Tuning Tubes Mechanically
So, if it's possible, we need to look for a way to tune the tubes mechanically but if not then we'll have to go the electrical route.
Thanks Cherryman for your input!!
IKEA Config
Cherryman,
This is the configuration I was eluding to for the IKEA boiler. It doesn't have a ring on the outside like the original Serbian boiler I introduced. It's a new design with the inner and outer tube both connected at the top and both energised by mains voltage. In this particular case, we're looking for a cathode much like that illustrated in the Savic Diagram below:
Best Regards,
Slovenia
consider it doneOriginally posted by Slovenia View PostThe boy is in very bad shape. He is bleeding very badly in his intestine again. The hospital just can't seem to get him squared away. His parents are very concerned indeed. It's disrupting their life big time worrying about him. At one point several days ago he showed some signs of improvement but now he's in bad shape again. So, we need your prayers really bad for this little guy. He is a very intelligent well liked kid.
thanks Ramset....my curiosity was itching me....
Savic's Boy Update
Originally posted by RAMSET View PostSlovenia
Any word on the little Savic Boy [Branilav] ??
Thanks!!
Hi Cherryman,
I appreciate your taking the time to help here. Thanks very much!! We'll test it out in this application.
Best Regards,
Slovenia
Originally posted by Cherryman View PostHi Slovenia,
Just a thought that might help:
Maybe Manual tuning by tension could be a more easy solution.
Just see it as the tuning of a guitar string, I think the same principle should count for a metal tube like object.
If you make the connection solid, you can even pull and push.
I made a little drawing to visualize:
By turning the bold on top the tension on your container/tube will be variable, and ( I think) as well as the resonating frequency.
This might eliminate difficult electronic tuning, as you just put on your power source and turn the screw slowly to see if you can bring the can to the resonance. ( Isolate the bolt carefully)
Cheers.
Hi Slovenia,
Cheers.Attached Files
That would be nice!!
Mr. DB
Quote
We will see what I can do with my sonic setup?
Some Numbers??
I love those kind of Numbers [Test results]!!
I just got the ship Seaworthy last Night ,Just have to do An inspection This AM
And I'm Done
Then I can get back to Testing Too
And yes Gordon ... Your Coil will get a dip in the Electric hot tub Also.........
Free at Last............... {for the moment]
Chet
PS
Slovenia
Any word on the little Savic Boy [Branilav] ??Last edited by RAMSET; 12-19-2011, 01:12 PM.
Tuning
We need to find a way to tune our IKEA device electronically. The stainless steel used in this thermos does appear to be a much better choice than aluminum. If we are going to use both inside tubes effectively, we also need a ring assembly that will adjust to each tube and with the IKEA thermos, there is an inner tube and an outer tube. For an assembly such as this with both an inner and outer tube, we are going to have to use a flat plate for our neutral ring and that will have to be adjustable and adjust in from one end to correspond with both the inner and outer tubes of the IKEA setup.
So, if you have an electronic background and know of a simple electronic device we could use to bring our IKEA thermos into tune we'd very much like to hear from you at this time.
A lot of the hydrogen guys were utilizing similar electronics in their cells. Some of their setups were quite complicated and we're looking for something designed as easy as possible. At this point, we just want our circuit to tune the IKEA tubes to the appropriate level so that it can be used in both Europe and USA.
Rationale:
Tuning by hand, sanding, is to tedious and time consuming. We need to tune in a value; set it; and forget it!!
Thanks!!
Daemonbart,
Wow, incredible stuff indeed!! Thanks for sharing about it.
Best Regards,
Slovenia
Originally posted by daemonbart View PostThanks,
water in my container seem to have charging when starting up with new water, also I still need to add about 30l/24h ?? There is not really any moist added indoors
After charging the heating have higher cop, charging 60l takes about 5 min, input about one kW.
The wirls in water I would say are similar to your pics
Kind rgds D
Fist Fights With Physicists - The Caduceus Coil, Helical Flow and the Evidence for Free Energy ☤ - YouTube
Here's an advance with plenty of links for more research and investigation Dan Winter- Super Imploder for Accelerated Plant Growth- Magnetic Phase Conjugation - Heterodyning - YouTube
Temp rise?!
Hi Steve,
I dont mind telling
I have done many temperature tests and doing it almost everyday! I will post the requested data later today.. 60l temp rise in 5 min with 1kW input.
That will be the same as 83Wh, with resistance heater and no loss the water should rise 0,87 K, in real it will rise only 0,7x0,87 = 0,6 K
Kind rgds D
Originally posted by PhysicsProf View PostDBart --
What is your temperature rise in 5 minutes? if you don't mind telling that is.
Thanks, Steve
DBart --
What is your temperature rise in 5 minutes? if you don't mind telling that is.Thanks,
Kind rgds D
Thanks, Steve
Charging water
Kind rgds D
Originally posted by MonsieurM View PostHave you tried vortexing the water before it gets in the container...using pipes like these
Figure 1: a typical vortex flow (Caduceus like
) The Vortex Indicator
from the research so far vortexed water is more energized and more reactive...ie resonant
as mentioned before...water is also a component that can be tweaked
note: Moe Joe Cell users used magnet vortexer to get HHO
more on the effect of double spiral pipe here Q's about WATER
see post: http://www.energeticforum.com/148474-post141.htmlOriginally posted by Slovenia View PostThere is a water generator out there that we may be able to apply in our experiments. It's the: Dr Oleg Gritskevitch 1.5 MW COP=100 water generator. It sounded very interesting to me. It's supposedly a fairly new generator. I'd never heard of it until yesterday and ran into it during some research.
very nice set up he created
ps: He uses Barium Titanate coating...but quartz would do the job...you should read that thread too
note: you can also vortex the water by wedging a Vogel Crystal inside a copper tube (more on Dr Vogel here http://www.energeticforum.com/renewa...tml#post156660 )
Victor Schauberger Drawing
