3 Battery Generating System
This topic is closed.
  • Comment
    • Balance and negative pulse
      Originally posted by ricards View Post
      bi,
      In the other thread you said you didn't want to discuss any of the battery systems.. yet here you are..
      I'm not sure what you mean by "Pulse current" If its the inductive discharge from the magnetic field collapse, the direction should be the same to the current that created the magnetic field. not how you drawn it.
      Hi ricards,
      Yes, here I am. I built Turion's 1bgs and never got any decent answers. So when I saw some talk of balance, I was curious enough to ask. Then just wanted citfta's opinion on something.
      Pulse current in this case is due the modification which Matt does in the motor. This mod shifts commutation to a point where the armature coils actually cross over to opposite polarity field magnets. For a short time (pulse duration) the motor operates as a generator with reverse current. Supposedly this reverse current pulse travels back to the source battery giving it a charge pulse, which I don't argue about. Gotoluc and I think tinman did video experiments with scopes to demonstrate this. I'll paste it below. My whole question here was about this negative pulse being blocked by the boost converter. Motivation stems from being skewered for not using a Matt modded motor in my 1bgs when I don't think it would have made any difference anyway.
      This is the pulse which Matt claims is responsible for increased energy.
      Screenshot from: https://www.youtube.com/watch?v=hYcg...be&app=desktop
      • Good point
        Good point. Don't forget arcing can complete the circuit when breaking inductive circuits. Ever put a scope on it?
        • Scope?
          Yes. Several hundred times. I have done hundreds and hundreds of tests on this system. I know what it is capable of and WHY. This is just a toy to get people to see that these principles are real. Build it or don't. I don't really care.
            Hi ricards,
            bi,
            I think you're being rejected and booted off because you insist that you know better yet you have only tried once.
            what are your intentions anyway?. are you here to look at this closely or discredit this?. or just killing time?
            what exactly are you trying to point?.
            maybe I can answer in a way that can satisfy you.
            • Comment
              • No lie
                You might as well claim to have built a flying saucer.
                Now with a stock off the shelf motor you MAY be able to get it to work if you tune the system, and I have posted instructions for that, but no promises.
                I have never said I built a 3bgs, just the single battery 1bgs.
                • Comment
                  • Saturday thoughts
                    7:45 am with heavy rain a cup of hot java to kick the brains and this thread to just sit, think and hope.
                    Turion I can't finish the upright Lenz free generator until early next year. I want to use something as a generator until then. Don't think the single battery circuit will produce without a lenzless generator.
                    Just wondering if anyone has had any attempts with other types generators? I do have several I could try.
                    Want to hear some ideas from any "builder" or thinking to build.
                    Thanks and time to nuke the ole coffee.
                    wantomake
                    • Comment
                        This is exactly what I said in post #4359. Guess I need to draw a picture. And this is how Matt has described the charge pulse from his modded motor. The blue arrows represent the intended path of the charge pulse current from the Matt modded motor back to the source battery. However there is a diode inside the boost converter which blocks current in this direction.
                        So you seen all the movies in which the power supply caps rise from the return current. Thats the same thing that happens to the boost converter. The cap loads up beyond the nominal voltage. While thats happening the controller will limit the duty cycle and the amount of current flowing out.
                        The amount of power returned to the cap is marginal at best because of the hysteresis in the iron. Also, the cause of the heat.
                        The arrows are technically wrong but at the same time the same effective action is happening, the battery is just distributing less power.
                        Its not hard to see if you put a scope on it. And not just selectively before you film.
                        I do not understand the on going insistence to keep doubting everything, but then again thats why I am not making attempt to have an ongoing threads. Most of you are too broke or too scared to step outside of your comfort and try anything.
                        • Back to the source
                          Thank you Matt,
                          This is what I've been talking about. The current pulse never reaches the source battery due to the presence of the boost converter. Hence my question: Why did I need to use your modded motor in the 1bgs system which I built and tested?
                          Like you told me here.
                          @BI ... Thats modified motor which you have no experience with at 24 volt runs about 1.5 amp no load. The jumpy current is because the motor discharges back to source, a good portion of we put in it and the BEMF. ...
                          Matt
                          Cheers to you,
                          • Originally posted by wantomake View Post
                            wantomake
                            Hi James, I am working on a permanent magnet motor / generator very much similar to the South-African developer's version described here:
                            http://free-energy-info.co.uk/SChapter6.pdf
                            Apparently, the generation effects sought for are achievable without using a magnet rotor, but I was planning on using one anyway so that I could visually see whats happening. At the moment, however, I AM too broke to do anything - waiting on enough funds to afford super glue to keep those magnet bullets in place.
                            Recently had enough motivation to go through my windmill / solar battery system and throw out about 20 bad batteries. Almost all of them have internal shorts that cause them to heat up and suck all the voltage out of my system.
                            I did want to experiment with a solenoid motor / generator by converting an old china diesel motor to a one lung solenoid magnet motor. I had wanted to incorporate extreme repelling force of caps charged up to several K.V. then discharged into coils. You can find demos of this tech from Ismael Aviso from the Philippines [VIDEO]https://www.youtube.com/watch?v=fxA6fDe3J6c[/VIDEO]
                            [VIDEO]https://www.youtube.com/watch?v=7eCsVPmEjyQ[/VIDEO]
                            and Dimitry from Russia. But I realized that most of the mechanical energy released will be ate up in internal friction of the engine, with not much left over to use to drive a generator.
                            I don't have any suitable motors to modify for a Matt-motor conversion, or proper voltage dc-dc converters to try the 3bgs system. But I would like to at least achieve some success in one of these systems before I die.
                            • Parts
                              Turion,
                              You are correct. These are the parts I have:
                              1 modified Matt motor 1016
                              1 rotor you sent me with magnets
                              1 coil wound to specs
                              1 boost module 10 amp
                              1 threaded axle with various nuts and such
                              Of course hardware and such no problem. Mostly the upright vertical holders is the most expensive for this build.
                              wantomake
                              • Feel your pain brother
                                Ken,
                                Thanks for the link. I understand about the battery banks for the solar. Strange as this sounds, some of my batteries are over 8 years old. I've used them in the 3BGS setup and that sweet pulsing kept them healthy. As long as I watched and kept electrolytes healthy the batts were good.
                                As far as the generator goes I'll see what happens with the upright. I also want to do this exactly as specs are posted here to see this baby turn out some power. Power for what you ask....my space ship of course.
                                wantomake
