Imhotep's Radiant Oscillator Video
  • Hv diodes
    I want to rectify the output from the ignition coil with two hv diodes to pos and neg of cap from pos of secondary coil. OR use pos and neg of coil and four diodes...
    Any tips on which diode to buy from here, or any other sources?? Any suggestions welcome..
    RMCybernetics - Surplus Science Supplies
    Ta
    • I got some from a microwave. If you are going to buy some try to get 20kv plus.
      • Hey guy,s check this out
        This guy has got the voltage so high and the current so low that he's getting gaseous streams..
        Up the frequency until it goes invisible, stick a segmented surface ie a single wind coil in or near the stream, and the voltage should multiply..
        High Voltage
        Anyone who wants to stick their hand in these streams (bodkins) should feel safe enough putting their family pet (or a goldfish) in the stream first..
        Thinking of building a tesla coil and running it from imhotep coil, and spark gap...
        Looks fun.
        • Ren's two transistor self oscillating CFL circuit
          Ren---I made the circuit that you posted and was able to get the loop closed by using an earth ground on the base of the small transistor. I discovered a strange thing at the end of the day when I was charging up the battery while running the system. The amp draw went to zero!! I got all excited until I realized that it must have just been the wall wart but when I unplugged and disconnected the charger the thing went to zero again if I touched the CFL!! . I made a quick video of it and showed a scope shot of the wave form. It may have just been "stray current" going through my body but it sure was weird.
          YouTube - Ren's two transistor CFL circuit
          Lidmotor
          • @Sucahyo that might be what's happening, cfl's being negative resistors in some way... But a standard negative resistor is supposed to use voltage. The frequency on my systems has gotten lower with each cfl though. As for cotton in relay... Just one little spark... You could try a solid state relay to reduce noise, I thought of it but they're really expensive..
            Try using step down transformer and diode bridge from the wall. Put it in a box for safety.
            • Ren's cfl circuit
              @ Lidmotor - I can't remember who posted this, but see what a crystal in a glass of salt water does. Also, what does touching wood do to amp draw? I've just realised I never checked.. I was too overwhelmed by the obvious voltage increase that made the spark jump the gap...
              If both happen, that would mean we're definitely getting something from outside the system going on...
              I'm getting more transistors soon :-) and winding a version of spark prolonger coil tonight that aaron? posted.
              • @Inquorate : It was my post, it was a glass of himalaya-salt-water and a crystal. I am doing more experiments with that right now and will post some more movies about it.
                  Lidmotor
                  Hi all
                  I tried this circuit and did see a considerable reduction in current when touching the CFL lamp from about 40mA to 20mA. However, the lamp was dim either way but did not reduce when touched. I tried to get the lamp to a practical brightness but the current always shot up. I eventually blew the transistors.
                  Hoppy
                  • question about the h11d1
                    this is a 6 pin package, and you are only using pin 4 (e) and 5 (c) ?
                    • Back in operation, had too much bed time - thinking and scheming might be dangerous ........
                      Now back up to date and off to my lab for a nice full Sunny Sunday of playing with serious coils and circuits.
                      It is time for us to change - get away from the transistors and relays.
                      Why? Because they limit our ability, they are limited in power and they
                      are most likely the obstacle we have to reach our goals. How to do? Maybe get them isolated from the circuit..........?
                      [QUOTE=Bodkins; Aromaz@All
                      Can you get two tubes/sphere in your origanal setup in the way i posted in the video?, the thing is anypoint you connect to ground the tube can be used....[/QUOTE]
                      I am not sure I understand this clearly? On my circuit once it is running and pulling the power form earth, I can connect the tube (1 to 5 units) one pole anywhere on the circuit with the other to gorund and it will lit up. Even connecting to positive or negative of battery and off to earth. .......
                      • Riddle
                        I have a riddle:
                        Everything goes into the Black one from where nothing came out.
                        Everything comes out from the White one where nothing went in.
                        The Black and the White are not the same because
                        The Black humans can See,
                        The White humans Theorize.
                        What is the Black and what is the White.
                        @Inquorate: You'll know already, please do not not post yet
                        • Originally posted by Aromaz View Post
                          I have a riddle:
                          Hi Aromaz,
                          Not sure about what is black and what is white,But sounds like quantum tunneling .
                          -Gary
                          • Riddle
                            Ha, I like that riddle. I'll keep my lips closed till someone gets it... Had me stumped for a good 15 mins aromaz.
                            • Although...
                              I might have to call a point of order re humans not seeing the white one.. Nat posted something written in 1920 that...
                              Bite my tongue bite my tongue bite my tongue
                              • @gmeat - I will just add a line to it for you.
                                It is some sort of related, but not quite!
                                @Inquorate - Well, we might see the results of the 'White one' but we never actually saw the 'White One' I started developing a different theory and about 25 minutes ago found that there are actually other people that also reached this theoretical conclusion.
                                Part of the fun is for your tongue be bitten on
                                Nat 1920 ?? Another posting maybe?
