Originally posted by Mutten
Originally posted by Aromaz View Post@Mutten, I am a bit occupied for this weekend with Luc's. Do you have a link to the very possible site / diagrams / videos pf Dr. Stiffler's? Will appreciate time savings!
Dr. Ronald Stiffler is his website.
Youtube Channel YouTube - MRH2O2's Channel
Sorry for the thread derail~
circuit I was going to mess with.
Selfrunning cold electricity circuit from Dr.Stiffler
@Mutten, I am a bit occupied for this weekend with Luc's. Do you have a link to the very possible site / diagrams / videos pf Dr. Stiffler's? Will appreciate time savings!Originally posted by Mutten View Post....... Dr Stifflers SEC15-3. I haven't seen any action on this on overunity.com for a while. There are a lot of strange phenomena these circuits share.
This isn't what I was looking for in regards to mosfets, but I found this circuit to be intriguing.
Single transistor solid state Tesla Coil
single 2n3055 driving a tesla coil.
when I saw the video a couple of days ago and saw the splotch on the ceiling above the coil, that was my first impression too.Originally posted by Aromaz View PostYou cooked the ignitio coil? Then that 'water' was transformer oil rather than water. Makes sense why it remained so long.
Wecome back. Hmm, those ignition coil...... strip them, there is a very delicate coil inside which will take many hours to wind.
Oil expands when it gets hot and probably bursted through a seal and sprayed up.
Your circuit is next to replicate, was waiting on more 3055's. I just hope I have the right 2n2222's.Originally posted by Aromaz View PostThe plenty burned 555's is what made me stop and actually find this circuit accidentally. I tried a number of 555 circuits, both as TIMER and PWM's. If you get it right it might be good. I would like to see what will happen if we can take this circuit up to something like 350 kHz rather than the maximum 2 or 3 kHz it settles on.
The cap is also another aspect not yet fully investigated.
I agree with the higher frequency, Gotoluc was messing with that area and getting great results. A week or so ago i was researching even higher frequencies, ended up getting sidetracked on a mini tesla coil forum. I'll try to dredge up the info but someone was using mosfets in the Mhz range.
Slightly off topic but I ordered enough parts to build one of Dr Stifflers SEC15-3. I haven't seen any action on this on overunity.com for a while. There are a lot of strange phenomena these circuits share.
@ Aromaz
I've gotten the system output up to 20khz in self oscillation mode by using that salt water capacitor off the + of secondary to magnetically quenching spark gap to cfl to ground. With a bigger F cap, could get output frequency quite high?? On the resonance thread there's been talk about making hv caps out of plastic page protectors or glass and Alfoil. Or was it the gray tube thread?
The plenty burned 555's is what made me stop and actually find this circuit accidentally. I tried a number of 555 circuits, both as TIMER and PWM's. If you get it right it might be good. I would like to see what will happen if we can take this circuit up to something like 350 kHz rather than the maximum 2 or 3 kHz it settles on.Originally posted by Mutten View PostI've replicated Lidmotors 555 circuit with some minor modifications since I didn't have all the parts needed. ........
I'm curious to see what happens when you add a big cap in parallel to the source voltage, and have 1 master 2n3055 and 3 or more 2n3055s slaves pumping to the primary coil with a very short duty cycle. I'm looking for the big punch with a rapid off time.
You cooked the ignitio coil? Then that 'water' was transformer oil rather than water. Makes sense why it remained so long.Originally posted by nat1971a View Postyeah baby i am back in business
i have my first kill of one ignition coil and one trannie.
LOL
LOL
@ mutten
Thanks for the reminder. I'd saved lidmotor's schematic then forgotten about it... So much is happening at mo, and I'm following too many threads to keep it all straight.. But that's a good thing? Right?
I used a 4733 zener diode going from pin 7 to pin6 (black band on 6)Originally posted by Inquorate View PostWhere exactly did you add the diode? I have spare 555's but still...... Could you post a schematic? Much appreciated if you can :-)
I tried a couple of other low voltage diodes and there didn't seem to be much difference
circuit is just a hybrid of this 555 timer and Lidmotors from page 64
Diode on 555
I was missing some 10k potentiometers, so I made due with what I had on hand.
resistance to pin 7 is 200 ohms, and pin 7 to 6 is 1k ohms.
I placed a diode between 7 and 6 also. This reduced the duty cycle to <50%.
I don't have an Oscope so I'm not sure what the duty cycle is.
pin 5 has a .68 uf ceramic, this seemed to sharpen the on/off response.
using a 4.7 uf cap connected to pin 6.
I got these ideas from 555 timer
Light output is slightly diminished with the addition of a diode, but the amp draw is way down, the transistor and 25ohm rheostat don't even get warm now.
while playing around I hooked the high voltage output from the coil to the aluminum duct work in my apartments heating system, there was a significant increase in light output along with high voltage present over the entire circuit.
On a side note, I've blown up quite a few 555's playing around, first couple were because I forgot the 1n4001 diode going to ground to protect the circuit. Very important to have this it seems.
Waiting for an order from jameco.
I'm gonna try to use an opto-decoupler for the 555 to help protect it even further. Need to wait since I blew up my last 555 last night.
Dear Aromaz,
On your Video 21 and 22 you have definitely achieved something,
Why don't you keep going on using heat generator system?
Please use Far IR lamps and use them as load.. If you don't like to generate heat, then please try to generate magnetic force... to generate rotation..
