There is still some confusion as some of the diagrams posted show the anode of the HV diode connected to the center pole of the ignition coil, and others like your correction showing the cathode. You can see why I am confused, you are not consistant. i.e the pdf you posted: http://www.energeticforum.com/redire...ytubeworks.pdf shows the anode connected.
Please look at the drawing and correct anything you think is still wrong.
Questions:
1. How do you charge C1
2. How is L2 pulsed
3. When is the switch operated.
PS: Your "peaking" caps in your previous posts on your "silent plasma" have a + - marking. This is incorrect, as the cap is across the inductor, the cap has AC passing through it, not DC.
Your "silent" plasma is just an AC arc which is a lot quieter than a DC cap discharge one ...
Your "green" discharge is just a higher energy discharge. I can get the same if I discharge a spark in air with several uF of capacitance at 5kv with platinum electrodes. (no copper in sight ..)
With the same high energy discharge I can "pop" neo magnets upto the ceiling .... nothing special there, just high energy for short amount of time ...
I can get fluorescent bulbs and normal neon's to flash green even purple instead of the usual orange ... these are all indications of a higher energy discharge pulse raising the gas in the vicinity to a different isotope level.
What will be "special" is producing continuous high energy pulses from the grids ..... I know how to do that with special techniques .... and they don't involve diodes.
Even if you are getting the "effect" you desire with the small window before the diode blocks shut, you won't get significant power that way continuous, the average power is too small ...
The key is getting more energy into the spark for a longer time .... that opens the door to the high current ....I know how to to that.
The power will then be applied to a resonant transformer modulated to the required load frequency. .... task complete ......
Aaron, I do not just talk ..... I have been experimenting on this for a long time. I am talking about "practical" hands on experiments. Once I have verified my latest circuit, I will post the schematic on-line and you
will see how I do continuous high energy pulses ....
I havn't posted any circuit up to now, because I want to post a complete working circuit that everyone can replicate, not some half-circuit's that are misleading and incomplete. Hence all the questions from me .... I am trying to get a complete circuit for your setup .....none of your circuits are complete, have component values, construction method's etc that everyone can duplicate ...
