  • llynch
    M.,
    7 came to mind with your posting regarding that interesting biological experiment using 7hz. Your recall with images still amazes me!
    The dam is a beautiful analogy that fit precisely. Imagine chipping away at the dam and then finally a crack appears and the 'waters' trickle out at first, then in what seems like a cascading avalanche the crack turns into a gap then a major opening that progressively reduces the damn to nothing more than a few small pieces scattered along the river.
    That is what cognitive behavior therapy is like.
    A good book find the previous night:
    Nature's harmonic unity: a treatise on its relation to proportional form : Samuel Colman, Clarence Arthur Coan
  • MonsieurM
    Thank you Llynch for this great post and mentioning Lully another great master ( just discovered him through Fulcanelli's book ) .... you triggered an interesting pattern with the Number 7 ...... it relates to a man who had prophetic visions ( we discussed him previously ) : now i understand one of his prophecy
    the dam holding the water is what people experience as Kundalini
    The moon crater of the seven circular stair will disclose its secret to the man. (no date)
    Originally posted by llynch View Post
    Here are few quotes from "The Hermetic Tradition" by Julius Evola.
    Knowing that one has to 'know thyself' prior to knowing anything else (a lot of word 'know' going on here)... Including my personal practicing of Cognitive Behavior Therapy has led me to believe that the Vedic text, Buddha texts, Hermetic texts all alike speak profoundly on the same process used in Cognitive Behavior Therapy.
    Though their use is a much more subtle and complete application of the modern process. Even so, the process is present at all scales.
    Repeated distillation to obtain the highest purity is the basic process. Imagine a conditioned response such as 'road rage' or angered defensiveness. There are a bazillion things that trigger each of these. Mindfulness of the mind is required to 'distill' (bring to light and contemplate) each one that arises. The end goal being aware of self without all the 'boat anchors' we have been conditioned with through our lives.
    The 'seven' mentioned many times I relate directly to the Chakras which then can provide a personal understanding of where those bazillion triggers may lie within a person.
    Anyway, wanted to share my perspective on it. That is not to say that some of the more curious things are not true, but the only way to find out is to clean out the attic.
    Stellar3:
    You seem to be in the place I was at a few years ago. A while back someone gave me a nudge (*cough M.), so you are getting the nudge in return. Trust in and follow your curiosity. The places it will take you will teach you all you need to know and much much more.
    A tip on efficient learning, cut and paste names and books mentioned while reading. This is how knowledge propagates outward like a fractal. The further back in time you start, the bigger the fractal branch is. Neat stuff.. enjoy yourself!
    Oh, the second quote. Marcel Vogel The Legacy of Marcel Vogel
  • llynch
    In relation to the Pendulum patterns:
    The day has been spent considering the attributes of each pattern that distinguishes one from the other.
    1) Number of circles
    2) Shape of circles
    3) Number of Vesica Pisces
    4) Shape of Vesica Pisces
    Defining that it became clear as the number of circles increased the size of the Vesica Pisces decreased.
    Also that as the number of circles increased their elongation reduces toward that of a circle.
    The desire to designate each circle as 1hz keeps coming up. Feels like it fits with the 7.8hz Shumann Resonance which I believe is a resonating wave the harmonic ring of the orbit of each planet generates. Cause and affect could take this one way out there.
    If there is a relationship, it is very possible that the patterns generated by the orbits of each of the individual planets (possible in combination as well) could be responsible for a pendulum generating the same patterns at a smaller scale.
    Fertile ground for thought when considering the repeated nature of the number seven in many places. Not discounting the harmonics and sub-harmonics.
    Edit:
    A few more things after sleeping on it.
    Mentally I rotated one of the simpler patterns 90 degrees and extruded it. (3d graphics application terms)
    The Vesica Pisces could be considered as two vibrations/signals/waves 90 degrees out of phase with each other.
    Each pair of opposing circles could be considered the same.
    The original 7 x 9 grid could possibly be related to the Hermetic numbers 7 and 9.
    The Vedas may also posses a reference to the same numbers as well. (if it's in the Vedas it is most likely in all other religous writings)
    Futher contemplation gives me the impression that the Vesica Pisces (within the concept of the solar system contained within a elongated field) would be two predominant vibrations not being generated by any of the planets but from the prolonged interaction of the sun and the field. Carrying the thought further, if the sun is traveling through the galaxy one would think that the field around the sun would experience a sort of buffeting action as it passes through differing densities of the galactic medium. Taking the thought full circle, 1 becomes 2 becomes 3 becomes the many thousands.
    I like mornings!
  • llynch
    Stellar3:
  • MonsieurM
    To this end they compared the rules of syntax (the way in which words are put together to form phrases and sentences), semantics (the study of meaning in language forms) and the basic rules of grammar. They found that the alkalines of our DNA follow a regular grammar and do have set rules just like our languages. Therefore, human languages did not appear coincidentally but are a reflection of our inherent DNA.
    could this be the famous Alkahest :
    Alkahest - Wikipedia, the free encyclopedia
    Alkahest is a hypothetical universal solvent,, water is sometimes called the universal solvent as well, because it can dissolve a large variety of substances, due to its chemical polarity.
  • MonsieurM
    Originally posted by Stellar3 View Post
    Could we also be superconductors?
    the following may answer your question :
    Russian DNA Discoveries Explain Human 'Paranormal' Events
    The Russian researchers, however, convinced that nature was not dumb, joined linguists and geneticists in a venture to explore that 90% of "junk DNA." Their results, findings and conclusions are simply revolutionary!
    According to there findings, our DNA is not only responsible for the construction of our body but also serves as data storage and communication. The Russian linguists found that the genetic code - especially in the apparent "useless" 90% - follows the same rules as all our human languages.
    The Russian biophysicist and molecular biologist Pjotr Garjajev and his colleagues also explored the vibrational behavior of DNA. In brief the bottom line was: "Living chromosomes function just like a holographic computer using endogenous DNA laser radiation." This means that they managed, for example, to modulate certain frequency patterns (sound) onto a laser-like ray which influenced DNA frequency and thus the genetic information itself.
    Since the basic structure of DNA-alkaline pairs and of language (as explained earlier) is of the same structure, no DNA decoding is necessary. One can simply use words and sentences of the human language! This, too, was experimentally proven!
    Living DNA substance (in living tissue, not in vitro) will always react to language-modulated laser rays and even to radio waves, if the proper frequencies (sound) are being used. This finally and scientifically explains why affirmations, hypnosis and the like can have such strong effects on humans and their bodies. It is entirely normal and natural for our DNA to react to language.
    more info in the link provided
    alpha quartz
    both alpha quartz and dna are coaxial helices
  • Stellar3
    Fractal Antennae
    it seems that Moray Agrees with me on the LC / 6 3 9 Circuit (http://www.energeticforum.com/160924-post201.html ) when he wrote:
  • MonsieurM
    Originally posted by purelyconstructive
    "In the beginning was the Word..."
    "As I speak, I Create."
    also know as ABRACADABRA ...... or some believe it is derived from ABRAXAS
    Abracadabra - Wikipedia, the free encyclopedia
  • llynch
    In relation to Vowels and Vibration and how they affect the world:
    Sound out the words and note the sound of the vowels:
    Group 1:
    love
    glad
    happy
    joy
    soul
    mind
    Group 2:
    hate
    fear
    afraid
    would
    could
    tears
    Kinda makes sense that Group 1 would be a basis for propagation of increasing complexity. I believe this is where the power of words resides.
    If you listen to one of the many Terrence McKenna talks you can notice the flow of sounds vowels are predominantly from Group 1. Comparison with a political speech should refine this pattern.
  • llynch
    Now that sir, is perspective genius! lol I believe I will avail myself of some of it and see what is gathered under the stone also. Brillant eye M. truly so.
    Maybe overlay multiples of 2.
    From that highlighted list designate the d/n values?
  • MonsieurM
    or consider each chapter value as d or n ( of course this is one option amongst many others )
    and each line as d or n 'depending on what you chose previously :
    so for instance
    Genesis 1 Chapter 1
    let's say that we assign to chapter 1 = d 1
    line one of chapter 1 is : line 1 = n 1
    1: In the beginning God created the heaven and the earth. d1 n 1
    2: And the earth was without form, and void; and darkness was upon the face of the deep. And the Spirit of God moved upon the face of the waters. d1 n 2 ( note that it corresponds to the figure posted earlier drawn by V. Schauberger )
    3 : And God said, Let there be light: and there was light. d1 n 3
    etc ......
    you can do the same with john : John 1 KJV
    1 In the beginning was the Word, and the Word was with God, and the Word was God. d1 n 1
    2 The same was in the beginning with God.
    3 All things were made by him; and without him was not any thing made that was made.
    4 In him was life; and the life was the light of men.
    5 And the light shineth in darkness; and the darkness comprehended it not.
  • llynch
    can't we associate the cymatic table with the Book of Genesis ( Genesis, from The holy Bible, King James version )
    It is possible as all things are... replacing names of people and places with todays terms for the process(cycle/sine) being described and the events that are noted which occur repeated regular intervals.
    Actually gave it a go a couple of times using the galactic scale as my canvas... it gets complex quite quickly (this was before I knew of the scale boundary markers). The solar system scale we have many more terms for. At the planet scale we have an extreme amount of words.
    This quote sums it up pretty good. There is also Veda reference (escapes me which it is in) that does not jump from 3 to a thousand. It does have a grand jump though. There is always that point of dramatic increase when using words though. Maybe the cellular development of a child in womb would show it visually better?
    From the Tao Te Ching:
    42
    The Tao begot one.
    One begot two.
    Two begot three.
    And three begot the ten thousand
    things.
    thebigview.com - Download Section
    The Shrodinger Equation image from Bedini's Gabriel Kron page shows this distributed increase in complexity.
    Image from: Welcome to John Bedini
    Note that it uses '3' individual variables.
  • MonsieurM
    well well ... history loves to repeat itself ..... on a smaller scale
    Nanoscientists suggest use of vacuums to overcome limits of conventional silicon-based semiconductor electronics
    With a new spin on an old method: a switch from the use of silicon electronics back to vacuums as a medium for electron transport
  • MonsieurM
    I think you might find these related to your last posts
    Want bigger plants? Get to the root of the matter
    Plant scientists have imaged and analyzed, for the first time, how a potted plant's roots are arranged in the soil as the plant develops. In this study, to be presented at the Society for Experimental Biology meeting on 30th June, the team has also found that doubling plant pot size makes plants grow over 40% larger.
    you got to love science ...... colloids were known to Alchemist used in the Rose Windows of Cathedrals
    A Colloidal Display: membrane screen that combines transparency, BRDF and 3D volume - YouTube!
    Yoichi Ochiai, Alexis Oyama and Keisuke Toyoshima, A Colloidal Display: membrane screen that combines transparency, BRDF and 3D volume, ACM SIGGRAPH 2012 Emerging Technologies, Poster, Talks (in publish)
    The Colloidal Display proposes an innovative solution which transforms a soap film into the world's thinnest screen. This screen's transparency, texture, and shape can be controlled dynamically by using ultrasonic sound waves. The screen's unique material, which allows objects to pass through, promotes new ways of interaction.
    It is a common knowledge that the surface of soap bubble is a micro membrane. It allows light to pass through and displays the color on its structure. We developed an ultra thin and flexible BRDF screen using the mixture of two colloidal liquids. There have been several researches on dynamic BRDF display[1] in the past. However, our work is different in several points. Our membrane screen can be controlled using ultrasonic vibrations. Membrane can change its transparency and surface states depending on the scales of ultrasonic waves. Based on these facts, we developed several ap- plications of the membranes such as 3D volume screen.
    The combination of the ultrasonic waves and ultra thin membranes makes more realistic, distinctive, and vivid imageries on screen. This system contributes to open up a new path for display engineering with sharp imageries, transparency, BRDF and flexibility.
    Yoichi Ochiai, Alexis Oyama, Keisuke Toyoshima
  • MonsieurM
    M.,
    Processing is also available for linux:
    Download \ Processing.org
    it may be in the package repository for the linux distro you use.
    In reference to making energy or creating the conditions for its extraction:
    Hope that didn't cause any mental distraction from what you are currently contemplating.
    Not at all .... to the contrary ... your thoughts enlighten this discussion in various ways ... All is Analogy ...
    if i may sum up what you just wrote :
    Coherence at All Levels and Dimensions ... each solid element used should be considered in a way as a Wave / frequency ... that will interact with the introduced wave .... and thus affect the symphony you want to create
    BOLERO-RAVEL - YouTube
