Hello again Hiwater,
I remember building the ufo Politics smaller dc motors some years ago. That motor was total surprise to me. One set of brushes was a motor end, the other was generator end.
Also the starter/generator on the EZ Go golf cart got me going somewhat in trying different experiments with coils and extra brushes.
Anyway just chatting.
Wantomake
Yes I have lots of parts laying around also. I am this winter working on a DC model. Comparing it to AC. I run the figures from the numbers sugested on the capacitor. Those numbers coincide with the numbers in amps to run this device on DC. Trial and error method. Nothing concrete. Good to hear from you again.
Hey Hiwater,
I am building lithium battery packs these days for solar storage. Haven't tried anything with the generators for a long time. Parts are laying around the shop from the Lockridge device project but I've not touched any of it.
wantomake
Powerpack. If you think about it what was a generator designed to do . Either 6 or 12 volt. Run 2 head lamps and a heater motor, That the basis of the old style generators..Through the brushes switching on the commutator the collapse of the magnetic feild goes back in to all the other windings of the armature and cant be collected there. So i believe the switching or pulsing unit was done outside of the case with one of the wires of the tri coil grounded to the case and the other wire to one of the brushes doing the switching. The tri coil acts like a capacitor at that point and removes the arc from the switching brushes at that point . Which in turn raises the voltage through the other windings on the tri coil. This is still a work in progress. Still kicking around ideas.
Power pack,
Some of us spent much resources on this idea and I personally lost interest after all the effort. I agree with your post things aren’t the same as during that time period. Therefore I’m into other projects at this time.
wantomake
The curiosity has been overwhelming, regarding has anyone in this world to this date, finally design a functioning machine that actually mimics what that German Engineer put together and Sgt Lockridge found? Forget what Lindemann/Bedini attempted to "think" what it does, but look at those old pictures and then you'd conclude this is not a 230VAC machine. The Armature of a 6VDC Bosch Generator can only produce up to 10+VDC. You have to go back in time and understand what those materials were at the time. Those metals making up the Armature, the Stator, the Mag Wire, all those materials we take for granted in 2021. But not available in the 1940's. Who has done this?
witches all over the world...
sad. really. But a wife is usually no inventor.
maybe i face same faith in the future when I follow my research ...
*thinking...*
Originally posted by mbrownn View Postall my equipment was taken (no conspiracy. I got a divorce).
Originally posted by HansKammler View Postcanīt resist to write again, just short:
how many turns you do on 1 winding on your armature ?
Originally posted by HansKammler View Postyou wind a wire from contactsegment to the back iron core many times and
return 180 degr. on the segment vis a vis ?
Originally posted by HansKammler View Postand there are not 4 blanks in the photo, you did blank every 2nd !!
(is this photo obsolete ?)
cheers). At this point with no equipment, I decided to try and get people interested in my work so the development could continue.That was about 3 years ago. I will be ready to start building again in the next few months.
canīt see this on the picture.
cheers
Originally posted by HansKammler View Postthank you mbrown for your explanations.
This is a whole new concept and I have to check how can I do all
this mechanical work at home. With electronics this is more easier.
Interesting you do a mechanical NE555 oscillator with your 4 blank armature.
Do you have a photo of your armature (actual) so I can figure out
how you wire it (wave or straight) I never wire a motor in my life.
When I buy the Bosch generator I my first thought was, **** how this dirty thing works. real Hard (!) ware
I have fear to destruct my armature if I begin to unsolder the windings.
But wire to wire it should work
cheers,
H.
http://www.energeticforum.com/attach...r-img_0007-jpg
http://www.energeticforum.com/attach...r-img_0029-jpg
http://www.energeticforum.com/attach...r-img_0028-jpg
The hardest part is getting the old windings out as they are usually held in with epoxy. I used a hack saw to cut the windings off at each end and then a punch to knock them out.
This video will help you with the wind, the only difference is I connected to commutator segments at 90 degrees do that i did not have to move the brush holders that were already there. http://www.energeticforum.com/redire...lpage%23t%3D99
cheers,
H.
Originally posted by HansKammler View Postthank you for your explanations.
1,
I realize at the "interesting motor" that you solder not every plate
on the armature with a coil because you will reduce the "brushfire" by
switching to the next segment. OK
so i think I can place gluefilm (isolationtape) on every 2nd plate(segment)
of the armature right ?
What I am thinking right now is 4 blank segments between each coil. this will allow a full charge and discharge of the armature before the next coil is charged, but this may change, as I'm still working on it.
Originally posted by HansKammler View Post2,
but then I realize to run your setup I have to rewind , resolder all segments
to set the wire lap in a 90 degree formation. OK
a lot of work for me to rebuild the commutator. OK this work have to be done.
1) so that the commutator will line up with existing brush positions
2) It keeps the wires close to the shaft preventing them getting caught in the brushes.
Nothing special, just practical.
Originally posted by HansKammler View Post3, Do you really think you are fast enough to make contact with the 2nd set of "take energy" brushes when the first set of "energizing" brushes will
leave the segment ?
I donīt think you have the time, coz soon you are lost contact you will get the kickback and this kickback can fly to the brushes if there are in the air.
so the only logic is to put the 2nd brushes to the same segment, before
the 1st brushes leave it ! True ??
The way I set up the MADMAG, the overlap can be greater.
Going back to the commutator, I had one blank between each coil, this was great for the MADMAG, but didnt seem so good to get the transformer actions like we want in this device. In the MADMAG it gives us one coil charging and one coil discharging at the same time, there is no off time to speak of.
For this device, by having brushes the same width as the commutator segments and 4 blank segments between each coil, we will have a 50% on time and 50% off. This requirement makes an ideal armature to have an even number of slots, the commutator ideally would have double the number of segments as there is slots, and that number be divisible by 5 ie 10, 20, 30 etc. This isnt proven yet, but is what I am working on now.
Brush and Fire
1,
2,
leave the segment ?
For my MADMAG (interesting Motor) we may be able to use off the shelf field coils and get reasonable performance. For the self runner, if it is possible and I believe it is, we will need all the parts to be matched to get optimum performance, but what those specifications are remains to be seen.
If one of the functions of the trifilar coil is impedance matching, this may help us, but I dont think it is going to be that easy.
