Quick thought just flashed through my mind.
Ignition coil, magneto, spinning wheel....
Erm, if you made a flat surface to mount the gear on, then turned the wheel 90 degrees and put 3 more at the other corners, you have a car.
Use the HV from a Slayer circuit wireless system to power the coils that then resonate with the transmission tower.
Paint it all black and there ya go, pulse motor technology, Tesla wireless powered Model T
For exciter tests - I recently re-posted the Mega-test PDF of common transistors in the Joule Thief exciter thread, so hopefully that helps. Anything I do comes from junker boards. Mainly though, for any transistor you put '2S' in front of the number, such as a C945 as seen written on it becomes 2SC945. Just type that in in Google and you'll get the datasheet. Look for high hFE (like 200+), low saturation voltages (like 0.3V) and a switching speed of above 150MHz. Power handling should be above 500mA for an all round winner and some kind of heatsink should be used for long period tests.
PNP transistors are just as good to find as NPN's, but the Slayer circuit, as is, is for the more common NPN's.
I've just broken a reed switch myself, one of the dark green glass ones. It just sits there stuck now. Thing is, it was running from about 1V off a solar panel, so i'm thinking its a combination of the neos being too strong and the switching speed being too quick.
and if nothing happens touch the trays with your hands, but don't let them touch each other directly.
