  • lost66
    Originally posted by Sephiroth View Post
    hmmm... ok, it sounds like the power windings aren't connected. By shorting the emitter and collector you are bypassing the transistor and so it should give you the same result as just connecting the coil to the battery.
    Try disconnecting the fan from the battery and measure the resistance between the wire that is normally connected to the primary battery's positive and the collector on the transistor...
    It should be around 1 ohm.
    ok i have 1ohm on the + and on the casing and 1ohm on the pot and neon
  • Sephiroth
    Originally posted by lost66 View Post
    nothing happens when i short casing 2 any 1 of the pins
  • lost66
    Originally posted by blackchisel97 View Post
    Hi lost66.
    Neon goes between emitter and collector and suppose to short high voltage, preventing transistor. However, transistor can fry within seconds with neon being lit, since neon treshold is higher than transistor's max. voltage. For neon to fire you need over 80+V. 2N3055 is rated @ 60V. Where is your resistor connected?
    hi blackchisel97
    there was 1 in series with 1 of the neon leads.
    i thought it was there because we run on 220v or something
  • blackchisel97
    1 thing on the neon, it had a resistor on it, was that ment 2 b there
    Hi lost66.
  • lost66
  • lost66
  • Sephiroth
    i was just getting exited, looked as if it wanted 2 spin and all that was needed, was 2 set the pot or some thing. but now u tell me about the short thing, there is no jump :-(
    So there is no reaction from the fan when you short the base and collector? if so then sounds like the transistor may be fried... Strange since you are using a neon
    But it will jump if you short the collector and emitter, right?
  • lost66
    the most common problem is a fried transistor. try briefly shorting the collector (the transistor casing) and the base (the pole with the potentiometer) together. If the transistor is still good, then it should repel the magnets and make the fan blades jump.
  • Sephiroth
    that might b a plan. 4:30 now, so i wander if it is worth sleeping (sleep is overrated) well i tried both ways but it wont spin up, if i sort of pulse it by hand, i can get it to turn (in a way) made a small video of it (15sec) but dont know how to post it.
  • lost66
    lol... it's half past midnight here so may have to pick this up again in the morning
  • Sephiroth
    that is so true i will get every thing ready (it is only 2 in the morning so i think a pot of coffee will also b in order
  • lost66
    WOOPS... I made a mistake... I just reuploaded the image... this is the way to wire it!
    If you wire it up the way it is shown there then we can try and pin point the problem... Can't test it while it is in pieces
  • Sephiroth
    i wish i can say, i did. but i did not take 2 much notice when i took it apart. but i do beleve it would have been like that @ some time (i tryed all options but the best i got out of it, was it rocked from side to side) i will have to try it again as u have it there.
  • lost66
  • Sephiroth
    hi sephiroth thanx 4 the lookin. it is the original windings. i am all in 4 good omens
    Good... that means the coils are definitely wound correctly
    do you have it wired up like this?
