Imhotep's Radiant Oscillator Video
  • Hey Lid, I found that page a while ago too, looks good huh. There is another more obscure page that I found once that shows a whole schematic with 555 parts included etc. I'll try and dig it up.
    Ive built half of that setup, using the ignition coil to fill up a 2000v 1uF cap with a spark gap discharging every couple of seconds, depending on the gaps distance. It needs a much smaller cap however.
    This is where one must study inductance and capacitance within their circuits to better understand what is at play.
    • I'm stuck in theory land, but it's not so bad
      I think I've worked out why backwards diode works on ground. Because you guys are using alternating current in transmitter, you are alternately charging and discharging the capacitance of the reciever. On the backdraft, energy is pulled up from ground. But tesla left ac current behind by this stage. He called his transmitter a disruptive discharge transmitter. And the aetheric effects for each frequency such as rooms lighting up etc persisted for some time after he stopped pulsing his transmitter. So, perhaps try dc pulses to transmitter, and the work done on reciever circuit will build up. ?!
      I'm almost in agony over not having time to experiment. Hope no-one minds my incessant ramblings.
      P.s. tesla said in one patent I recommended reading, that each pulse should be over .08484 seconds in duration so that aetheric pulse has time to span the globe and return, thus setting up standing wave. Perhaps check 555 timer calculator and lidmotor, perhaps use another pot instead of 1k resistor, to mark time of pulse.
      • Originally posted by ren View Post
        You talking about LC Ren?
        • L/C = Inductance/Capacitance
          Resonant circuits. Look here:
          LC circuit - Wikipedia, the free encyclopedia
          LC Oscillators
          DeepFriedNeon - Tesla Coils
          • Deep fried neon
            LC Oscillators
            Thanks for the links Ren. I especially liked the "Deepfriedneon" one with the calculator. I already have a collection of deep fried parts and maybe this will help stop that.
            Bodkins you should really understand this LC stuff. Its all about the cap and the coil and the music they make together.
            Cheers,
            Lidmotor
              Hi,
              Not sure about that math.
              I get .13 seconds to make the trip at light speed.
              Carl
                Lidmotor
                nicely put. Dont forget the sauce....
                • Re Harold Aspdens work
                  Guys
                  I spoke to Dr Aspden on Sunday about his GB2390 patent and he explained what to expect from the capacitors . He went on to say that the inductance load between the cylinders will in effect draw energy from each cylinder in turn, and in doing so will pull the Aether energy into that cylinder to compensate for the difference in both at that time. Meanwhile the oscillating circuit then turns over to the other cylinder and in turn draws energy from that and the process of equilibrium starts over creating an Aether pump. He went on to say that when the circuit is in resonance and the draw of energy is such, the circuit will then run its self . Another key is not to over draw energy from the circuit in a manner that would over stress the pump.He has written book called the "Physical truth" that has a lot of updates on the subject of the harnessing energy from the Aether
                  • hmmm. There are those words again....inductance, capacitance, resonance...
                    • Thank ren the sites are real gems
                      Im building the Dr Aspden Patent this week and the site we help me work out the number Cheers
                      • Resonance
                        Guys since we are talking about resonance, one engineer worked out his own way of defining resonance (RLC -VARS) through RF protocol, where you have voltage nodes and current nodes, he calls this radiant energy.
                        His stuff could be considered as "babble " to most, but i have it on good authority that some one got one of his circuits working based on his teachings, i cannot say any more at this stage for obvious reasons .
                        This guy used an Rv prime mover and RV alternator, as you know when using this configuration you build up allot of reactive power (Resonance). This exceeds the watts needed to operate the prime mover.
                        For example 340 watts in
                        1200 VARS out.
                        The idea is to make the load part of the resonant circuit (Alt) and get every thing in the EXTRACTION circuit to resonate. But this is a discussion for another thread. The configuration although i cannot state the exact values as i do not have that info..YET is currently:
                        Three PH Trafo in series with the ALT caps in tipple flux mode-> 3 PH bridge ->dc caps-> Blocking diodes one forward biased on pos leg and one reverse biased on neg leg to more dc caps bucket brigade daisy chain -> common rails -> super cap ->battery and inverter back to standard RV PM. There is your looper. ALL this and the details of what i describe are in the RV compilations just thought i would mention about resonance guys, sorry if its off topic, Aaron please feel free to whip my butt if it is.
                        Ash
                        • P.s. tesla said in one patent I recommended reading, that each pulse should be over .08484 seconds in duration so that aetheric pulse has time to span the globe and return, thus setting up standing wave. Perhaps check 555 timer calculator and lidmotor, perhaps use another pot instead of 1k resistor, to mark time of pulse.
                          Here is the math...........
                          speed of light = 186,000 mps
                          circumference of world = 25,000 m
                          186,000 / 25,000 = 7.44 (around the world 7.44 times in one second)
                          1 / 7.44 = .1344 (around the world once in .1344 seconds)(and this is at the surface not in the cavity, which would take longer)
                          Carl
                          • Launching and Receiving Waves
                            To All
                            Patent #2921277
                            Publication Images
                            • Or... In Metrics instead of Miles
                              c is 299,792,458 Meters per second (at "sea level" apparently; there is some question as to if it is higher "underground" or "underwater"..which i dont pretend to know the answer too ).
                              The circumfrence is 40,070 kM at the Equator, or 40,070,000 Meters.
                              By your basic equation,
                              299,792,458 / 40,070,000 = 7.481718... (pretty close lol)
                              1 / 7.481718 = 0.1365914 Seconds
                              But is this figure supposed to be the Rise Time (...or "Fall" in this case)... Or the total Frequency / Period?
                              • Cheers Ash
                                THREE IS THE MAGIC NUMBER
                                Tesla was obsessed with number 3
                                Imhotep Three Fans charging
                                Three pyramid egypt Image:Giza pyramid complex (map).svg - Wikipedia, the free encyclopedia
                                Stan Meyer tubes the gas bubbles inbetween the two resonating plates
                                Harold Aspdens patent middle tube picks up ether
