  • MonsieurM
    BBC News - 'Twisted light' carries 2.5 terabits of data per second
    Researchers have clocked light beams made of "twisted" waves carrying 2.5 terabits of data - the capacity of more than 66 DVDs - per second.
    he technique relies on manipulating what is known as the orbital angular momentum of the waves.
    Recent work suggests that the trick could vastly boost the data-carrying capacity in wi-fi and optical fibres.
    and previously posted : http://www.energeticforum.com/psychi...tml#post192813
    demonstrating a method of simultaneously transmitting multiple signals on the same frequency.
    Helices of light: dark helices with a bright future
    (Nanowerk News) Laser beams can be made to form dark as well as bright intensity helices, or corkscrews of light. In a paper shortly to appear in Optics Express, Dr Ole Steuernagel, at the University of Hertfordshire's Science and Technology Research Institute, has now shown that forming dark helices can have considerable advantages over employing their commonly considered bright cousins.
    Light helices may have many fundamental and technological applications in lithography and the manipulation of particles through optical forces, such as particle trapping and particle transport. In lithography, the light helices can create novel materials with helical imprints to provide left- or right-handed optically active materials. When applied in laser tweezers that manipulate particles through optical forces, helices can be used as a handedness filter for twisted molecules, create twisted waveguides for trapped quantum particles and even provide intertwined transport via intertwined optical helix configurations.
    Image illustrates a single bright helix (red line) superimposed with a single dark helix (black line)
    in case you forgot ... your DNA is also Helical .... like Alpha Quartz
  • MonsieurM
    Discovery of material with amazing properties
    Normally a material can be either magnetically or electrically polarized, but not both. Now researchers at the Niels Bohr Institute at the University of Copenhagen have studied a material that is simultaneously magnetically and electrically polarizable. This opens up new possibilities, for example, for sensors in technology of the future. The results have been published in the scientific journal, Nature Materials.
    The "8-armed candlestick" in this unusual image of the measurements is proof that the "walls" of the domains in TbFeO3 repel each other at certain temperatures and therefore lie at a fixed distance from each other. The signal from the "ordinary" chaotic domain walls would more resemble a fly swatter. Credit: Niels Bohr Institute
  • MonsieurM
    Is your leaf left-handed? Previously overlooked asymmetry in Arabidopsis and tomato leaves
    Research published in the Plant Cell shows that the spiral pattern of leaf formation from the point of growth affects the developing leaf's exposure to the plant hormone auxin; This exposure leads to measurable left-right asymmetry in leaf development, in species previously assumed to have symmetric leaves.
    This is a model of developing leaves. Credit: Richard Smith
    The front of a leaf is different from the back of a leaf and the tip is different from the base. However, a leaf from a tomato or an Arabidopsis plant superficially appears to be bilaterally symmetrical, or the same on the left and right sides. Don't let its appearance fool you; there is an underlying asymmetry between the left and right sides the arrangement of leaves or flowers along a stem, affects key plant characteristics, such as how much light can filter through to lower leaves. Leaves can form opposite each other, or in alternation, or in whorls; often leaves form in spirals where the next leaf is offset by roughly 137 degrees, known as the "golden angle", which is related to the Fibonacci sequence.
    Recent research has shown that leaf initiation in the meristem is specified by locally high concentrations of the plant hormone auxin.
  • MonsieurM
    Stars, jets and batteries: Multi-faceted magnetic phenomenon confirmed in the laboratory for the first time
    Magnetic instabilities play a crucial role in the emergence of black holes and other cosmic phenomena. At the Helmholtz- Zentrum Dresden-Rossendorf, confirmation of such a magnetic instability - the Tayler instability - was successfully achieved for the first time in collaboration with the Leibniz Institute for Astrophysics in Potsdam. The findings should be able to facilitate construction of large liquid-metal batteries, which are under discussion as cheap storage facilities for renewable energy.
    The magnetic phenomenon, observed for the first time in the laboratory at the Helmholtz-Zentrum Dresden-Rossendorf, was predicted in theory by R.J. Tayler in 1973. The Tayler instability always appears when a sufficiently strong current flows through an electrically conductive liquid. Starting from a certain magnitude, the interaction of the current with its own magnetic field creates a vortical flow structure. Ever since their involvement with liquid-metal batteries, HZDR scientists have been aware of the fact that this phenomenon can take effect not only in space but on earth as well. The future use of such batteries for renewable energy storage would be more complicated than originally thought due to the emergence of the Tayler instability during charging and discharging.
  • MonsieurM
    would recommend you print the above Walter Russell table to study it more closely and make notes for insights that might show up ..... you can also compare the table with some of the news from physorg posted here on certain elements
    Emerald Tablet of Thoth The Emerald Tablets of Thoth Tablet
    All eyes do not see with the same vision,
    for to one an object appears of
    one form and color
    and to a different eye of another.
    So also the infinite fire,
    changing from color to color,
    is never the same from day to day.
    Randall Cole Roffe: Harmonic Resonance
    [/B]
    The application of the principles of one science into another is often neglected. Today we have a massive and growing volume of experimentally proven information that certainly does not always
    find its every application.
    In the real world, we can work from scientific theory, through experimentation, into an engineered result, but just as often we work via reverse engineering, from the
    result back into the origin.
    If we take a good look -- and listen -- at the whole of manifestation, and apply the principles of acoustics and music, and of the color wheel, the grand pattern that emerges is self-evident.More
    than this, a possible explanation of a medium of transmission of a universal electrogravitational influence, as a plenum far more fundamental than an ether, becomes apparent. With this realization a
    whole new understanding of physics also emerges, with awesome possibilities.
    Randall Cole Roffe
  • MonsieurM
    Meanwhile ..... a bit of info : we did discuss the Hall effect Battery : http://www.energeticforum.com/renewa...tml#post191887
    First observation of the hall effect in a Bose-Einstein condensate
    (Phys.org) -- National Institute of Standards and Technology researchers have observed for the first time the Hall effect in a gas of ultracold atoms. The Hall effect is an important interaction of magnetic fields and electric current more commonly associated with metals and semiconductors. Variations on the Hall effect are used throughout engineering and physics with applications ranging from automobile ignition systems to fundamental measures of electricity. The new discovery could help scientists learn more about the physics of quantum phenomena such as superfluidity and the quantum Hall effect.
    Starting with a cloud of about 20,000 atoms, the researchers varied the trapping force, pushing the atoms together and pulling them apart, to simulate the movement of charge carriers in an alternating current. In response, the atoms begin to move in a manner mathematically identical to how charged particles experiencing the Hall effect would move--at right angles to both the direction of the "current" flow and the artificial magnetic field. This causes the tilting motion. Credit: NIST
    --------------------- and back on the subject of Aluminium
    Iron-aluminium compound could replace palladium catalyst, reducing the cost of plastic production
    as catalysts to accelerate reactions or guide them in a particular direction. And this is often the case, as in an important step in the production of polyethylene, a substance that makes plastic bags light, flexible and stable. However, a team of scientists from the Max Planck Institute for Chemical Physics of Solids in Dresden and the Fritz Haber Institute of the Max Planck Society in Berlin have now developed a catalyst using iron and aluminium that works just as well as the conventional palladium catalyst, but costs much less. To identify the iron-aluminium alternative, the scientists first systematically ascertained what properties the material would need. They plan to use this same procedure to search for catalysts for other reactions in future.
    their have their charts ................. we ours
    bonus : result of a search on Boron
    Phys.org Search - boron
  • MonsieurM
    Originally posted by gene gene View Post
    Hi MonsieurM,
    I hope this is not to far off topic, but you seem to have a way with image comparisons so I have one for you.
    I found an interesting image that made me think of your (blue,red,blue) 6,3,9. It is a scope wave form image and can be seen here Schematic self run system. Go down to reply #18 by Romero.
    To me it looks like your 6,3,9 with the 3 flipping. Could flipping the 3 be Tesla's key to the universe?
    Regards, Gene
    You know ........ thought of what you wrote and the image you pointed at ..... it seems like you said the "3" is flipping .....or in other words pulsating
    thank you Gene .... it is quite an intriguing observation .....I will check that book Tesla wrote : The inventions, researches and writings of Nikola Tesla, with special reference to his work in polyphase currents and high potential lighting
    and if you look closer at the image it should remind you of :
    post on Tesla polyphase : http://www.energeticforum.com/renewa...tml#post195288
    what do you think polyphase mean .....
  • gene gene
    Hi MonsieurM,
    Regards, Gene
  • MonsieurM
    Here is a first for you
    Crop Circles in Sarvestan, Nr Shiraz, Fars. Reported 12th June 2012
    IRAN 2012
    Updated Sunday, 17 June 2012 19:43:38
    The First Crop Circle In Iran
    ------------------------- linking a few similar patterns
    " Ovni en Ramos Arizpe, Coahuila." ( 3 de Octubre de 2005.) - YouTube
  • MonsieurM
    info update :
    Before It's News
    The team were able to image all the spins in the special salt, finding that the spins are parallel within pairs of layers, while for adjacent layer pairs, they are antiparallel, as large bar magnets placed adjacent to each other would be. The spin arrangement is called "antiferromagnetic". In contrast, for ferromagnets such as iron, all spins are parallel.
    By warming the material to only 0.4 degrees Celsius above the absolute "zero" of temperature where all classical (non-quantum) motion ceases, the team found that the spins lose their order and point in random directions, as iron does when it loses its ferromagnetism when heated to 870 Celsius, much higher than room temperature because of the strong and complex interactions between electron spins in this very common solid.
    The team also found that they could achieve the same loss of order by turning on quantum mechanics with an electromagnet containing the salt. Thus, physicists now have a new toy, a collection of tiny bar magnets, which naturally assume an antiferromagnetic configuration and for which they can dial in quantum mechanics at will.
    "Understanding and manipulating magnetic properties of more traditional materials such as iron have of course long been key to many familiar technologies, from electric motors to hard drives in digital computers," said Professor Gabriel Aeppli, UCL Director of the LCN.
    "While this may seem esoteric, there are deep connections between what has been achieved here and new types of computers, which also rely on the ability to tune quantum mechanics to solve hard problems, like pattern recognition in images."
  • MonsieurM
    here is a paper written by Maurice Cotterell on gravity
    How Gravity Works - Maurice Cotterell
  • MonsieurM
    you maybe interested in the following Great Discoverer ( one who inspired me quite a bit int this discussion)
    Leon Sprink - Antigravity - patents
    Leon Sprink
    The form (e.g., a cube) was mounted upright and aligned East-West. 1000 to 5000 KV of positive charge (per meter of electrode separation) was applied for two weeks or longer to establish a zone of activation, spreading up to 60 meters :
  • MonsieurM
    from: http://www.energeticforum.com/renewa...tml#post197755
    Originally posted by purelyconstructive
    I submit the following hypothetical situation for your consideration:
    The Fractal Scalar Field
    "God is a circle whose center is everywhere and circumference nowhere."
    Every single point in the boundless field is both Zero and Infinity simultaneously. Absolute Zero is extremely cold, while Infinite White Light is extremely hot. They are in superposition. Two aspects of ONE Thing. "Zero Point Energy" is a (cold) inward contraction and (hot) outward expansion of this field ("Aether", "Space-Time", "Vacuum", "Akasha", "Void", or whatever one may call it) at all points radially. These spherical standing waves overlap to generate a lattice structure that looks like a 3-D "Flower of Life". All manifest things oscillate through it or crystallize upon it in musical ratios.
    Please refer to the following document, A Flower For You, for further ideas.
    Thank you.
    did you notice that the following from your proposal .... looks like a magic Square ( searl effect )
  • MonsieurM
    an interesting article .... worth reading
    Free Energy: What's Consciousness Got to Do With It?
    an excerpt : Before It's News
    In this issue, the eminent Tom Bearden has blessed us again with his understanding and wisdom, this time concerning the impact that human awareness will have on the world when free energy is released: see Taming the Fierce Energy of the Vacuum, Part II. He shows us not only that all things are interconnected, but that zero-point energy, or ZPE, is even more so, for it is the source.
    And if we are looking for proof, William Tiller, Stanford emeritus professor and scientist, provides it. He has just published a book about his experiments that prove scientifically that human thought imprints the physical universe. In The Conscious Creation of a New Paradigm, Dr. Tiller shares with us his own spiritual journey and scientific search. And in How the Power of Intention Alters Matter, he describes how the experiments he performed prove that consciousness can actually restructure the laws of physics! Many have by now demonstrated that prayer works, as we have reported since our first issue. But now Dr. Tiller's experiments explain how it works, and how ZPE and free energy are an intimate part of ourselves.
    Moving even deeper into areas that are not commonly known about, this issue explores the relationship of antigravity to ZPE. Dr. Ted Loder, from the University of New Hampshire, shows us the history of antigravity research and technology, which extends all the way back to the mid-1920s. He describes how our government has been secretly using this new/old science to create a vast, awesomely advanced technology that has given life to, among other things, America's B-2 bomber. And there is much more he has to share with us in his article Antigravity: Space and Energy Technologies for the 21st Century.
    The Schauberger Machine
    Although Dr. Loder does not address it in his article, there is another extremely important antigravity machine in existence that was originally created by the Germans during World War II. It's called the Schauberger engine, and it was taken up by America after the war.
    It is our understanding that the Schauberger engine will ultimately transform the world, for its antigravity technology makes obsolete all current forms of space, air, land, and water travel by introducing the power to simply levitate.
    The Schauberger engine contains nothing but water
    Before It's News
    Got Mass? Princeton Scientists Observe Electrons Become Both Heavy And Speedy
    A Princeton University-led team of scientists has shown how electrons moving in certain solids can behave as though they are a thousand times more massive than free electrons, yet at the same time act as speedy superconductors.
    The observation of these seemingly contradictory electron properties is critical to the understanding of how certain materials become superconducting, in which electrons can flow without resistance. Such materials could dramatically increase the efficiency of electrical power networks and speed up computers.
    The concept of "heavy" electrons seems counterintuitive. The tiny particles flit through silicon chips to process information rapidly in digital electronics, and they flow with ease through copper wires carrying electricity to your desk lamp. But the Princeton research has revealed that a hard-to-measure process known as quantum entanglement determines the mass of electrons moving in a crystal and the delicate tuning of this entanglement can strongly alter the properties of a material.
    Cool the electrons to far below room temperature in certain types of solid materials, and these flighty particles gain mass, acting like much heavier particles. Surprisingly, further cooling close to absolute zero makes these solids become superconducting, where the electrons, despite their heaviness, make a kind of perfect fluid that can flow without wasting any electrical power.
    Electrons moving in certain solids can behave as if they are a thousand times more massive than free electrons, but at the same time act as superconductors. A new study led by Princeton scientists shows that this happens because of a process known as quantum entanglement that determines the mass of electrons moving in a crystal. The discovery can help improve understanding of how certain materials become superconducting, which may have applications in areas such as power network efficiency and computing speed.
  • MonsieurM
    a repost from: http://www.energeticforum.com/psychi...ntenna-28.html
    Hermetic philosophers have taught the very same fundamentals
    even as philosophers of the future will do, for that which constitutes
    truth will remain truth. It cannot be changed. But the theories of men
    and their opinions, which are incorrectly given by some as truth, are
    subject to change. Because one calls himself a philosopher does not
    necessarilv make him such. Only he is a philosopher who has a sincere
    love for the wisdom that manifests universally and who strives as
    sincerely to apply it in his daily life. Wisdom is acquired through
    righteous living. It is understanding applied. The acquisition of a
    degree of Doctor of Philosophy, as conferred upon graduates in
    institutions of higher learning, does not make one a philosopher, as
    much as those in possession of such a degree may believe in their
    right to such a title.
    To be acquainted with the history of philosophy, the lives and
    teachings of those called philosophers, is only a study and knowledge
    of their universal concepts and what has been derived from them.
    To be a philosopher, therefore, means to understand and live according
    to that understanding, knowing well that only by giving unhesitatingly
    and unselfishly will our belief in mankind be justified. When this
    has been realized, then only will Alchemy become something real.
    Transmutation always takes place on a higher plane, and in the physi-
    cal world laws cannot be adhered to or violated without producing
    karmic manifestations. Beneficial karma, if it is permissible to use a
    term, because karma is impartial, is brought about by harmonious
    applications of natural laws. These natural laws must be adhered to if,
    according to predestined results, we wish to obtain what nature has
    decreed
    BBC Shock and Awe: The Story of Electricity [2/3] - The Age of Invention (2011) - YouTube
    you want to know why it is important .... To be acquainted with the history of philosophy, the lives and
    of their universal concepts and what has been derived from them. ...... because when you know the origins of the knowledge you acquired ... and they came from places you thought were "inferior " to your society ( whatever it maybe ) .... you will resonate humility as you grow in knowledge for you will realize in the words of Sir Isaac Newton ( who spoke fluent Arabic... for your knowledge )
    If I have seen further it is by standing on ye shoulders of Giants.
