Gray Tube Replication
  • Guest
    Guest replied
    This is the version of how I'm understanding it..
    With the use of bifilar wound coils and a blocking diode on the far
    side of the interruptor junction, this will keep the path open through
    the diode and generate a negative voltage on the LV electrode in the tube
    when the motor is in the correct position.
    When the airgap in the tube passes high voltage, it is reaching through the
    capacitors and into wherever they lead, may it be a battery or capacitor or
    ground. The silicon will crunch tight after a certain time has passed, manifesting
    a radiant burst of light and energy onto the mesh through a natural means as
    of yet not fully established.
    Once reaching the surface of its newly found conductor, the pressing
    of the diode launches it into a greater momentum, repulsing the permanent
    magnets and generating flow in the other winding.
  • Guest
    Guest replied
    wh--
  • lamare
    Originally posted by Spokane1 View Post
    Just becasue the bogus/failed CSET that Gray patented in 1986 didn't work, doesn't mean that the fundamentals behind it were faulty - just that that particular implementation of it didn't yield the results that were hoped for.
    Once Mr. Hackenburger had a better understading of the physics of this new technology he eliminated the fixed gap CSET approach from the EMA6 motor and replaced them with a dynamic system that became part of the commentator in April 1976. He still employed the arc, just in a different embodiment.
    There is a good chance that Hackenberger actually improved upon the original design of Marvin Cole, once he got his arms around the overall physics of the process. It took him about 3-4 years to figure it out.
    The last photo ever taken of the EMA6 (April 1976) shows the CSET's removed and the new nylon "Donuts" as their replacement. This retro-fit must have showed some promise because with additional funding in late 1979 Hackenberger built the last free energy motor (The Blue Motor). I really doubt that he would have moved to Kansas for 18 months (or that the investor would have paid all the costs) if he didn't believe that he could come up with an improved design to replace the EMA6 that was destroyed by the FCC in early 1979 (or late 1978). It is a reasonable assumption that the Blue motor contained some version of the dynamic arc system that replaced the 1973 versions of the fixed-arc CSET system and the less than sucessful system that was initially used on the EMA6 at the time of the 1976 press release.
    Since Hackenberger, E.V. Gray, and his son Mark left Dodge City in the middle of the night (1980) with the Blue Motor in hand they must have been on to something. (or so I think) To bad that Hackenberger died right after that great escape. E.V. Gray went underground for several years after that attempting to avoid Mr. Russel Audrey (the investor) who rightfully wanted what he had paid for.
    All of this points to the arc as being some important part of the non-classical process. Cole and eventually Hackenberger got better results with a dynamic approach. However that dosen't mean that some other inventer can't get significant results with a fixed gap system.
    The real technical question is how was the non-classical energy extracted (or converted) from the circuit that contained the arc? Dr. Tesla explored a lot of different variations of dynamic arc interrupters from 1893 clear up till 1896. So, the magic seems to be in the interesting physics of the disruptive discharge and how it affects other circuit elements.
    I'm sure there is more than one approach to harvest this extra energy - once we understand the physics of it. Dr. Tesla seems to have employed resonance and delay lines impregnated with electrets. Marvin Cole appears to have used a dynamic electrostatic excitation and collection process. Stan Myer and the other researchers mentioned have employed various methods that worked for them.
    Peter Lindemann's proposal back in 2001 in his book "The Free Energy Secrets of Cold Electricity" was by far the best (and only) attempt to fleash out a real world circuit with what technical information was avaliable at the time. Today we know a little more, thanks to people that who shared their observations and photos. But, Peter's fundamental concept is still valid. An open, high current, disruptive discharge arc, from a storage capacitor casues some form of non-classical energy to manifest (Cold Electricity?) in the right environment. This energy can be OU if properly harvested. Apparently the copper grids and enclosed gas that Hackenberger used from 1973 to 1976 were not completly up to the task. But, I'm convinced that he did come up with something that was.
    I really doubt that E.V.Gray understood exactly how Marvin Cole or Hackenberger were able to do it. But he knew it was worth lots of $$$ and he was going to sell it. He spent the rest of his life doing just that.
    Mark McKay, PE
    Take a look at the schematic from Gray's 1975 patent:
    Edwin V. Gray: Electromagnetic Association Motor (Pulsed Capacitance Discharge Motor, &c: US Patent # 3,890,548 )
    And compare this to William Duddell's "singing arc":
    Adventures in CyberSound: Experiments with "Singing Arc" and Tesla Coil
    Looks like Hackenberger replaced the CSET with a classic Poulsen/Duddel-like arc converter oscillator circuit, which uses an effect that used to be well known: the negative resistance effect of a spark gap. This clearly suggests that the basic operation principle is to get the coils into oscillation...
    The same circuit can be found in the "fueless engine" documents:
    More references at my article under construction:
  • Guest
    Guest replied
    no caps, circuits, gaps
    With my circuit as shown above in the photos, I'm going to adjust it
    to remove the HV capacitors and get a spark gap flowing onto the LV
    side bypassing the diodes in order to have it visually throwing a gap,
    something I've not yet experimented with.
    Surely there must be some kind of result from the stream of pulses I'm sending
    with the current circuit driver shown below. If there is still no result even
    without the large capacitor bank sitting on the HV electrode, then I'll implement
    this power-on delay found over at CircuitDB in their Miscellaneous.
    Otherwise I am open to suggestion...
  • Guest
    Guest replied
    I've got a number of small HV caps from one of my previous versions of
    this circuit, so one or more of them will likely get put to good use if
    I include one at all, as you mentioned.
    The method by which pulsing the coil is accomplished with a capacitor
    is not yet wholly understandable to me yet, although I've drawn up the
    following idea -
    Once the zener voltage is reached, it goes into the transisting sensor
    and switches on the juice. I still have yet to understand exactly how this
    would work.
  • Aaron
    @Geotron
    If your caps charge from the HV of the ignition coil, some would say
    that would show you have true longitudinal impulses since they
    would essentially be charged off of one wire since that is exactly
    what you have. It is being tapped off of one wire.
    One thing I see is that that cap bank is WAY too large and will suck up
    everything from the HV output IF they are even charging and there won't
    be enough to jump the gap.
    In that spot for those caps, I'd have either an ultra small peaking cap with
    the ground actually tied to common ground or no cap at all.
    For the input to the ignition coil, I'd use a capacitive discharge system.
    A few things seem backwards to me, I'll have to think on that but if you
    get results, it of course doesn't matter how I see it - just whatever
    works for you.
  • Guest
    Guest replied
    the voltage isn't helping
    This is currently what I've got... have to rebuild my original timer, using
    a temporary replacement, although its working quite well.
    I just charge up the HV cap bank to ~900V, then use a screwdriver to tap the
    LV side commutator - no effect. The tube electrodes are really darn close,
    although perhaps somehow I can get them even nearer if that is thinkable.
    Everything besides the ignition coil circuit, timer and 12V battery are shown.
    There are no hidden connections or parts besides those.
  • Aaron
    @Geotron
    Geotron,
    So out of all of this, what is the final schematic you're going with
    for your test?
    If you can post a schematic instead of a simplified diagram, I can
    see more accurately what you're doing and I'm pretty sure I can
    show you what needs to be tweaked if anything in order to make
    it work.
    For me, it always works no matter what variation I try because I
    stick to the basic principles that I believe makes it work.
    Basically, any variation of the water sparkplug circuit with an inductor
    and that is about it.
  • Guest
    Guest replied
    confusion
    Shown below is my reason for not understanding - on the left, the 12V
    is pulsed into the diode while on the right it is opposite, using the
    anode of a capacitor and the (-) battery to initiate the high voltage
    over the gap, then waiting for the diode to close and shock the mesh.
    Currently I have it set up as shown on the left, except for my 12V is
    being boosted up to 90-something and fed into the anode of a capacitor
    by charging it up from temporary contact with (-)bat, then commutated
    through into the anode of the diode on the LV electrode as is illustrated
    with no effect.
    Another thing that concerns me is talk of having positive potential sitting
    on the low voltage side when it would look to be a grounded sink drawing out
    pulses of high potential (in reference to the diagram on right).
  • Guest
    Guest replied
    I've built the version shown in that discussion thread, and it does
    not function. After going through the first three pages of this discussion,
    and seeing your video on the Proof of Concept, I am faced with a different
    view of how it works than I previously thought.
    The following is what I now believe to be a more accurate representation
    of the technology -
    Version 1
    Pulsing an ignition coil with the energy from a capacitor, the output
    connected through the bridge rectifier + capacitor and sent into the HV
    electrode, over the spark gap onto the LV side by the diode sitting open
    connected to the capacitor's anode and (-)Bat drawing it in.
    The high voltage signal passes through the diode, causing it to slam closed
    and send it radiating through the spark gap onto the mesh tube into powering
    the motor.
    The trigger must then commutate the buildup of charge into the capacitor
    feeding the HV ignition coil, or rather the high voltage signal into the
    opposing LV-side blocking diode after a buildup of charge in the tube.
    Compared to - as I previously believed and which doesn't work -
    A high voltage signal is generated from the coil and sent into a bridge
    rectifier + cap and directed to flow into the HV electrode against
    the blocking diode(s) connected to the LV rod. The diodes will remain
    closed until they are activated by a low voltage signal to open them in the
    face of the high voltage, then slam closed sending radiant energy onto
    the mesh tube.
    As per the Version 1,
    The manner in which the ignition coil capacitor is charged to send a pulse
    into the tube is not immediately striking me. In the video you've hooked
    it to a relay I believe with either some kind of voltage sensor or timing
    device switch. This is the portion I will need to find out about if the
    rest is looking to be accurate.
    I now see that perhaps I jumped to a conclusion in the diagram I posted
    above with the Zener diode, and the position of the box labeled 'SW'. It
    might rather be positioned between the low-voltage tube electrode and
    blocking diode if I am correct.
  • Aaron
    Geotron's Gray experiment
    Geotron,
    Is that diagram showing exactly what you have in the
    pics here? http://www.energeticforum.com/renewa...tem-plans.html
    You mention low voltage cap but the diagram shows a battery there.
  • Aaron
    snubber cap
    Originally posted by pranav2010 View Post
    hi aaron
    what do you mean by snubber cap ????
    have wonderful day
    Hi Pranav,
    I apologize I didn't respond sooner, I just now saw your message.
    A snubber is a small cap that gets placed across points and will suck
    up some of the discharge to prevent welding the points together.
  • lamare
    Someone attended me on some interesting patents by Benitez. I uploaded them to my server:
    Bestandsoverzicht van /pdf/Patents/Benitez/
    These may be interesting to study in relation to Gray's work, too.
    In this patent, he describes a.o. a magnetically quenched spark gap and an old school, electrolytic capacitor like rectifier:
    He refers to this arc as a Poulsen arc lamp:
    Arc converter - Wikipedia, the free encyclopedia
    Unlike the spark-gap transmitter converter, the arc converter produces undamped or continuous waves (CW). This was an important feature as the use of damped waves resulted in lower transmitter efficiency and communications effectiveness, while covering the r.f. spectrum with interference. This more refined method for generating continuous-wave radio signals was initially developed by Danish inventor Valdemar Poulsen. The Poulsen arc converter can be likened to a continuous-duty-rated electric arc welder with a tuned circuit connected across the arc. The negative resistance characteristics of an electric arc permits the creation of a relaxation oscillator that converts direct current to radio frequency energy. The arc converter consisted of a water-cooled bronze chamber in which the arc burned in hydrogen gas between a carbon cathode and a water-cooled copper anode. Above and below this chamber there were two series field coils surrounding and energizing the two poles of the magnetic circuit. These poles projected into the chamber, one on each side of the arc to provide a magnetic field. This field helps to stabilize the arc and improve overall conversion efficiency. In today's world one can still find oscillators based on negative resistance devices; the tunnel diode is one of them.
    More on arc oscillators and Poulsen here:
    Adventures in CyberSound: Poulsen, Valdemar
    Wireless Telegraphy and High Frequency Electricity: Wireless Telephony chapter (1909)
    Howeth: Chapter XI (1963)
    Update:
    So, according to Arc converter - Wikipedia, the free encyclopedia , there is a difference between a spark gap transmitter and a Poulsen Arc converter.
    The spark gap transmitter:
    The Poulsen Arc converter:
    The difference is that with the spark gap transmitter, the spark gap is used to charge C2, and you get a dampening wave. With the Poulsen converter, the negative resistance effect of the spark gap is used to get an undamped or continious wave. Note that with the spark gap transmitter you have the cap in parallel with the coil, while with the Poulsen arc, you have them in series.
  • Guest
    Guest replied
    With a romp through past discussion on the Gray Technology, I have seen
    a different version of the model that I've been using up until now.
    Included below is a Zener breakdown charger I thought might be of some
    practical use, and the idea of the LV side has been completely changed
    in my mind Aaron thanks to your efforts.
    I do not claim to fully understand the technology yet, although hopefully
    I'm getting somewhere close.
  • pranav2010
    snubber cap
    hi aaron
    Pranav,
    I think that will work, I have done that to charge batteries with the plasma
    impulses where your 24v battery is but you do not need that to test.
    It also could make your battery explode - so for safety - remove for now.
    Leave the gap but remove the battery and diode there, you don't need
    them.
    Relay can work, I have used relays in many of these experiments but little
    by little your relay points will fail - you may be able to alleviate that with
    snubber cap across the points. But you can try.
    After removing the battery/diode, test and it should give you a good
    plasma burst at the gap.
    The ignition coil provides the HV output and the cdi 16uf capacitor provides
    the LV so you don't need the battery to test the effect. The CDI cap and
    ignition coil combination already mix both the HV and LV together.
    have wonderful day
