollJust because someone disagrees with you does NOT make them your enemy. We can disagree without attacking someone.
Balance
Hello citfta,Originally posted by citfta View PostVoltan,
Carroll
First. Just a simple question. No drama from others, if you know what I mean.
To me, balance means or implies adjusting or tuning. When I built the single battery, 2 boost converter circuit and tested it, it did require tuning. With it, I had the 2 boost modules, each with adjustment and the load resistance value which I could choose. Balance also infers a process of getting some parameters within a certain relationship. With the system which I built this was simply stability; that is to stop the hunting. It was a feedback system and exhibited classic feedback symptoms.
As I understand the basic 3bgs system, there is no tunable converters and the only way I can see to balance the system is to adjust the load. Is that correct? And then, because the load is not fedback to the input, stability should not be a big issue. So what parameters do you monitor to balance the system and how would that be done in practice where you have less control on the load?
Hello bi,
What I found was as you have stated the most important part of the system is the load on the motor. As Dave has said many times most of the replicators that failed tried to do too much for the size of the batteries they were using. As you well know batteries will only take a charge at a certain rate determined by the condition of the battery and the capacity of the battery. Trying to force too much charge into the battery that is being charged will only result in more losses.
And as we also proved to ourselves many times, pulse charging the battery is a more efficient way to get charge back into the battery. In fact I just recently bought a commercial charger that uses pulse charging to condition and recharge the battery. The modified Matt motor gives us the pulse charging going to battery 3.
By keeping your load low and pulse charging battery 3 you WILL get longer run times than if you only ran that same load on the 3 batteries connected in parallel. As battery 3 gets charged then you swap it with the lower charged battery of the other two. And you keep doing that, recycling the energy from the batteries by charging one while discharging two. Of course the system will eventually run down so you need some means of recharging the batteries when that time comes.
This is NOT an overunity system. It is just a much more efficient way to use the power in batteries. Dave and I have a friend that used to live in Tennessee. He was living totally off the grid. He was using solar power to keep his storage batteries charged. I visited him and saw his system and very small home. When he started using the 3BGS he was able to run his loads much longer by recycling some of the energy into recharging the battery in the 3rd position. He gave very high praises to Dave and the 3BGS because it allowed him to do more with the system he had. Most of the time his loads were not pulse charging battery 3 but he still got more run time from his batteries.
So the "secret" to the 3BGS is to keep your load small in comparison to the battery size. If possible pulse charge battery 3. And finally you have to learn when is the best time to swap the batteries. And all of this takes time to learn. Some extra batteries also help because then you can allow them to rest between charging and discharging. This also helps to make the system more efficient.
Respectfully,
Carroll
PS:I see Dave was posting the same time I was.Just because someone disagrees with you does NOT make them your enemy. We can disagree without attacking someone.
Balance
Thanks citfta and Turion,Originally posted by citfta View Post... When he started using the 3BGS he was able to run his loads much longer by recycling some of the energy into recharging the battery in the 3rd position. He gave very high praises to Dave and the 3BGS because it allowed him to do more with the system he had. Most of the time his loads were not pulse charging battery 3 but he still got more run time from his batteries.
citfta,
Did this guy ever measure or quantify his results? These successes always appear subjective to me. The restrictions like less than the 20 hour rate and battery swaps and rest periods mean a controlled test would require weeks with close attention. Otherwise, the fact that the 3bgs has significantly more batteries will yield longer run times not to mention the continual attention being a benefit to the 3bgs.
Back to the balance question, or answer, it looks like sizing the 3bgs system for the load is the only way. That doesn't seem practical for a home power system where the load is constantly changing. The primary purpose of batteries on home solar installations is to buffer or contend with varying loads, like night to day, or refrigerator or pumps cycling. So wouldn't the balanced 3gbs installation into an existing battery assisted home solar PV system double or triple the total battery count for the home owner?
citfta, are you using a 3bgs for anything useful? Is anybody here doing so?
You can take or leave it, but I've been involved with energy conversion and energy storage for 40 years. I've tested thousands of batteries and hundreds of motors and generators. I really like the modern Lithium based batteries and really hate the lead acid. I have no desire to increase the amount of lead acid on my property. In all of the testing on lead acid which I've done or studied, I've never seen more than a temporary improvement from pulse charging and never any indication of "running between positives" as beneficial. Just stating reasons that I'm not interested in building the 3bgs, as you always tell me to do. The only quantitative controlled test which I've seen does not support your 3bgs claims. Of course Turion objects to that test. All this time, has no one else instrumented and recorded data from a controlled 3bgs test?
Oh well, back to other stuff. Carry on.
Changed mind
I changed my mind. No more moving marine batteries around.Originally posted by wantomake View PostUpdate.
wantomake
I did build and test Dave and Matt's 3BGS with boosters and got the system balanced to retain same voltage during test runs. Saw it with my eyes and I know it works.
I did build somewhat of a version of Dave's upright generator and it did SUUL. That means it does indeed exist.
I only failed to join the two together in one unit. I know it would've been a wondrous thing to feel, see, and experience.
But my disease "if I take it all apart and build it bigger/better" took over. So all is dismantled and just collecting dust. What a shame.
No I'm not starting all over again. I followed directly the plan, took advice while driving Dave/Matt crazy, spent resources and put in the time.
Now I wonder what could have been with lots of time, knowledge, decent shop that doesn't leak rain water, monies, oh and just a little more love of the adventure of seeing Free Energy made real.
wantomakeLast edited by wantomake; 11-28-2018, 07:35 PM.
Data
Wantomake,
The fact that you have built it and seen it work is not going to be enough for bi. He wants hard data, which you have not provided. Therefore, you do not know for sure whether it works or not. Because you haven't PROVED it to him.
But that's ok. Just keep on doing what you are doing and that will be your reward.
