  • MonsieurM
    Yeaaahhhhh
    just a thought but your experiment made me think (just now) of this set up:
    if it can work on heat ; it can work on cold.....
    I had to say this before it skips my mind; you can use this set up when you cool your melted crystal batteries faster
    Dave, this could be the way to shape it ...pulsed dc is a requirement i think..and also you may have to reverse the electrodes for the cooling set up (principle of polarity )
  • Dave45
    This reminds me when I tore a couple of car starter solenoids apart to get the coils there was an iron ring around the solenoid for this field to run in but it was split to stop the field from completing its path.
    This is what they call lenz, we are trying to prevent lenz when we should be trying to tie into it.
  • Dave45
    Yeaaahhhhh
    Yea I thought about an electrostatic charge on the screen,
    Another thought maybe a setup like this
    Where the copper wire points in towards the coil,
    what if we froze the water without any field, since ice is a dielectric the electric field would move into the copper wires and conducted to the outside of the cell.
    If we can tie into this field things are going to start to happen.
  • MonsieurM
    Yeaaahhhhh
  • Dave45
    Hey Im baaaccckkk
    The copper still didnt seem to attract the field, Im missing something, I wonder if I used dc instead of ac.
  • Dave45
    The cell didn't work. May have to ground both
    I lost internet on my computor need to pay my bill. I hope that's the problem
  • MonsieurM
    everytime you put electricity to a coil you create a black hole
    As Above so Below...
  • Dave45
  • Dave45
    Say your coil is the galaxy when the power is turned off the planets or electric field goes to the coil, there's the bemf.
  • Dave45
    Here's your solenoid, the planets and stars run in the electric field
  • Dave45
    the planets and stars of a galaxy run in the electric field. the center of the galaxy is a magnetic core, what they call a black hole is the magnetic core of our galaxy.
    Its starting to make since now
  • Dave45
    This is air core, I wonder what a hollow ferrite core would do.
    Maybe intensify the magnetic field thereby intensifying the electric field, I believe the bands that are surrounding the coil is the electric field.
  • MonsieurM
    The new cell is in, I didnt use screen this time I used copper wire wound a few times, its connected to ground rod.
    We'll see
    I see now how your set up works
  • Dave45
    triple dog dare, I havent heard that in years
    I'll not take that dare
  • shawnnweed
    The only way that makes any sense if I ground the screen then I'll have to hook the aluminum plate to the antenna.
    I hope this thing doesn't start transmitting I really don't want the FAA or whoever at my door.
    If the FAA shows up just hold one side of the ice and make slurping noise while holding the grounding rod like a straw...just look at them and say, "What!!!! so I like alot of ice..."
    p.s. triple dog dare you to touch your tongue to the metal rod.
