Duncan,
Very interesting post! I know heterodyning got a major push with regard to the TPU on the other big energy research forum back around 2007. Perhaps it was too successful...
Stan Dayo notes that Henry Moray used a set of three (I think) heterodyning coils in one of his devices.
So are you basically saying that a heterodyned set of signals will produce a greater volume under the combined wave form than would be produced separately?
Bob
Single Wire Power - A Search for Ambient Power to do Wwork
I'm not sure what you were actually saying and I assume that some things are well known when perhaps they are not.Originally posted by Duncan View PostWell thanks for reading me GR and thanks are also owed, (I guess) for posting this clip although In truth, I'm not at all sure what you wish it to convey to me and From your question mark I assume thats visa versa?
The harmonics of sine and square waves are the same frequencies theoretically. The intensity of the harmonics is different, which is what gives them different sounds. Through adjusting the pulse width of a square wave various harmonics are suppressed. A sine wave by definition sounds like a sine wave due to the lack of harmonics, and every conceivable waveform can be broken down to a collection of sine waves that are sounding at the harmonic frequencies corresponding to that waveform. When all sine waves are playing together at the correct frequencies and intensity, the output is a square wave.
interpretation of electricity. It is designed to show the viewer exactly what they would expect to see using electromagnetic norms And it does . Even the clip I showed by gotoluc is only there to show 'a tendency' It is rather that which is not shown that is of interest.
It is just a view I take but it connects rather like this .. I am constantly being shown and having demonstrated the actions and effects of electromagnetism and the electromagnetic wave.
All predictable (if complex) and expected . It is I suggest exactly where we should not be looking.We need and should be searching the exceptions !
There is no absolute scale of size in the Universe, for it is boundless towards the great and also boundless towards the small. There is no absolute scale of size in nature, and the small may be as important, or more so than the great Oliver Heaviside
Lets look at one example in practice and see where the hole is blown through the theory by practical application. Most of what we are taught regarding waveforms comes from the pen of Joseph Fourier
of particular interest are the transforms.
Concerning sine waves in their simplest form basically informs. hetrodyning F1 and F2 results in f1+f2 , f1-f2 and of course the original f1 and f2 obviously the waves then to mix again adinfinitum.. normally colliding at points it time and space expending energy.
Although in theory 'a perfect' sine wave is not possible It is essentual in radio work to get extreamly close. Beating two 'near perfect' sine waves together with the ability to shift one of them 2π radians w.r.t the other and at specific frequency ratio's (one to t'other) can and does take us 'through the mirror'
to a different world. It can bring about the 'perfect square' or switch Bob conciders.
An infinate ammount of what our instruments and mathematics assumes is nothing proves to be an almost limitless energy supply. Here is fellow member MJN outlineing that effect from solid practical experiance This key post is copied from his thread on water fracture but the anomaly regarding waves and switching would obviously apply .. 'anywhere and everywhere' including a single wire.
First I will explain the frequencies.
The frequencies I chose could have been other frequencies, but, the difference between them is important.
If you look at the first frequency of 120mhz, the secound is 6X to 720mhz. We now look at the heterodyning frequencies:-
Without filtering out we will get many orders of exact frequencies with a finite space between them. If we were to start with only 3X difference between these two frequencies we would get a different result.
Example:-
100mhz and 300mhz
200 400
200 600
400 800
400 1200
100mhz and 600mhz
500 700
200 1200
1000 1400
400 2400
2000 2800
Now you can see the difference with a 6X spacing rather than a 3X spacing. Each new frequency will interact in a heterodyning mode as well and you need to run this through a computer program to see the full frequency spectrum. MJN
Kind Regards Duncan
Duncan,
Thank you for your post. I don't pretend to understand a lot of the technical details and formulas you put forward to illustrate your points. However, I believe we both see that resonance plays an important role in the energy collection process. Interesting that you raise the whole chrystal issue. I think a person would be hard pressed to deny their value in gathering energy from the ambient, or radiant energy and amplifying properties in their many forms. If I had more time and energy, I'd be playing with these as well.
Thanks again for the post - always interested in what you have to say.
Bob
?Originally posted by Duncan View PostI suggest here that the harmonic progression of a (perfect) sine wave is different from the progression of a (perfect) square wave.
Harmonics - Sine, Square & PWM - YouTube
for consideration ..
a progression of video's and web pages for your entertainment which progress this thinking ..
Harmonic and overtone progression
crystals driven in overtone or harmonic mode
quartz crystals being polarized (A'la T.H.Moray perhaps.)
Just as volts amps ect are founded on electro-magnetic polarized principles so the electrostatic phenomena has IMHO some parallels for instance .. To pole quartz being as important to electrostatics as to magnetize iron is to electromagnetism.
Piezoelectric Materials: Crystal Orientation and Poling Direction | COMSOL Blog
here is quartz crystal being Poled by German researcher Thomas Trowoger prior to being used in a pyramid construction which in turn drives motors. Its a long video but the piece that I would like to interest you in is circa 0H40min as the man poles quartz.
That then leads me to ponder this
https://www.youtube.com/watch?v=x2kY6FFpgRs
I suggest here that the harmonic progression of a (perfect) sine wave is different from the progression of a (perfect) square wave. This can be seen used in some fields such as .. frequency selection using quartz crystals and filters, grid power line failure by harmonic progression, and some (old) teaching of armature reaction. You may like to view this as electricity (whatever that is) divided like a road of houses odd numbers one side even numbers the other. overtones and harmonics respectivly, I do.
All I try to point out here is when using the blanket term 'resonance' take a deep breath and take a hard look at what you actually mean.
For instance Which particular type of wave (Transverse or longtitudinal) do you consider here.
Where is all the predictive maths for these events that give form to chaos ? Where is the engineering science and units of the electrical longtitudinal wave and its inevitable off spring? Its certainly not going to be volts amps and ohms law !
In fact we don't know the laws, we dont know the units. Counter space ? Negative power? One thing I do know is it can be manipulated and adjusted to work the problem being no one seems to have simplified the engineering principles or acknowledged the units which could make for easy replication. Perhaps EPD does but he's certainly not making it simplified .. or easy.
Interesting intro to plasma ball and plasma properties:
Bob
Single Wire Power Transfer from Plasma Bulb
Here's a new video from YT user Thomas Ferko showing a single wire power transfer from a plasma bulb. Charge is being drawn from a 7.5 W plasma bulb AND from ground wire in home to light a 220V 40W bulb:
Bob
Resonance, Square Waves & Compressed Harmonics
I should also mention that resonance with the right accompanying levels of overtones/harmonics is important in loosening the bonds that restrain the aether from entering open system circuits. If we look at successful single wire replications involving high voltage, they often come up as a square wave on the oscilloscope. The square wave, to put it simply, contains compressed harmonics of the fundamental, giving it the shape it has.
Resonance with harmonics --- square wave --- single wire power from the aether. They all fit together.
Bob
Originally posted by Bob Smith View PostOne thing that I will say about this setup is that it is an open system.
Resonance seems to be an important key which enables a system to interact with the ambient to transform energy in the ambient into a useable format.
BobAll the reading, research, experimenting and observing I’ve done leads me to believe that resonance is responsible for nullifying or at the very least weakening the inertial lines of force that keep objects in position. These inertial lines of force may in fact be synonymous with gravity.Originally posted by Bob Smith View PostA few comments to refresh some past points made:
During the EST Conference Panel Discussion, Eric Dollard made a number of statements about electricity. At one point, he comments on a FE researcher loosening the molecular bonds in water with dielectricity. I can't remember exactly where in the video, but the whole thing's worth watching, and can be found here: https://www.youtube.com/watch?v=lWoLH21ITys
I would submit that dielectricity is what we're after in speaking of accessing ambient power to power a single wire load.
In one of Eric's earlier Borderlands videos, he shows how resonance separates magnetism from dielectricity in a coil. https://www.youtube.com/watch?featur...UBKgnnc#t=1108
YT user kdkinen replicates EPD's demo: https://www.youtube.com/watch?v=-DmAyYhnRgc
Magnetism is associated with amperage and heat, and dielectricity with voltage. It may in fact be that under certain conditions, pure dielectricity may interact with certain coil configs, capacitor arrangements or batteries to produce various coloured sparks or amounts of heat (or lack thereof).
I think we might get further ahead by looking at ways in which dielectricity, once separated from magnetism, can be utilized to do work. It may be that in order to do some serious work besides lighting LEDs, it needs...
a) to be converted to conventional electricity (AV plug is one way, but what follows?)
b) to have a useful...
- charge density,
- pressure
- resistance/impedance
How are these determined/accessed?
Bob
It is also my belief that resonance weakens the inertial barrier between an open electrical system and the aether. You “poke” the aether with a circuit oscillating at the right resonant frequency, and its inertial forces that keep it external to the system weaken. In this manner, resonance can be seen as a means of weakening the inertial barrier between the aether and the open electrical system. Resonance, in effect, is the door that opens the passageway between the two, allowing the aether’s immense reservoir of primordial potential to flood into the system as electrical charge, or more precisely as dielectricity. There is much more to this, but it is late, and I will resume in the very near future.
Bob
Aski him how would he do the reverse ?Originally posted by Bob Smith View PostA few comments to refresh some past points made:
Dielectricity, Resonance and Doing Work
A few comments to refresh some past points made:Originally posted by Bob Smith View PostOne thing that I will say about this setup is that it is an open system.
Bob
- charge density,
- pressure
Bob
Bob
