Don't Kill Dipole
  • SkyWatcher
    Hi folks, Hi Jbignes5, ASPARTAME and other fake sugar products and things like msg can cause symptoms in the body similar to MS. Pepsi and all diet sodas contain ASPARTAME or other types of fake sugars. I used to drink pepsi and so did my wifes uncle and when we stopped, all the symptoms like shaking or convulsions and headaches vanished. Also, I do recall getting slight vision problems also. That could be the problem, I'd check into it, people probably have varied sensitivity to these toxins. Hope this helps you or anyone else.
    peace love light
    Tyson
  • Slovenia
    Plugging the Leaks
    How do we plug the leaks in our electrical circuits, motors, and other devices?
    Reference post October 9, 2010 Response to Slovenia regarding post #38.
    This is fantastic information indeed. I think this is a big key too. The main thing I learned though was that all the energy is coming from the external side of our devices and not our devices themselves. This is a new way of thinking, but we have to make the change in our thought process before we can move forward with the design of the devices we are trying to design here.
  • Slovenia
    Much Insight
    Hi Jbignes5,
    You have much insight into what Tesla was doing and how things actually work. You also have a talent for describing things in a way that non electrical guys can understand what you are trying to say. I have been going through and reading your posts multiple times as I organize them and have found all your information to be incredible.
    Thanks for sharing it with us. The more I read the more I want to know. Some things are finally starting to come into perspective for me.
    Best Regards,
    Slovenia
  • Farmhand
    Jbignes5 I have to say what you say sounds a lot like the the shape Otis T. Carr talks about as being the shape of the universe or the universal shape that all is based on, he says it is a square when veiwed from the side's and a circle when veiwed from the top or bottom.
    Have a look at these attachments. It is basically a pair of right angle cones bases joined so when looked at different ways it can have different shapes.
    http://www.energeticforum.com/renewa...is-t-carr.html
    I have not locked my opinion in as to what the junctions look like because they could be either 3 or 4 sided pyramids or even cubes. It might be a combination of all of them as far as I know. In then case of water I am leaning on a cube. If you look at the snowflakes you will see a 2d slice of some angle of the junction. Most likely 45 degrees. That would make the junction cubic. If you take the center portion of the snowflake and connect the dots you can actually make a 3d wire frame of a cube. I am starting to come to the conclusion that different materials have different configurations of the network as it's structure but not always that way because in the case of salt I have seen both networks of 3 and 4 sided pyramids as the base with the same batch of material.
    I thought this was a nice diversion from the don't break the dipole discussion. It is very important that we go this route because this is the picture of what we want to work...
    Fantastic work you do looking at the basic structures, very interesting.
  • Slovenia
    Jbignes5 Archive
    Hi Jbignes5,
    I'm in the process of organizing your posts into a more readable understandable format.
    Best Regards,
    Slovenia
  • Slovenia
    Wonderful Work
    Hi Dragon,
    You are doing a great job here. We are very glad to have you with us!!!
    Best Regards,
    Slovenia
    I don't mind criticism, it is a more conventional circuit based on charging and discharging the outer most caps and using the central cap as the potential change. More closely related to the tesla switch. I would love to completely understand how to couple it to the environment. Until that understanding, I can only hope to learn and catch up with someone like yourself. I feel like I entered the class at the last 15 minutes of the hour and I'm trying to understand what happened the first 45..... I'll get there...
    Last edited by Slovenia; 10-11-2010, 10:26 PM. Reason: sentence problem correction
  • Slovenia
    Good to hear from you DavidE!!
    Originally posted by DavidE View Post
    Slovenia
    Don't you mean... Don't Kill the Dipole (for very long)
    Excellent thread, thank you.
  • DavidE
    Slovenia
  • Jbignes5
    Yeah it's not looking to well...
    What started all this is my double vision in my left eye after it had swelled up. It is going away now but it has left a slight doubling of my vision in my left eye. I normally wear glasses and this is messing with me something terrible.
    When I started researching this morning about this problem The bad news was that it was MS... I show all the signs of MS and have had these signs for quite a while now. Including shaking and heart palpatations. But as I continued reading I also saw that a B12 deficiency can cause the same symptoms so I am betting thats what is the problem.
    My mother had the same issue and unfortunately it was before they knew anything about B12 deficiencies and they removed the section of here intestines that was responsible for extraction of that specific vitamin. They called it irritable bowl syndrom and removed it toot sweet .. A rather harsh treatment that has her not able to eat anything but purely bland food.
    If it comes down to it shots will be my last resort seeing that vitamin boosters seem to work because it is not natural it is easier to absorb. I am sure I will be fine but just in case I am wrong about this then it doesn't look good. But I am sure about my research.
    Thank you for the concern and I know it will be fine either way...
  • Slovenia
    I Got It (Archiver)
    Hi Jbignes5,
    I thought maybe you were referring to some special archiver type program at Energetic that I knew nothing about.
    I'll be glad to archive and put into context all your work on this don't kill the dipole thread. I'll look for some other relevant post elsewhere to if I have time and once this archiving job is done.
    Sorry to hear about the B-12 deficiency. We don't need you to get MS or Parkinsons, so take good care of yourself!!! Your mind is like a steel trap and we can't afford to lose you. We appreciate all you have shared with us all.
    Best Regards,
    Slovenia
    Originally posted by Jbignes5 View Post
    You are the archiver lol.... Making a file to save is archiving... And I appreciate that.
    Not all my posts just the ones here. They need to be read and organized according to their context. I am so bad about keeping on track.
    My thought process is being shifted by a deficiency in b12. I just found out that I am lacking in B12 and it isn't because I don't eat right. I am starting to exhibit MS type symptoms and I fear that if this doesn't get fixed soon I won't be continuing this subject due to not being able to think any more. My whole body is going out of wack. I am shaking like Parkinsons and my left eye is seeing double vision, along with other MS like symptoms.
    I am gonna go with a B12 deficiency for now as that can have the same effect. They say that vitamins work better then getting it from food so I'll try that for now. It would certainly explain my lack of thought that is in context and the other evidence that something is not right. Don't worry I am on it. If it comes down to it I'll go get tests for b12 deficiency and get shots but for now I think I can get away with the vitamins and if it does not get any better I know what to look for.
  • Jbignes5
    Umm YOU... Lol
  • Slovenia
    Archiver??
    Hi Jbignes5,
    What is this archiver you were referring to? Also, which files were you wanting to have someone go though? I noticed that you have 661 posts on Energetic Forum alone. Thanks.
    Best Regards,
    Slovenia
    I need someone who can go through my work here and put it in context. We have the archiver! Thanks Slovenia! I appreciate this help you are providing us all.
  • Slovenia
    pdf file of thread "Don't Kill Dipole"
    I have attached a pdf file of our thread, "Don't Kill Dipole".
    The file is current through yesterday, October 10, 2010.
  • Jbignes5
    I had touched on the network aspect before and here it is.
    In all the years that I have studied magnetism I got sidetracked along the way by noticing an unusual event. This event was totally separate from the magnetic event I was studying but I though I would take it as far as it would go.
    I started to get into viewing microscopic pictures of snowflakes and it dawned on me that like normal crystal growth you need a seed crystal to grow the formation that you wanted. Well where is waters seed crystal coming from when it freezes?
    Check these out. Oh and when I say a pyramid I realized that it is not 4 sided only. There is a 3 sided version as well.
    Pictures are of salt, water in crystalized form:
    Water:
    This last shot of the snow crystal shows that in the center there is a odd angle of viewing the junction. Maybe 45 degrees from head on? It does look like if it is a cube in the center that it could be made also with two 4 sided pyramids facing tip to tip with a binding potential holding them together. You have to remember these are floating in a water like substance that is soo fine that these are rough when compared. Also this is a 2d picture of the junction that forms I believe in between junctions or something like that heh...
    Salt:
    This last one is very telling of how the lines get formed going out of the pyramid.
    It is interesting to see that the real structure could be salt and that water can take a snapshot of the junction that it falls onto. You have to remember that crystals grow through fractal diffusion. Meaning that the center is most telling about the actual junction it falls through. This junction is very tiny and crystal growth works through the evacuation of charges from the matter. As the charges get drained away it gets rigid. I suspect that charges are like greasy elbows. When the charges are not there anymore it becomes rigid and the joint expands because the bonding charges are not there anymore. As in the case of water.
  • dragon
    updated drawing
    I just wanted to point that out lol.. Keep at it.. It has merit....
    This is an update to my earlier drawing. This one is a little simpler and disconnects the ground until it's properly positioned. I'm going to attempt to build one this week for some simple experiments. It should work with a "window motor" approach driving the rotor with the central cap. Well, at least in theory... it will either go or blow !
    ________
    VOLCANO VAPORIZERS
