  • MonsieurM
    Another pattern linking
    James Y Johnson -- Dipolar resonance -- Anomalous dispersion bands
    Improvements in devices for generating electromagnetic fields oscillating with quasi-optical frequencies
    1934-09-29
    Inventor(s): James Y. Johnson
    Applicant(s): TERNION AG
    Classification: - international: H03L7/26; H03L7/26 - European: H03L7/26
    Abstract -- Electromagnetic fields of quasi-optical frequencies are generated in the space between two oppositely-placed electrodes which are excited at one or more of their natural frequencies by an external high-frequency source.
    fUSION Anomaly. Ernst Chladni
    While investigating the various tones of music, Ernst Chladni (1756-1827) made a classic experiment to show the effects of harmonic vibrations. He spread fine sand over a glass or metal plate and set it into vibration with the bow of a violin by scraping the bow along one edge of the plate. The bow would alternately stick and slip in rapid succession on the edge of the plate to create waves of sand (also sound waves). He would hold the plate between his fore finger and thumb; the point where the plate is held is, of course, a node where there can be no movement. The bow sets up waves that move across the plate and then are reflected from the edges. The reflected waves become superimposed on the new waves coming from the bow edge. This results in symmetrical patterns of nodal lines where the plate is not moving. Figure 1 shows square and circular plates that are being held in the center. The type of pattern created depends generally on
  • MonsieurM
    btw:
    3 *
    Lenses can bend light and sound in almost any direction
    using special lenses that can bend light by (i.e., a full loop), scientists may limit light leakage in optical fibers and overcome this problem, not to mention provide a useful material for many other applications. Recently, a team of scientists has theoretically investigated materials for achieving this kind of advanced light control, which could work equally well for sound waves.
    imho
    1934-09-29
    Abstract -- Electromagnetic fields of quasi-optical frequencies are generated in the space between two oppositely-placed electrodes which are excited at one or more of their natural frequencies by an external high-frequency source. The electrodes are the seat of electromagnetic waves, after the manner of Lecher wires, but in two dimensions instead of one. The apparatus is applied for various purposes, including the chemical, physical, and biological processes referred to in Specification 417,501. The distribution of electric stress in the dielectric may be made visible by a polarized-light projection system. Fig. 1 shows a resonator comprising parallel circular plates 1, 2 excited by high-frequency voltages applied by the conductors 3, 4. The plates may be of square or rectangular form, and may be inclined to each other. One or both may be concave or convex on its inner surface. Current and voltage waves are propagated along the plates in the same manner as along Lecher wires. With circular plates excited at their centres and with their rims free, the fundamental oscillation gives a voltage peak and a current node at the rim. If the rims are short-circuited by added capacity, as for instance by inserting the resonator in a metal cylinder 9, Fig. 24, the voltage peak and current node are at the centre. The plates also resonate at higher frequencies, with nodal diameters and nodal concentric circles. With rectangular plates, nodal lines parallel or oblique to the edges are created. The positions of the nodal lines may be predetermined by metal blocks 10, Fig. 24, fixed to the external cylinder 9, or to one of the plates 1, 2. The plates may be of good conducting metal, or of poorly-conductive metal with or without a coating of good conductivity; or the plates may be in the form of containers filled with an electrolyte. The plates may be light-permeable, consisting of glass with a very thin coating of precious metal on their inner or outer faces. One or both plates may also be in the form of wire grids stretched across rings of insulating material and electro-plated with copper or silver to provide good conductivity where the wires cross. The resonator plates are excited by separate generators of damped or undamped waves. Fig. 25 shows a valve generator 54 with Lecher-wire output circuit 45, 46 tuned by a condenser bridge 53, and with the resonator 51, 52 loosely coupled thereto by two air gaps between small spheres 47--50. The coupling condensers may take the form of a ball and ring, or of small parallel plates at adjustable distance. The couplings may be slidable along the wires 45, 46, and along the resonator plates. The Lecher wires may be in the form of a wire and concentric tube, and they may be provided with knot extremities for coupling to the edge of the resonator plates. By inserting the Lecher wires between the resonator plates, an inductive coupling may be provided. In Fig. 32, the concentric-tube Lecher system 99 is adjusted in length by a trombone slide 108 and is tuned by reflection bridges 102, 103 placed in the divided branches 100, 100. The coupling conductors 104, 105 of the resonator 106, 107 project into the interior of the conduits. When liquid to be treated is contained in a glass envelope 128, Fig. 40, placed between the plates 120, 121 of the resonator, the dielectric is composed of layers of air glass and liquid. The Specification discusses the effect of the composite dielectric on the natural frequencies and the damping of the resonator. The distribution of electric stress in the liquid may be rendered visible by the apparatus of Fig. 40. The resonator plates are coupled by rods 122, 123 to Lecher wires 124, 125 fed by a valve generator 126. Temperature may be regulated by heating-coils 129 within the casing 130. Light from a source 137 which may be a mercury vapour lamp is projected through lens 131 , polarizing-prism 133, mica plates 135 and lens 132 , and after passage through the treated liquid 128 emerges through similar devices to the screen 138, giving thereon a picture of the field distribution within the resonator. If the exciting oscillation is modulated, a complex varying pattern is produced. Glass or liquid lenses 142, 143, Fig. 41, may be arranged between the container 144 for the liquid under treatment and the resonator plates 140, 141. If convex as shown the lenses tend to equalize the field over the whole area whilst concave lenses concentrate the field in the centre. The lenses may be attached to the container 144 or the plates 140, 141. The resonator may be housed in a double-walled cylindrical casing with external knobs and dials for screw adjustment of the plate gap. Heating coils and coils for spraying cooling liquids into the casing are provided. Lecher wires of the concentric type are led through the container walls to excite the resonator, and high tension may be applied through chokes. The resonator plates may take the form of shelves 231--233, Fig. 49, separated by insulating posts 234, the material to be treated, for example foodstuffs, being placed upon the shelves. Energy may be led to the shelves by Lecher wire systems terminating in knobs adjacent to the edges of the shelves.
    (montalk.net) Research Notes: Longitudinal Waves
    There are numerous methods to generate longitudinal EM waves, but only one will be discussed here. Consider a large flat metal plate charged to a steady high voltage:
    This gives rise to a steady electric field pointing out and away from the plate. If its voltage were instead made to uniformly oscillate, the electric field would likewise oscillate and radiate away. But since the field already points in the direction of radiation, the resulting wave will be longitudinal. The vector potential diagram would then look like this:
    read on
  • MonsieurM
    now let us try to resonate some fractal Constructs .....
    from : http://www.energeticforum.com/psychi...tml#post187363
    Anisotropy
    The scientists, Sebastien Guenneau and coauthors from Institut Fresnel, CNRS, University of Aix-Marseille in Marseille, France, have published their study on the focusing and bending of light and sound waves in a recent issue of the New Journal of Physics.
    As Guenneau explained, both light and sound control techniques use gradient index (GRIN) lenses, which can effectively be used to curve space for light and sound trajectories. By creating a change, or gradient, in the refractive index of a lens, the scientists could create anisotropies
    doesn't remind you of: ( Principle of Correspondence )
    The Vimana's - Flying Machines
    Their method of propulsion, she said, was "anti-gravitational" and was based upon a system analogous to that of "laghima," the unknown power of the ego existing in man's physiological makeup, "a centrifugal force strong enough to counteract all gravitational pull." According to Hindu Yogis, it is this "laghima" which enables a person to levitate.
    Wireless breakthrough: one frequency, multiple signals • The Register
    by demonstrating a method of simultaneously transmitting multiple signals on the same frequency.
    Team member Bo Thide of Swedish Institute of Space Physics first conceived the orbital angular momentum idea in a 2007 paper focussed on radio astronomy, but in which he wrote that the concept "paves the way for novel wireless communication concepts."
    Last year, Tamburini, Thide, and their team demonstrated the multiple-signal technique by beaming two separate audio signals at 2.4GHz, then two television signals, 442 meters from the lighthouse of Venice's San Giorgio Island to the balcony of the Palazzo Ducale.
  • MonsieurM
    Is Our Sun a MASSIVE UFO Stargate?
    Is Our Sun a MASSIVE UFO Stargate? - YouTube
    IndianaBoys
    Many researchers into the UFO enigma tend to overlook a very important fact. While it assumed that most flying saucers are of alien, or perhaps Governmental Military origin, another possible origin of UFOs is ancient India and Atlantis.
    What we know about ancient Indian flying vehicles comes from ancient Indian sources; written texts that have come down to us through the centuries. There is no doubt that most of these texts are authentic; many are the well known ancient Indian Epics themselves, and there are literally hundreds of them. Most of them have not even been translated into English yet from the old sanskrit.
    The Indian Emperor Ashoka started a "Secret Society of the Nine Unknown Men": great Indian scientists who were supposed to catalogue the many sciences. Ashoka kept their work secret because he was afraid that the advanced science catalogued by these men, culled from ancient Indian sources, would be used for the evil purpose of war, which Ashoka was strongly against, having been converted to Buddhism after defeating a rival army in a bloody battle.
    The "Nine Unknown Men" wrote a total of nine books, presumably one each. Book number one was "The Secrets of Gravitation!" This book, known to historians, but not actually seen by them dealt chiefly with "gravity control." It is presumably still around somewhere, kept in a secret library in India, Tibet or elsewhere (perhaps even in North America somewhere). One can certainly undertand Ashoka's reasoning for wanting to keep such knowledge a secret, assuming it exists. if the Nazis had such weapons at their disposal during World War II. Ashoka was also aware devastating wars using such advanced vehicles and other "futuristic weapons" that had destoryed the ancient Indian "Rama Empire" several thousand years before.
    Only a few years ago, the Chinese discovered some sanskrit documents in Lhasa, Tibet and sent them to the University of Chandrigarh to be translated. Dr. Ruth Reyna of the University said recently that the documents contain directions for building interstellar spaceships!
  • MonsieurM
    from: http://www.energeticforum.com/psychi...tenna-135.html
    IndianaBoys
    PS_ fractal antenna link: W1YW - Callsign Lookup by QRZ.COM Updated December 30, 2012
    quite interesting ..... how about we take it to the next level ...... ..... Nature 's fractal antennas
    How to electroplate flowers, leaves, animal skulls, and other organic materials
    not a fan of reinventing the wheel ..... but i like to pimp it up
    a dried Leaf
    Electroplating Flowers And Leaves With Organic Plating Kit — Electroplating Kits
    more found here ..... as jewelery .... but there is more to it than just decoration
    REAL LEAF JEWELRY Gold Silver Copper One Of A Kind by Jeunebugs
    Pine Leaf would work too as it resembles CB Antennas : High Performance CB Antennas
    In addition to making our Top Performance CB antennas, we can also "upgrade" your existing IMAX 2000
    fiberglass antenna, or any 5/8 wave fiberglass base antenna, to offer you more performance! We can
    upgrade them to have "higher gain" and "handle more power". We redo them with better coils and taking
    out the small wire/puny wire conductors inside the fiberglass, and replacing them with larger copper (or
    better yet, silver plated copper
    or a pine cone ...... Like your Pineal Gland
  • MonsieurM
    The Primer Fields Part 1 - YouTube
    on a side note :
    Tibetan Bowl anyone Watching Tibetan bowls sing - YouTube
    also you probably can make two electromagnet bowls ( or rodin like Coils ) ... you can also try Asymmetry .... like Nature does
    for some new experimentation
    Felix Ehrenhaft: Magnetic Current --- 9 articles
  • MonsieurM
    Another form of discharger, which may be employed with advantage in some cases, is illustrated in Fig. 3/167. In this form the discharge rods d d1 pass through perforations in a wooden box B, which is thickly coated with mica on the inside, as indicated by the heavy lines. The perforations are provided with mica tubes m m1 of some thickness, which are preferably not in contact with the rods d d1. The box has a cover c which is a little larger and descends on the outside of the box. The spark gap is warmed by a small lamp l contained in the box. A plate p above the lamp allows the draught to pass only through the chimney a of the lamp, the air entering through holes o o in or near the bottom of the box and following the path indicated by the arrows. When the discharger is in operation, the door of the box is closed so that the light of the arc is not visible outside. It is desirable to exclude the light as perfectly as possible, as it interferes with some experiments. This form of discharger is simple and very effective when properly manipulated. The air being warmed to a certain
    if you look carefully what follows is a "transmuted" version of it
    the propeller :
    image from : PHOTO STORY
  • MonsieurM
    Originally posted by occy30 View Post
    Thread has gotten quite so let me add this video I stumbled upon:
    This is amazing!!!!!!
    Any science guys here wanna watch this video and let us know your thoughts? It's a little over my head but this guy is able to put together a working theory of magnetism for "above AND below"
    thank you occy30 for the link and giving me the opportunity for some update
    in relations to the vid and the exp set up : "On Light and Other High Frequency Phenomena"
    a finds i stumbled on ..... just today as a matter of fact
    based on the above statement ... a few of his writings :
    Research of Nikola Tesla in Long Island Laboratory
    where for the equivalent conductor he calculated inductance ignoring "magnetic influence." For the Earth diameter he assumed to be 7914 miles so that,
    --total capacitance of the cylinder 707.5 2.40377
    7914 = HM 3
    707.5 + 2.40377 = HM 1 + HM 5 = HM 6
    From the above values capacitance per mile and inductance per mile were calculated (the length of conductor was assumed to be 7914 miles, the Earth diameter). From the calculated c and 1, Tesla obtained the relationship between frequency and the wavelength along the cylindrical conductor (Long Island Notes, January 29, 1901):
    wavelength (miles) = 1/(f Ic) = 192,300/f (Hz).
    192.300 = 9 3 3 = HM 6
    He also wanted to measure capacitance of "zones"--spherical rings. In a substitution sphere-straight conductor, in one measurement on November 3, 1902, Tesla found that "the induction of sphere 38.1 cm radius would be 45 cm. . ."
    ..... and thank you again for the link
  • occy30
  • MonsieurM
    Dave , I think the following Article has much to show us .... in relation to the Joule Ringer ..... named after the noise it makes
    "On the Dissipation of the Electrical Energy of the Hertz Resonator"
    These waves are propagated at right angles from the charged surfaces when their charges are alternated, and dissipation occurs, even if the surfaces are covered with thick and excellent insulation.
    When a glass plate is placed near a condenser the charge of which is alternated, the plate emits a sound. This sound is due to the rhythmical impact of the air against the plate. I have also found that the ringing of a condenser, first noted by Sir William Thomson, is due to the presence of the air between or near the charged surfaces.
    When a disruptive discharge coil is immersed in oil contained in a tank, it is observed that the surface of the oil is agitated. This may be thought to be due to the displacements produced in the oil by the changing stresses, but such is not the case. It is the air above the oil which is agitated and causes the motion of the latter; the oil itself would remain at rest. The displacements produced in it by changing electrostatic stresses are insignificant; to such stresses it may be said to be compressible to but a very small degree. The action of the air is shown in a curious manner for if a pointed metal bar is taken in the hand and held with the point close to the oil, a hole two inches deep is formed in the oil by the molecules of the air, which are violently projected from the point.
    Taking the above views, I believe, that in the experiments of Prof. Bjerknes which lead him to undoubtedly correct conclusions, the air is a factor fully as important, if not more so, than the resistance of the metals.
    Thomas Henry Moray: Speech at Valley State College, Northridge CA
    This type of energy device is capable of converting the high frequency, high level of the cosmos, kinetic radiations by synchronization, into usable frequencies and voltages. Basically the theory of operation is as follows:
    Oscillations by synchronization are started in the first stage of the circuit of the device by exciting it with an external power source such as the difference of potential between two points. The circuit is then balanced through synchronization until the oscillations are sustained by harmonic coupling with the energies of the Universe. The reinforcing action of the harmonic coupling increases the amplitude of the oscillations until the peak pulses "spill" over into the next stage through special detectors or valves which then prevent the return or feedback of the energy from the preceeding stages. These oscillating pulsations drive each succeeding stage which oscillate at a controlled frequency and which are again reinforced by harmonic coupling with the ever present energies of the Cosmos. That is, the first stage drives a second stage, the second stage driver a third and so on. Additional stages are coupled or until a suitable power level at a usable frequence voltage and amperage is obtained by means of special resonant oscillators.
    Once the device is in operation and delivering energy, it does not require the continuance of the original excitation induced by the difference of potential between two points to maintain the oscillations. The oscillations are sustained as long as the device remains properly synchronized and the external circuit is completed through a suitable load. This load may be maintained at as low an output as 1/4 watt, The special tubes which are the key to the successful operation of this device are specially constructed ionic, cold cathode tubes.
    All energies of the plasma of the Universe have resilient rigidity and density, which is subject to displacement and strain. When a resilient substance is subject to strain and then set free, one of two things will happen, The substance will slowly recover from the strain and gradually obtain its natural state or the elastic recoil will carry it past its position of equilibrium and cause it to execute a series of oscillations. Something of the same sort will also occur when an electrified capacitor is discharged through special high frequency valves.
  • Dave45
    The last pole shift covered the earth with water, this one will be with fire.
    We are spiritual beings the ascention will be a spiritual one,
    The Lord will come for His.
    later
    dave
  • MonsieurM
    I think the pyramid's were built before the last pole shift, when we cross the threshold and the poles shift again they may fire up, but we wont be there to see it.
    no one knows what the future holds .... we can only Speculate ( all truth is Half truth )
    Good reading you Dave
  • Dave45
  • MonsieurM
    from: http://www.energeticforum.com/psychi...tml#post214590
    Originally posted by Danny B View Post
    There is currently a lot of research using a caduceus coil to treat seeds for better germination. I suspect that the clarifier generates the same scalar beam.
    Using magnetic energy to treat seeds goes back probably 12,000 years. There is an excellent book on the subject.
    "Seed of Knowledge, Stone of Plenty" by John Burke
    I have no idea in what aspect matter is "deficient". So, I don't know what "quality" of matter is affected/improved by the Bedini clarifier. There are hints that this device can be used to do a very special "treatment" of matter to get some exciting results. I have NO idea what they might be.
    Reportedly, one can also use electricity to completely change the genetic code. It's a fascinating possibility.
    English - urzeitcode.com
    thank you for the info Danny B
    see also :
    http://www.energeticforum.com/agricu...o-culture.html
    A recent book, Seed of Knowledge, The authors show that these structures were overwhelmingly sited at locations where the local geology magnified naturally-occurring electromagnetic fluctuations in the earth's crust and, further, that pyramidal and corbel- roofed stone structures erected at these locations enhanced this effect.
    from: http://www.energeticforum.com/214187-post3503.html
    Limestone Quartz Magnetite and Residual Paranormal Hauntings Study by Long Island Paranormal Investigators - Ghost Haunted Demonic Investigation Ghost Hunter New York NY
    Phillip S. CALLAHAN -- Paramagnetism & Agriculture
    Paramagnetism --
    Rediscovering nature's secret force of growth: How to farm properly as god intended
    His use of the word granite ( used in all the Ancient Structures we discussed ) implies that he not only knew that good soil is made from eroded stone but also which kind of stone was best suited to a viable agriculture.
    This word is similar to prepared granite except that the pyramid sign (Septih), for the Dog Star, is replaced by the symbol for a wing (many feathers), a much stronger levitation force than one feather . In other words black granite ( see black pyramid in Alaska http://www.energeticforum.com/psychi...tml#post207477 ) is a paramagnetic battery for the force. Every Egyptian word for different types of para-magnetic stone, eg. aner-en-rut (sandstone)
    The findings add to a growing body of research suggesting that sound meant more to our ancestors than archaeologists once realized. We live in a sound-saturated society, full of iPods, thunderous special effects in movies, and thousand-watt car stereos. New discoveries in the young field of acoustic archaeology hint that just as we create elaborate sonic environments with our electronics, the ancients may have sculpted their soundscapes as well. Like many artistic endeavors, their efforts may have been rooted in an attempt to reach the divine.
    A Fractal Resonance
    Santos Bonacci - Truth Frequency Radio - 11-03-12 - Syncretism & Our Binary Star - YouTube
  • MonsieurM
    Tesla Patent 787,412 - Art of Transmitting Electrical Energy through the Natural Mediums
    ART OF TRANSMITTING ELECTRICAL ENERGY THROUGH THE NATURAL MEDIUM.
    what do you see
    Analogy is perhaps the most powerful conceptual tool for understanding new phenomena or opening new areas of investigation
    Thomas H. MORAY
