I need some suggestions...
this thing is locking up all my reed switches. they are only working intermittently, and I think they are either burning up, or just magnetically locking up, because I can't get a steady stream going right now.
If anyone has a simple switching circuit they could share with me, I would really appreciate it!
the simpler the better, I have several different kinds of NPN transistors, and a couple of coils I can work with, I just need something that will short this primary coil consistently so I can take good measurements off of the secondary, and measure the input.
the only switching circuit I know how to make is the SSG, and I don't think that will work here.
when the reed switches are working, I am getting extremely bright light out of both legs of the neon! I really want to keep messing with this thing, but I need a more reliable shorting method than the standard reed switch.
I do have couple of 4 pin hall sensors, but I don't know if those would even work for plain switching. I also don't know how to use them
thanks in advance for anyone who can help me out here
N8
N8
). when the neon gets stuck on, I can smell the O3 being made coming out of the reed switch. also when the neon is stuck on, I hear an intermittent clicking noise coming from the reed switch, almost like it's self switching some how...
) of the exciter circuits, and I am glad that you mentioned it! I will have to look up the slayer circuit on the thread, and see if I can't make something happen with that! the AV plug I can try tonight for sure, I have seen one before, and should be able to put one together quick, I will post results on that shortly
If you can get a "pickup" coil or piece of wire near the ignition coil secondary to get the transistor to switch that way instead of an external aluminium tray then it can be made neat and tidy and your results can be more accurate because everything's in exactly the same place as it was the last time etc.
