Imhotep's Radiant Oscillator Video
  • Toroid on probe
    Originally posted by jibbguy View Post
    Sounds like you are doing some very nice work , Aromaz
    If i could inject an aside: Regarding your idea of the coil at the scope probe, this reminds me of an old trick we used to use to check the RF radiation of devices (quickly testing the effectiveness of shielding schemes without an expensive RF meter or having to go into the Faraday cage, which was a pain):
    Simply clip the ground of the scope probe to the tip; creating a "loop", and wave it slowly around / near the device. We used to see quite graphically how RF would "hover" over metallic surfaces and not be shunted to Earth Ground; which is a pretty strange effect when you think about it
    Amazing how a simple thing like this can fail to penetrate my old brains.
    I did just this, but then added the toroid between the probe and earth!
    Amazing how the energy is flowing around. Getting all sorts of readings. Away form the coil - 3m, it all goes quet and just little noise on min scale.
    • Safe the desert trip
      Aromaz-- Sorry that I mispronounce your name. It is Aroma-zzzz. I wish that I could get more ZZZZZs. This stuff keeps me awake too. Thanks again for getting envolved with this and sharing.
      I did have the 2n2222 wired correctly and the package label was wrong. A warning to others who may buy the Radio Shack package of (15) assorted 2n2222 "like" transistors.
      Something very strange is going on with this circuit. I was getting mild shocks at places in the circuit way up stream where there shouldn't be any HV. This was happening before when I was using the Bedini fan circuit. Aromaz when you mentioned the low amp draw and the battery voltages climbing a light went on in my brain. Last night I ran the system a long time, it was stone cold, and the analogue amp meter was hardly registering anything. The coil was humming along and the light was on. If I touched the rehostat leads at the source battery I got a mild shock. In my particular case I may be getting energy from the house somehow from that ground lead. I hope not. I may have to drive out to the desert and run the experiment again.
      Lidmotor, desert will be good. Maybe I can save you that. I took it out to my farm last night, new house, new 250cm earth probe (only hammered down 8 days ago). In all I actually had more power and stronger lights. I will put that down to the earht probe since my lab is only using the buildings frame as earth. I set system up about 100m from nearest building and any house wires.
      Forgot to take multi meter and camera. There is unlikely any stray voltages there bare those we will find on all land. Farm is about 3 km from beach, nearest high tention wires are more than 1.5 km away, nearest cellphone tower is 2.8km.
      • Guys, Gene an engineer/friend i know offered some comments on Lid's video and the effect. Thanks to Gene.
        Ash
        "If you check out the jln pages there is a circuit shown using the 2n2222
        transistor which shows how "negative resistance" occurs in that particular tiny transistor.
        The schematic referenced at the jpg doesn't show the base of the 2n2222
        transistor being connected to the positive side of the battery. The vid tho,
        shows a 5megohm pot on the base of the 2n2222 connected to the positive of the battery.
        Just as a "reference" those small CFL's have a "standard rated" draw of 270mA at 120volts. (at least on the several I have that look just like that.) He's driving the lamp as some 200-300mA per his comments on the video, tho he notes also that the light brightens and the current draw decreases somewhat when he connects the HV to an earth ground. If he had a better analog ammeter he could better tell what "real" effect is being seen... usually at the bottom end of an ammeters reading they are pretty inaccurate.
        Its interesting but doesn't seem to be adjusting the "real draw" much from the
        "normal draw" of just plugging that cfl into a lamp socket off the mains. He
        should probably get a scope to connect to it as well so he can see whats going on in the Low Volts side.
        Gene"
        • Thank you
          @Bodkins
          Thanks very much for your video's and input.
          You made my day; second person to duplicate and verify. Now I feel more confident since this is not a regional fluke.
          How exactly this is working and where all that light power comes from I do not know. Fact is that it is using a very tiny amount form the battery to operate. My earth connection in the lab is not really suitable, but as in previous post: out on the farm it did make much more light.
          on this stage only one remark: Add more lights.
          This is a real phenomena - the more lights the lower the amp draw.
          I plan and hope to have some 18 hours in the lab today.
          • Therefore we need to find NEW ways, NEW experiments and NEW lines of thoughts.
            • ashtweth and Tesla
              Sorry, the previous post arrived twice.
              • Part 2 --Aromaz Circuit
                Aromaz-- Thanks for saving me a trip to the desert. I reduced the circuit by 2 transistors today to see if it would still run and it did. If I run it on low power mine runs cool and at about 70 mili amps. I also tried multiple cfls and that also worked. In the video I show the HV being pumped out of this thing. It is very strong. A standard 110v neon will light up from only one lead at any place in the circcuit. There is something very strange going on here. With two cfls in series mine will run without the earth ground but at reduced light.
                YouTube - Aromaz CFL Circuit--Part 2
                Cheers,
                Lidmotor
                • DYNAMIC RESONANCE THEORY So my Dynamic Resonance Theory is:
                  • Thanks for that Aromaz and Lid, ill up date Imhoteps/your PDF.
                    Now also any one interested in that negative resistor thing, Gene gave us te links.
                    Heres that link from jlnlabs... its been up there for a couple years
                    now.A Negative Differential Resistance Oscillator with a Negistor
                    here also this page to a loaded version a similar circuit.
                    The NDR Oscillator with LOAD
                    Not sure if its helpful... but probably interesting for those guys to
                    read. Gene
                    • We are in the AIR, nice video Lidmotor
                      [QUOTE=Lidmotor;36206]Aromaz-- Thanks for saving me a trip to the desert. I reduced the circuit by 2 transistors today to see if it would still run and it did. If I run it on low power mine runs cool and at about 70 mili amps. I also tried multiple cfls and that also worked. In the video I show the HV being pumped out of this thing. It is very strong. A standard 110v neon will light up from only one lead at any place in the circcuit. There is something very strange going on here. With two cfls in series mine will run without the earth ground but at reduced light.]
                      Lidmotor, just got your video down now. I think the major difference between us is the coil. My coils are low class and has max output 6,800v on HV (when I was doing the original Imhotel single coi/relay). On my coil('s have 4) I can barely hear the resonance, same with younger people. On your video the resonance is very audioble.
                      On an earlier question: Yes my 555 circuit was connected to the Base of the 2N2222.
                      Suggest:
                      A) Add more and more lights till you really see the glow goes down with every new addition. If your coil is stronger than mine, I suspect you will be able to light up much more light than me. That could also be the reason you had trouble with the 2222 since it might not pass enough initial energy for the demands of your coil - AND why I can not get second coil running....and why I needed 3 tertiary transistors..... I will look into other options for this transistor.
                      B) Consider to get rid of the control pot, see my previous post about DRT.
                      C) Move earth wire around on circuit to test alternative places each time you change something. Even disconnect.
                      VERY curious to see video with Tesla transmitter.
                      I just keep on failing to get my video's uploaded to You Tube. Same mystical message, even translated video to .AVI, same thing "Fail to upload due to unknown error
                      • Negative Resistance !!! Very nice indeed.
                        Gene
                        Thanks to Gene. I have been to JLN labs before, though there I was more interested in the AntiGravity research. This NDR is just possible to solve another problem I have. VERY interesting indeed.
                        Much appreciated and big "thank you" to Gene.
                        • Frequency testing
                          @ Lidmotor and Bodkins;
                          If you do not mind and it is possible, I would like to verify some more ghostly findings here.
                          Have you been able to measure the actual frequencies? In particular I am interested in the fq in Hz measured:
                          A - at the coil Positive (+)
                          B - at the coil Negative
                          C - At the battery poles (+) and Negative (-)
                          D - Your earth wire on occation where:
                          1) connection increases illumination
                          2) connection decreases illumination.
                          E - Take at least 3 identical CFl's - does not matter whatever else you have connected in tubes or so. Take reading at + terminal of coil, add 1x light in series, measure again, add 2nd light in series; measure and add 3rd light..measure.
                          There is a puzzle embedded here. This might be of help to formulate the DRTheory.
                          • another replica
                            with 1 2n2222a and 2 2n30555
                            grazie aroma
                            • Very interesting indeed Aromaz. Maybe you could try a rotating coil to see what happens? There is a huge secret in motion of the coils and transfomers(ie variocoupleers) I believe. Aehter will be attracted to a vortex motion.
                              • I think Ash's post brought up an interesting point before. While the majority of these circuits are running fairly efficiently it is important to note the light output. I have a toroidal transformer here that I am pulsing with a PWM and mosfet and I have finally got a bulb to light to full brightness or more. By full, I mean if you stare at it for longer than a second your vision goes blurry . There is a dramatic difference between "lit" and "illuminating" and it is important to note. I can run my lights at low amp draw, but only at decreased incadescance as well. Coincidently the 20watt globe I have can be lit to 99% brightness or more for 1.5 amps @ 12v. One interesting point is the toroidal transformers secondary is not directly connected to the primaries.
                                Aromaz I am interested to see where your circuit goes, there are multiple ways one can trigger an oscillation for peanuts. IF you havent yet, look further back in this thread at the Bedini self oscillator we experimented with, I believe that in some ways it is similar in principle to the one you have, to some degree. Didnt Lidmotor connect the transistors base (2n2222) to the positive of the source?
                                By the way, search for a demo or freeware version of "stoik video converter" if you have a pc. I had no troubles with it converting for the Tube.
