  • ilandtan
    You may find secret one explained in one of Tesla GB patents in some weird manner. It connects two seemingly unrelated Tesla US patents.
    People take it directly but it'a a diagram only. Yes, Tesla patent about radiant energy describe method and picture is only a diagram to depict flow of thoughts .
    You talking about this?
    Improvements relating to the utilization of electromagnetic, light or other like radiations effects or disturbances transmitted through the natural media and to apparatus therefor
    Figure 4?
  • boguslaw
    Originally posted by Dwane View Post
    Hi Boguslaw,
    I read an article by Tom Swift in PJK's book recently. In it he suggests one connection to the positive of the capacitor after the rectifier and one connection to the case of the capacitor before the diode. Is this what you might be suggesting?
    Dwane
  • Dwane
    No. You have to have a single plate insulated from ground. Or any surface able to store charge. Then you have to find a way to make it charged (secret one) , make it "into" two plate capacitor (secret two) , make positive feedback aka parametric resonance (secret three) and so on. It's a bucket full of secrets. Those who find the answer , found just the method to self-control the secrets to work together.
    Let me recall Tesla's words: "It was evident to me that wireless transmission of energy, if it could ever be accomplished, is not an invention; it is an art. Bell's telephone, Edison's phonograph, or my induction motor were inventions, but the wireless transmission of energy is an art that requires a great many inventions in combination. "
    imho, secret one resembles very closely the way we statically charge by induction
    Hi Boguslaw,
    Dwane
  • ilandtan
    Just to show that I am not the only one thinking this direction please view this. I know his videos want me to go into coma, or wash my clothes or do dishes. His analysis is sound. Just remember he's graduated to selling something, which now makes me suspicious.
    [VIDEO]https://www.youtube.com/watch?v=18kOGVfkoik[/VIDEO]
  • ilandtan
    Hi ilandtan,
    Have successfully replicated your four globe slayer demonstration. I only used three light globes. I know you said that this would not run the house, but, my demo the lights faded after about30 seconds. I take thst to mean that I am not generation sufficient energy to maintain the flow. I first tried the globes in parallel, and they lit up. In series they were much brighter. So it becomes a current thing. My ferrite "Probe" was a series of small cores I had which I bound together. I am not sure if that would have affected the result. The L1 and L2 were wound using the weight ratio of wires 1:4.
    Anyway, good test to replicate. Now for the second test. This is going to take a bit longer while I work out the best way to organise the materials and components.
    The photos show the lights with probe inserted into Tesla coil, the probe, and if you look carefully in the centre of the photo, the corona coming from the loose wire at top of the coil.
    Edit: there was one other output i noticed with the probe. It lit up first towards the bottom of the Tesla coil, and it also lit up at the top but not as brightly and in a very tight margin of energy.
    Dwane
    Looks good Dwane! So now you have resonance and radiation. But you see, the limitations of the power. You will be able to better the performance with varying loads, to optimize the impedance matching. I also tried taking one additional coil around the ferrite rod, and firing the stored energy from the first coil back into the ferrite rod, that made some improvements, but didn't build the energy like a thought. My hope was that feedback could increase the output. The main problem with this setup is that the insertion of the ferrite core and any loads run off of it, will affect the power in.
    My next step was to setup an RX/TX, it gave the advantage of running the loads better. There is no doubt that what you do on the RX side has almost no effect on the input. I had 15W LED -100W equivalent bulb that was dimly lit using the primary setup, but using RX/TX, I was able to illuminate it almost 90%. It was solidly lit, and the input power was still 6W.
  • Dwane
    Originally posted by ilandtan View Post
    I guess we have to ask ourselves why we we are pursuing this technologies, and it is to find ways to harness effects that might lead us to over-unity. If you make a device arbitrary from the ambient then it's doubtful that we will be able to achieve anything extra-ordinary. As for the size of coils, remember that you are making a tuned circuit, and in Don's devices he often uses a tank circuit for L1/L2, so you can cut the coil size differential by placing appropriate capacitors inline, for tuning for either side.
    With no consideration for the ambient, with a simple Slayer I achieved this:
    [VIDEO]https://www.youtube.com/watch?v=dLlF4R6aUfE[/VIDEO]
    It wont run your house, but it starts to make you think. But ultimately a resonant L1/L2 alone won't give us over-unity. I believe there are ideas omitted in the Don Smith tomes that we have to pull from his communications and lectures. If you are not aware, a great deal of his thoughts are cached here
    I have been poking around Don Smith's ideas for about three years, and they guy has some insight, fuzzy math... but he explains ideas that seem impossible, and then you start seeing what he says about grounding, and cooling and it convinces you that he might be right about everything.
    Hi ilandtan,
    Dwane
  • ilandtan
    We should keep historical lessons for others
    Originally posted by jim glinski View Post
    Well I have a drawing around here some where mabe a pic there's a posting on energetic on it real power with caps ..or something like that I did make a video but had to do it in a darkened room and still the neons were hard to see .you can just Google cascade charging and read about it Ben Franklin did it . I stopped working on it got scared of the way it was acting the neons were flashing hot and blue white and the chance of over fill and a boom was a little to much right then .this is DC only higher voltage with neon triggers to short the terminals got a 4watt incondesant blub to flash with this using two motor caps the one to ground totally isolated flashed the bulb.its electrostatic induction nature trying to balance the environment .look to the physics demos on electrostatic induction charging .it's done with balloons all the time .and caps are isolated by the dielectric .
    I feel that it is important how we as experimenters go about our learning.
    We will come across ideas, we will use the scientific methodology to prove them relevant. We should have schematics to share, and media to illustrate the topic. I work off Visio and video, to show and validate with others what I've learned. It is important to progress iteratively, thus collectively, we become more aware of what people have proven so we can apply it to our efforts.
  • jim glinski
    Back again
  • ilandtan
    It was done during the hivoltage static machines it's called cascade charging they used lyenden jars .and Bedini said he's devices got 30% more power this way .it's the voltage that attracts the ground current .use oil filled motor casps at 450 volts .and a neon on trigger on a MOSFET gate to dump at around 99 volts .you need a good earth ground or for get it .if you hold the ground wire with out ground connection you become the ground and get shocked as the current leaves your body .I had five in a series string firing neons and using a diode inline with a Variac to ajust power .careful here one wrong connection and boom .
    Schematic Jim, and/or Video?
  • ilandtan
    Originally posted by ricards View Post
    as usual, a conflict of interest..
    what's the point of telling if not telling it all?..
    I have to agree Boguslaw, if you can't give away your path to your fortune, we understand, however you should be able to devise an experiment that is cheap and easy to replicate in your approach. So the rest of us banging our heads actually can know there are aliens in area-51 (so to speak)
    Otherwise, why tease everyone?
  • jim glinski
    Include a car coil as hivoltage source
  • jim glinski
    Ground cap charging
  • ricards
    Sorry can't explain further (personal reasons). There is amplification by taking ambient energy bit after bit like a snowball. It's the energy trapped in Earth magnetic field - almost all overunity patents are tapping this energy , because there is no other source around us - the famous ETHER.
  • boguslaw
    Have you validated any of this experimentally? If you would indulge me by explaining the secrets one, two, and three.
    Secret One, the only way I see to charge a cap is to give it the balance of what charges it (ground on plate 2) for enough time for the charges to accumulate on.
    Secret two, is just another capacitor in series, what does that do?
    What is the amplification mechanism?
  • ilandtan
