  • MonsieurM
    Look around you and within you and you will understand:
    A network is a group of two or more systems linked together
    Networks magnify whatever they are seeded with, good or bad
    COHERENCE AT ANY LEVEL IS COHERENCE AT ALL LEVELS.
    An orderly arrangement between wave lengths establishes a connection between frequencies and fields. But for this connection to last, it must resonate to all frequencies and fields. This can only be accomplished through the resonate structure of golden mean pathways. a harmonic cascade effect
  • MonsieurM
    just to share with you image of version 2.0 of the Dowsing Rod ... a Mobius Caduceus Coil .... been testing it for all kind of targets and surprisingly accurate ( had a friend hide my keys ... it did the job ) .... quite an easy experience ..... you can try it yourselves
    most who did try were quite surprised
    reminder of measurement :
    2 bars of 63 cm
    fold at 90 degrees
    handle is 18 cm
    long part is : 45 cm
    for the coils .... try to follow the same Harmonic Math
    ps:
    Beliveing is seeing
    How to use divining rods - YouTube
  • MonsieurM
    Consider the following as a Scientific Metaphor to your own Alchemical Transformation ( a Fractal Construct ) :
    Thanks for the memory: More room for data in 'phase-change' material
    The work was reported April 16 in the online edition of Proceedings of the National Academy of Sciences.
    The research focused on an inexpensive phase-change memory alloy composed of germanium, antimony and tellurium, called GST for short. The material is already used in rewritable optical media, including CD-RW and DVD-RW discs. But by using diamond-tipped tools to apply pressure to the materials, the Johns Hopkins-led team uncovered new electrical resistance characteristics that could make GST even more useful to the computer and electronics industries.
    "This phase-change memory is more stable than the material used in the current flash drives. It works 100 times faster and is rewritable about 100,000 times," said the study's lead author, Ming Xu, a doctoral student in the Department of Materials Science and Engineering in Johns Hopkins' Whiting School of Engineering. "Within about five years, it could also be used to replace hard drives in computers and give them more memory."
    GST is called a phase-change material because, when exposed to heat, areas of GST can change from an amorphous state, in which the atoms lack an ordered arrangement, to a crystalline state, in which the atoms are neatly lined up in a long-range order. In its amorphous state, GST is more resistant to electric current. In its crystalline state, it is less resistant. The two phases also reflect light differently, allowing the surface of a DVD to be read by A tiny laser. The two states correspond to one and zero, the language of computers.
    Although this phase-change material ( You ) has been used for at least two decades, the precise mechanics of this switch from one state to another have remained something of a mystery because it happens so quickly -- in nanoseconds -- when the material is heated.
    To solve this mystery, Xu and his team used another method to trigger the change more gradually. The researchers used two diamond tips to compress the material. They employed a process called X-ray diffraction and a computer simulation to document what was happening to the material at the atomic level. The researchers found that they could "tune" the electrical resistivity of the material during the time between its change from amorphous to crystalline form ( you again ).
  • MonsieurM
    Continuing on our info gathering:
    here is an example of Morphic Resonance / Fractal Resonance:
    Rules of attraction
    Nicholas Christakis, whose research has shown how everything from obesity to smoking to happiness spreads through social networks, said Monday that the human ability to form lasting relationships results from a trade-off between greater access to information provided by our networks and the increased exposure to disease that networks bring.
    Assortativity is the tendency of popular people to be connected to other popular people and the tendency of unpopular people to be connected to unpopular people
    Networks magnify
    think 1% vs 99%
    Lightning signature could help reveal the solar system's origins
    Every second, lightning flashes some 50 times on Earth. Together these discharges coalesce and get stronger, creating electromagnetic waves circling around Earth, to create a beating pulse between the ground and the lower ionosphere, about 60 miles up in the atmosphere. This electromagnetic signature, known as Schumann Resonance, had only been observed from Earth's surface until, in 2011, scientists discovered they could also detect it using NASA's Vector Electric Field Instrument (VEFI) aboard the U.S. Air Force's Communications/Navigation Outage Forecast System (C/NOFS) satellite.
    In a paper published on May 1 in The Astrophysical Journal, researchers describe how this new technique could be used to study other planets in the solar system as well, and even shed light on how the solar system formed.
    "The frequency of Schumann Resonance depends not only on the size of the planet but on what kinds of atoms and molecules exist in the atmosphere because they change the electrical conductivitySchumann Resonance from above still requires the instruments to be fairly close to the planet, so this technique couldn't be used to investigate from afar the atmospheres of planets outside our solar system. Instead, scientists imagine something much more dramatic. After a spacecraft is finished observing a planet, it could continue to detect Schumann resonance as it begins its death dive into the atmosphere. During the process of self-destruction, the spacecraft would still provide valuable scientific data until the very last minute of its existence.
    resonate this info with :
    Shoshana Zuboff: When Global Warming Ate My Life
    I was shocked to discover that when it comes to increased lightning frequency and destructiveness, a NASA study concluded that eastern areas of North America like Maine are especially vulnerable. Scientists confirm a 10% increase in the incidence of extreme weather events in our region since 1949.
  • MonsieurM
    a bit of info :
    Cairo Calendar shows Egyptians discovered binary Algol first
    (Phys.org) -- Algol, aka the Demon Star, is actually a binary star in the Perseus constellation, and has been the subject of speculation for hundreds of years. Now a group of Finnish researchers propose that the peculiar behavior of Algol was first noted by the Egyptians some 3200 years ago. They suggest, as they describe in their paper uploaded to the preprint server arXiv, that a document known as the Cairo Calendar, shows that not only did the Egyptians know about Algol, but that their observations can be used to further explain the erratic behavior of the binary seen today.
    -------------------------here is an intriguing one as we have previously discussed European Royalties and their lineage :
    BBC News - Portrait of Queen Elizabeth I reveals secret snake
    A mysterious image of a coiled snake has appeared in a 16th century painting of Queen Elizabeth I, the National Portrait Gallery has said.
    The Tudor queen was depicted with the snake clasped in her fingers in an original version of the work, but it was replaced with a bunch of roses.
    note the snake is held on the right hand
    originally found: Painting of Queen Elizabeth
  • MonsieurM
    wanted to share the following with you:
    Thank you again Lamare , you made it easier to understand
    Originally posted by lamare
    Originally posted by MonsieurM
    Hello Lamare , i have been following some of your posts as they are quite interesting ( although some are beyond my mathematical knowledge ) ; the reason for this message is that through the course of the discussion taking place in the golden tractate threat, i stumbled on a website that has some intriguing math and it kind of resonate with Dollards math .... could you have a look , and let me know what you think of it .... keep your mind open :
    UMMO - UMMITE PHYSICS AND METAPHYSICS - A new website devoted to the Ummites - general introduction
    a little excerpt:
    Hi MonsieurM,
    I printed the first 42 pages of the word document on that site and read it in the train home from work.
    It is quite an intriguing read and I experienced kind of a battle between my feelings and my ego mind.
    So, you could say it did touch a nerve or two..
    What I understand of it, is that they basically say the Universe consists of some kind of entities that exist outside of our notion of time and space. To me, that would mean some kind of abstract entity that exist in the shape of pure information.
    You see, information just exists. It exists outside of space and time. It just IS. And that resonates very nicely with your sig...
    Now when you know how a computer works deep down, it is in essence pure logic being "executed" or "animated" by a machine that follows just a few very simple binary logic rules. These are implemented using transistors, configured as logic "nand" "gates", that change their state at pre-determined times. In other words: ruled by a clock.
    So, in essence it's a machine that "executes" binary logic, ruled by a clock signal.
    At a higher abstraction level, like in a higher object oriented programming language like C++, you can define all kinds of abstract "objects" which you can program to have all kinds of interactions with one another, in essence the exchange of information.
    So, all of this is, in essence, information and "thought constructs" being "animated" by a machine.
    However, it is thinkable that the same kind of "objects", abstract thought constructs, in essence pure information, COULD also be "animated" by another kind of machine, which would be "consciousness".
    And of course, you could also think of other kinds of "anmiation machines" than machines based on binary logic.
    So, it appears to me we are looking at the definition of some kind of abstract objects, characterized by "angles" (or, in my interpretation, "perspectives") that are "animated" by some kind of "computing" "machine" using a different kind of "logic" or "programming language" than what we are using.
    In this idea, our consciousness would be "a program" or "object" animated by this "computing machine", which interacts with other "animated objects" by means of this "computing machine" according to certain rules.
    In this thought-construct, the "animated objects" exist in some abstract "machine", but are not ordered within 3D space and time. And under certain rules, "matching angles", these "animated objects" can interact with one another, or, exchange information and thus create the illusion of space and time.
    Within such a scenario, the Universe would thus be a very convincing illusion, a simulation not unlike a computer game, "animated" by some kind of advanced "computer" existing outside of what we perceive as space and time.
    And that connects very nicely to what Bashar tells us. See for example:
    Bashar Explains The Holographic Universe - YouTube
    Bashar on Creating in the YOUniverse - YouTube
    Bashar - Infinite Parallel Realities - YouTube
    Bashar - "Shifting Through Infinity" - June 19, 2010 - YouTube
    (i.e.: I just googled these Bashar vids, can't listen to them at this computer, since I broke my sound card some time ago.)
    from: http://www.energeticforum.com/psychi...tml#post166867
    Principle of correspondence:
    Originally posted by clueless View Post
    That from a 2002 article. Unlike so many other promising breakthroughs this is one that has been widely implemented.
    To further quote from the article: "The innovation, called Fractal Structure Circuit(TM) (FSC), uses fractalized conductor paths to replace the capacitors, inductors, and resistors in "RLC" circuits."
    And another quote: ""Virtually every electronic device uses coils and capacitors to form RLC circuits. These discrete components are arranged by tried and true rules to get the circuit to perform as needed. What we've done is ask: can a fractal pattern, with its self-capacitance and self-inductance, be used to eliminate components and still get the equivalent RLC circuit? We've found that the answer is yes; and in most uses, especially at microwave frequencies, all components can be replaced by conductive fractal patterns or 3D structures."
    And one more blurb from that article: " Looking at the Fractal Structured Circuit(TM) one sees, for example, a beautiful etched copper pattern replacing the usual traces connecting button or canned shaped capacitors and coils (or their SMT counterparts). "
    Here is the link to that article.
    Fractal Antenna Systems, Inc.
    Apparently it is in wide use in cell phones, their antennas and some microwave circuits.
    People are making homemade fractal HD antennas using coat hangers as one instance of using a common material.
    I think this feature; fractuals should be used in some builds to take advantage of a wideband of frequencies and resonance. Maybe it will be useful in the Muller/Romerouk build.
    For those that be interested google fractal circuits and fractal antennas.
    I do not have the resources/space/knowledge to do any builds at the moment but I am curious enough to verify if a HD antenna can be made simply using fractals and common materials.
    Any way something to consider.
    -RG signing off
    so if you change perspective you are looking at a different fractal circuit .... ie our discussion
  • MonsieurM
    Let's try an experiment ... took a random picture of a patent by Tesla and the Magnifying transmitter :
    Nikola Tesla: Mechanical Oscillator ~ US Patent # 514,169 & # 517,900 ~ Tele-Geodynamics
    If you look at this construct and its measurements / Ratios :
    and let it resonate with this design found in some of Walter Russell's Work :
    you end up with .... a little surprise for you:
    either way it works .... Fractal remember
    if you keep on polarizing yourself on the bemf / whatever emf ... (all due respect ) .... you will only be obsessing on on the effect and not the cause ... as walter Russell said it :
    "...I always looked for the Cause behind things and didn't fritter away my time analyzing Effect.
  • MonsieurM
    Remember what Tesla's Mom told him :
    find all the Truth in the Bible ... his was the sacred Book and Nature mostly
    you want to find out about Tesla's Truth ....then look at all his Truth and combine them ....and you will still find the same Design :
    it is shown in all his Patents .... just put the two constructs together and you'll start to see them resonate... it may appear as if seen through a different angle / dimension ... but it is there
    My brain is only a receiver, in the Universe there is a core from which we obtain knowledge, strength, inspiration. I have not penetrated into the secrets of this core, but I know it exists
    Nature may reach the same result in many ways. Like a wave in the physical world, in the infinite ocean of the medium which pervades all, so in the world of organisms, in life, an impulse started proceeds onward, at times, may be, with the speed of light, at times, again, so slowly that for ages and ages it seems to stay, passing through processes of a complexity inconceivable to men, but in all its forms, in all its stages, its energy ever and ever integrally present. A single ray of light from a distant star falling upon the eye of a tyrant in bygone times may have altered the course of his life, may have changed the destiny of nations, may have transformed the surface of the globe, so intricate, so inconceivably complex are the processes in Nature. In no way can we get such an overwhelming idea of the grandeur of Nature than when we consider, that in accordance with the law of the conservation of energy, throughout the Infinite, the forces are in a perfect balance, and hence the energy of a single thought may determine the motion of a universe. Nikola Tesla
  • MonsieurM
    here is a nice vid you might like : start at 5 min 5 s
    Super Lethal Plasma Ball! (-Ultra- Overclocked) - YouTube
    Placing a hand near the glass offers an attractive place for the energy to flow. The capacity of the body to accept radio-frequency energy is greater than that of the surrounding air. The energy available to the filaments of plasma within the globe will preferentially flow toward the better acceptor. The energy is flowing through the filaments, so the filaments move too. This flow also causes a single filament, from the inner ball to the point of contact, to become brighter and thinner.[1] The filament is brighter because there is more current flowing through it and into the 150 pF capacity, or capacitance, presented by an object the size of a human. The filament is thinner because the magnetic fields around it, augmented by the now-higher current flowing through it, causes a magnetohydrodynamic effect called self-focusing: the plasma channel's own magnetic fields create a force acting to compress the size of the plasma channel itself.
    one think you should now ... the plasma ball is also an Antenna reflecting any change outside the Ball .... do you think those Plasma filament are moving at random or like trees:
    Seeing the forest through the trees
    Imagine you are walking through a forest. All around you are trees of different species, age, size and height. It looks pretty random, right? Wrong.
    In research funded by the National Science Foundation, Brian Enquist of the department of ecology and evolutionary biology at the University of Arizona and his team have discovered a secret in the trees: Hidden among and within the architecture of the branches are fundamental rules that link the size, shape, age and in fact everything about a single tree to all the trees in a forest.
    think of these filament as electric trees
    Dueling Banjos - YouTube
    ----------------------from http://www.energeticforum.com/psychi...ntenna-50.html
    this design is probably the missing piece in Teslas communication and electric Coil Apparatus: a Caduceus inside Metal Ball to complete the design ( for the heater Caduceus with Barium titanate or Magnetite bar see Petar experiments here : http://www.energeticforum.com/renewa...er-heater.html : )
    [IMG]
  • MonsieurM
    now read the following and apply the principle of correspondence
    As Above so Below
    Plasma globe - Wikipedia, the free encyclopedia
    you do realize that this method is applicable to all his inventions / Truth
    ps: Glass is quartz
  • MonsieurM
    a few more quotes .... to get the idea :
    Nikola Tesla Quotes
    the female mind has demonstrated a capacity for all the mental acquirements and achievements of men, and as generations ensue that capacity will be expanded; the average woman will be as well educated as the average man, and then better educated, for the dormant faculties of her brain will be stimulated to an activity that will be all the more intense and powerful because of centuries of repose. Woman will ignore precedent and startle civilization with their progress
    We are whirling through endless space ( cols space ), with and inconceivable speed, all around everything is spinning, everything is moving, everywhere there is energy. There must be some way of availing ourselves of this energy more directly. Then, with the light obtained from the medium, with the power derived from it, with every form of energy obtained without effort, from the store forever inexhaustible, humanity will advance with giant strides. The mere contemplation of these magnificent possibilities expand our minds, strengthens our hopes and and fills our hearts with supreme delight.
    The gift of mental power comes from God, Divine Being, and if we concentrate our minds on that truth, we become in tune with this great power. My Mother had taught me to seek all truth (fractal )
    Nothing enters our minds or determines our actions which is not directly or indirectly a response to stimuli beating upon our sense organs from without
    Three are the natures of Mind,
    carrier it of the Will of the Great One.
    Arbitrator of Cause and Effect in thy life.
    Thus is formed the threefold being,
    directed from above by the power of four.
    I have thought of a number of other uses to which this principle may be put (fractal / principle of correspondence ) )
    some planets are not inhabited, but others are, and among these there must exist life under all conditions and phases of development.
    so call them the Akashic Records or Book of Knowledge
    Pierluigi Ighina
  • MonsieurM
    sometimes all it take is a change of perspective and two fractal constructs 6 and 9 to give you a 3 .... inspiration .... which led Tesla to create :
    Plasma globes, or plasma lamps (also called plasma balls, domes, spheres, tubes or orbs, depending on shape), are novelty items that were most popular in the 1980s.[1] The plasma lamp was invented by Nikola Tesla[2] after his experimentation with high-frequency currents in an evacuated glass tube for the purpose of studying high voltage phenomena, but the modern versions were first designed by Bill Parker.[1] Tesla called this invention an inert gas discharge tube.[3]
    PowerPedia:Walter Russell - PESWiki
    Nature's first principle of power prdouction and the construction of matter is to produce heat from the cold of space.
    Principle of Mentalism .... Tesla knew it too
    the whole earth will be converted into a huge brain, which in fact it is, all things being particles of a real and rhythmic whole.N. Tesla
  • MonsieurM
    I forgot to add that there is one element we tend to forget or overlook (take it for granted )
    but all the planets ( and other elements of the Universe ) evolve in a " Vacuum" ... so if you were to replicate Russell's Coils as Savvypro mentioned:
    Looking at the picture of Jupiter, a picture of a Walter Russell coil overlaid on the planet appeared in my mind.
    testing it in a Vacuum ... think of it as a larger version of a Vacuum Tubes which coincidently Tesla worked with as well
    How to make a vacuum tube - Hack a Day
    it is also called biomimetics
    just try to visualize the following ( not saying believe it is true ; just a change of perspective )
    Electricity and Magnetism
    Ed said that the academic idea that they are sending electrons through wires as you electric service is also false. Helical coils of electricity flow in spiraling rings around the wires.
    now what happens to two overlapping solid coils ( Russell Coils ) if you add electricity ;these helical coils of electricity will overlap flowing in opposite direction... see last figure
    the half version / Male version / Expand see fig 127 Tesla Cone
    here is a close example : Bashar's Coils
    so what happens when the electric helical coils of the black coil and the copper coil meet ( see the two planets in the drawing and Jupiter pic for an aerial view ) ) .... from this perspective the setup will be fractal
  • MonsieurM
    From either end you would see the CW and CCW of the coils. If the spacing of the coils is done right one will go with the CW and the other with the CCW, with the feilds.
    What would happen if a round magnet (e.g. 1 cm diameter x 3 cm long - that type of round magnet), was placed in the middle?
    when these two opposing ( male ( larger ) / Female (smaller) ) coils are in the right resonance .... a perpendicular vortex gets created pointing towards the center were the magnet would be just like a tornado would
    see example below:
  • Dave45
    Now let us resonate 2 fractal constructs together .... just remember
    Runaway planets ejected from galaxy at insane speeds - CSMonitor.com
    a sling shot of sort
    Were the planets ejected at the core or outer circumference?
