  • lerameur
    Hi,
    There is a two semi circular magnets inside, so I guess it is a 21 pole and two stator. 2 wires for input and two opposite wires for output. Hope to fix the problem at output. How mush would you suppose I get out in watt?
    Similar to this one on your web site but with 21 poles instead of 10 poles:
    The rotor in my motor is not 100% balanced, therefore at high speed it vibrates a bit... the tenants beneath me would not like me if I make a video this late ....
    Also thought of adding two more set of brushes to accumulates more power out at the generator side.
    Joel
  • Ufopolitics
    Originally posted by lerameur View Post
    Bonjour UFO,
    Yes it is the Monster circuit from J.S..
    Although the 4 diodes on the output, well near the mosfet seems to smoke a bit when the circuit is on for more then 4 minutes.
    I am going away for a few days. I will get a video up when I come back. The motor was originally a 3HP 21 poles 1750 rpm 14 amps 180VDC.
    With johns circuit at 40% DUTY CYCLE and 48vv from four 12v batteries it consumes 10 amps. turning pretty fast and almost unstoppable. Although I hooked up a 10 watts dc light bulb from the output ( two other wires from the motor). I was hoping to get more power out from that method.. at least 100 watt... 10watt is negligible from the 480watt input
    have a good evening
    Joel
    Lerameur,
    Is the Motor a Four Brush, Four Stators?...I noticed you've said "two other wires from motor"...if it is a Four/Four or 4/4 is supposed to have Four wires out.
    Monster pulsers are designed for Four Brush system (meaning four top/four bottom) even though two brush could work with two boards...but not same results.
    The electric output of this motors, is just a Flow Through of the "Non Used Energy" at Input Joel...in order to measure the Motors total Wattage Output, you must also ADD the Mechanical output of the Machine my friend.
    Even though, ten watts is too little for that input...so, there must be some wrong there.
    Regards and looking forward to see the videos
    Bon Voyage Mon Ami..
  • lerameur
    Bonjour UFO,
    have a good evening
    Joel
  • Ufopolitics
    Hello UFO,
    I have receive the circuits from John Stone and build it as requested. Works great with fast rise time.
    Bon Jour Lerameur,
    You received the Monster Pulsers from John Stone design...am I correct?
    I have two questions.
    1) when using the CFL bulbs, do you remove the electronic circuitry or just use the bulb as is.
    You use the CFL's complete as they come from factory.
    Watch my old videos below, and see how I use the CFL's as they come out of the box:
    RADIANT FREE ENERGY - YouTube
    2) I used this circuit with an ordinary light bulb and in a motor that I rewound with your method. When I decrease the duty cycle from 50% to 40% and lower, the intensity (speed for motor) reduces. Thus less hot electricity less performance.
    From what I have read, the cold electricity gets in , in the off time and helping the rotation. obviously i think I am not getting it.
    Any idea or steps to be taken to trouble shoot the problem??
    Joel
    Ok, you meant, you used this circuit (the Quad Monster Pulsers from J Stone?) in a motor you rewound as my method (can I please know which type?...how many poles?...what kind?)
    Is there a possibility that you show Us any pictures or videos of this?...along with some diagrams of connections? would help a lot Mon Ami!
    Cold Electricity gets in at off times, that is correct, however, its operation is TO ASSIST the rotation, so do not expect when lowering the duty from Hot, your Motor will go crazy and start speeding up...I never said such thing my friend.
    Like I said, it will help me a lot to help you...if you show diagrams and videos of your set up.
    Merci and kind regards
  • lerameur
    Understanding circuitry
    Hello UFO,
    2) I used this circuit with an ordinary lihght bulb and in a motor that I rewound with your method. When I decrease the duty cycle from 50% to 40% and lower, the internsity (speed for motor) reduces. Thus less hot electricity less performance.
    Joel
  • Ufopolitics
    Originally posted by Zara
    Hey UFO... I found this today...let me know what you think about it. How to Improve the Smartphone Battery: Video - Bloomberg
    Hello Zara,
    What do I think?...ok
    I think the "Zillionaire Cell phones battery Industry"...will request Radio and all broadcast corporations to stop this...they will pay the price later...but stop it NOW...
    Then the "Radio Waves Industry" would complaint to the Governmental "Agency in charge" (the Federal Communication Commission) FCC...saying that this invention creates distortions, noises and so many problems within the networking system...
    The end?
    It will never happen, too much $$ at risk for such little "free energy device"...
    so do not dream about it.
    Now Zara, let's delete both posts (Yours then I will delete mine)...since they are "Non Related Content" on this Thread, and those are Forum Rules.
    Appreciate your understanding friend!
  • Ufopolitics
    Originally posted by RandyFL View Post
    UFO,
    Where would I find the specifications to rewinding a Radio Shack motor...
    I'm finding bits and pieces of the info and would like to experiment with a de-witched motor. I have worked on a electrical circuit a good part of last year and it needs a motor :-)
    Randy
    Hello Randy,
    Please, post this into MAEM, the Thread I cited in above post to Larameur, and I will give you the links...
    Thanks for helping here...
  • RandyFL
    UFOpolitics' motors
    UFO,
    Randy
  • Ufopolitics
    Hello UFO,
    I watched you video called 'Asymmetrical Winding Part 1 ' Because I am about to wind a similar motor, I had a question concerning the gauge sizing used for coiling. You used 18 Gauge with about 13 turns. which do not seem a lot. Comparing to you coils which are wounds many many turns and used 100 times more wire, I presume this condition was needed to get cold electricity. So my question is, why so few turns ? why not used a 22 gauge and add more turns ?
    regards,
    Hello Lerameur,
    Well that is what I could fit in...with 18 awg, however, Iankoglin (Kogs) used 18 and was able to fit around 15 turns...related to gauge, it is not because of Radiant, a heavier gauge will generate stronger magnetic fields, and since we are only pulsing coils by very short times...we can afford it in my machines...
    Also Ordered the JS circuit board a month ago, should arrive anytime soon. Anybody know the digikey part number for those male and female receptacles ?
    Have a nice day
    Update : I just had a look in my inventory and i only have spindle of 19 Gauge. Could I use that ? (I'll do max turns with this gauge)
    Lerameur, please let's keep threads organized...I would like all related to electronics and controllers as any Solid State Pulsed Coils to be here...and all related to Electrodynamic Machines...(Motors/Generators) in MAEM (My Asymmetric Electrodynamic Machines)
    Machine Alive used 19 gauge...and built a very robust Motor, so post over there and ask him how many turns he did...but I do recommend to do as many as you could...
    Kind regards and wish you great luck!
  • lerameur
    Asymmetrical Winding Part 1 - question
    Hello UFO,
    regards,
    Have a nice day
  • Ufopolitics
    Thanks Midaz!
    Excellent video!...Yes MrWarrensk is an excellent researcher and a heck of a developer...awesome!
    I can only imagine the kind of Magnetic Spatial Distortion "Network" He is creating there...between Rodin Coil and Asymmetric Machine.
  • mobigozer
    Thank you so much!
    This is fantastic information.
  • Midaztouch
    @ Team
    Keep it Clean and Green
    Midaz
  • Cornboy 555
    Hello all, a short vid, to show frequency before and after diodes, also voltage, after diodes, and maybe a scope shot of what is happening?
    I welcome any input you may have.
    00144 - YouTube
    Thanks Cornboy.
  • Cornboy 555
    Thanks Sammy, about time you got those boards covered, they must have been feeling awfully nude and lonley, without their friendly components.
    If i can do it anybody can.
    I will post a short video soon with frequency measurements, before and after, and scope shots of pulsing coil.
    Just got heaps on at the moment with the farm.
    Keep those hipps warm friend, and don't let them touch you until you are ready.
    Warm Regards Cornboy.
