Originally posted by Lidmotor
Try different sized caps too. The common consensus is a medium to large capacitance is better.
It looks like this automatic pulser circuit is something that I can now figure out how to build. If I have any more questions I will use the appropriate thread and keep this one clear for Imhotep oscillator discussion. By the way I noticed that people are having trouble with heat and burning out transistors. Been there done that. You are right that you have to watch the resistance on the base of the transistor and put a fixed resistor in with the pot. On my latest circuit I got away with a 100ohm resistor with a 1K wire wound pot. It was just trial and error but the TIP3055 transistor I'm using runs cool. I'm also dumping alot of heat (still) into the 25ohm rheostat that I use so I put hefty heat sinks on the front and the back of it and it is working.
Please check out the "Free Energy and Open Source Energy Movement" articles: There are subjects of significantly greater importance there. You can see them all here at Peswiki (
